Twenty CRM 1.0.2
Twenty is an open-source CRM comparable to Salesforce.
Main page: https://twenty.com/
Twenty on Github: GitHub - twentyhq/twenty: Building a modern alternative to Salesforce, powered by the community.
App documentation: GitHub - mrmarkuz/ns8-twenty
Thanks to @capote for pointing out that app.
Thanks in advance for testing and feedback.
Great job @mrmarkuz :+1:
Can you also integrate Planka into NS 8?
looking at this: https://raw.githubusercontent.com/plankanban/planka/master/docker-compose.yml
probably module generator could get it done in <>5mins
but for a simple looking app, it sure does have alot of things. @transocean any considerations for Wekan
Edit: Markuz did it GitHub - mrmarkuz/ns8-planka
Planka is already available from my repo in Software Center. The restore doesn’t work yet but it should be good enough for a first test…
