Hello team
Finally I had managed to install and configure properly, nethserver vlan and ubiquiti edgeswitch
Working flawlessly, and inter vlans routing just great… Nethserver does the routing automatically
Hello team
Hi, great.
Could you kindly shed some light into inter vlan
Routing. That still confuses me to date
vLAN are… different networks on the same cable (putted into the simplest possible way).
This allows you to split your switch into multiple virtual switches, or use one ethernet cable as a multiple cable (connecting with only one cable 2 or more networks among vLan capable devices)
Anyway @Vitor_Hugo_Barbosa you’re always welcome if you want to brag your setup
Maybe this topics might have some good information for you:
Hello friends i will write a how to… Again i am learning this but it work… Just awesome really and easy to do…
Inter vlans routing is added to the nethserver firewall automatically when you create the vlan
You don’t need to add an extra card to do it 1 port to rule them all
(Lord of the rings quote)
vLAN = Network Adapter = same approach lead by the zone concept… ![]()
Exactly
