fstab warnings
Installation process generates some warnings. They can be safely omitted⌠just reporting it:
Jul 16 18:01:25 localhost esmith::event[1305]: expanding /etc/fstab
Jul 16 18:01:25 localhost esmith::event[1305]: WARNING in /etc/e-smith/templates//etc/fstab/50options: Use of uninitialized value $property in string eq at /usr/share/perl5/vendor_perl/esmith/DB/db/Record.pm line 167.
Jul 16 18:01:25 localhost esmith::event[1305]: WARNING in /etc/e-smith/templates//etc/fstab/99writefile: Use of uninitialized value in concatenation (.) or string at /etc/e-smith/templates//etc/fstab/99writefile line 4.
Jul 16 18:01:25 localhost esmith::event[1305]: WARNING: Template processing succeeded for //etc/fstab: 7 fragments generated warnings
Jul 16 18:01:25 localhost esmith::event[1305]: at /etc/e-smith/events/actions/generic_template_expand line 64.
during installation (can be ommitted)
Jul 16 18:00:02 localhost systemd-tmpfiles: Failed to parse ACL âd:group:adm:r-x,d:group:wheel:r-xâ: Invalid argument. Ignoring
Jul 16 18:00:02 localhost systemd-tmpfiles: Failed to parse ACL âgroup:adm:r-x,group:wheel:r-xâ: Invalid argument. Ignoring
MORE GENERAL WARNINGS (they donât prevent normal usage; some can raise the clear yum cache red warning message)
Jul 17 11:56:16 intranet systemd: Configuration file /usr/lib/systemd/system/auditd.service is marked world-inaccessible. This has no effect as configuration data is accessible via APIs without restrictions. Proceeding anyway.
Jul 17 11:56:17 intranet kernel: ipt_ULOG: ULOG: fail to register logger.
@nethserver-fax (installed with no modem/fax device present)
Jul 17 20:35:29 intranet pkgaction[22654]: install: @nethserver-fax-server
(âŚ)
Jul 17 20:35:59 intranet esmith::event[23325]: WARNING in /etc/e-smith/templates//var/spool/hylafax/etc/config.nethesis/15AreaCode: Use of uninitialized value in concatenation (.) or string at /etc/e-smith/templates//var/spool/hylafax/etc/config.nethesis/15AreaCode line 10.
Jul 17 20:35:59 intranet esmith::event[23325]: WARNING: Template processing succeeded for //var/spool/hylafax/etc/config.nethesis: 1 fragment generated warnings
Jul 17 20:35:59 intranet esmith::event[23325]: at /etc/e-smith/events/actions/generic_template_expand line 64.
(âŚ)
Jul 17 20:36:06 intranet FaxQueuer[24326]: Could not create FIFO: Permission denied.
Jul 17 20:36:06 intranet systemd: hylafax-faxq.service holdoff time over, scheduling restart.
Jul 17 20:36:06 intranet systemd: start request repeated too quickly for hylafax-faxq.service
Jul 17 20:36:06 intranet systemd: Failed to start HylaFAX faxq (job scheduler service).
Jul 17 20:36:06 intranet systemd: Unit hylafax-faxq.service entered failed state.
Jul 17 20:36:06 intranet systemd: hylafax-faxq.service failed.
ntopng network interface warning
Jul 17 20:42:19 intranet ntopng: [NetworkInterface.cpp:950] WARNING: If you have TSO/GRO enabled, please disable it
Jul 17 20:42:19 intranet ntopng: [NetworkInterface.cpp:952] WARNING: Use: sudo ethtool -K enp0s3 gro off gso off tso off
UPS support (no UPS connected, can be omitted)
Jul 17 20:54:27 intranet pkgaction[24776]: install: @nethserver-nut, collectd-nut
Jul 17 20:54:33 intranet collectd[24875]: read-function of plugin `nutâ failed. Will suspend it for 20.000 seconds.
dovecot warning: fd limit
Jul 17 20:58:38 intranet dovecot: Warning: fd limit (ulimit -n) is lower than required under max. load (1024 < 2000), because of service auth { client_limit }
Chat Server
Jul 17 21:27:30 intranet pkgaction[1904]: install: @nethserver-messaging
Jul 17 21:27:59 intranet esmith::event[2374]: Canât call method âconfigServiceAccountâ on an undefined value at /etc/e-smith/events/nethserver-ejabberd-update/S02nethserver-ejabberd-conf line 34, line 747.
Jul 17 21:27:59 intranet esmith::event[2374]: Action: /etc/e-smith/events/nethserver-ejabberd-update/S02nethserver-ejabberd-conf FAILED: 2 [0.222883]
httpd
Jul 17 21:38:05 intranet httpd: [Sun Jul 17 21:38:05.346001 2016] [alias:warn] [pid 4584] AH00671: The ScriptAlias directive in /etc/httpd/conf.d/squid.conf at line 6 will probably never match because it overlaps an earlier Alias.
Jul 17 21:38:05 intranet httpd: [Sun Jul 17 21:38:05.346675 2016] [alias:warn] [pid 4584] AH00671: The Alias directive in /etc/httpd/conf.d/welcome.conf at line 29 will probably never match because it overlaps an earlier Alias.
Jul 17 21:38:05 intranet httpd: [Sun Jul 17 21:38:05.346682 2016] [alias:warn] [pid 4584] AH00671: The Alias directive in /etc/httpd/conf.d/welcome.conf at line 30 will probably never match because it overlaps an earlier Alias.
Jul 17 21:38:05 intranet httpd: [Sun Jul 17 21:38:05.346684 2016] [alias:warn] [pid 4584] AH00671: The Alias directive in /etc/httpd/conf.d/welcome.conf at line 31 will probably never match because it overlaps an earlier Alias.
Jul 17 21:38:05 intranet httpd: [Sun Jul 17 21:38:05.346687 2016] [alias:warn] [pid 4584] AH00671: The Alias directive in /etc/httpd/conf.d/welcome.conf at line 32 will probably never match because it overlaps an earlier Alias.
Jul 17 21:38:05 intranet httpd: [Sun Jul 17 21:38:05.346688 2016] [alias:warn] [pid 4584] AH00671: The Alias directive in /etc/httpd/conf.d/welcome.conf at line 33 will probably never match because it overlaps an earlier Alias.
Jul 17 21:38:05 intranet httpd: [Sun Jul 17 21:38:05.346690 2016] [alias:warn] [pid 4584] AH00671: The Alias directive in /etc/httpd/conf.d/welcome.conf at line 34 will probably never match because it overlaps an earlier Alias.
Jul 17 21:38:05 intranet httpd: [Sun Jul 17 21:38:05.346692 2016] [alias:warn] [pid 4584] AH00671: The Alias directive in /etc/httpd/conf.d/wpad.conf at line 16 will probably never match because it overlaps an earlier Alias.
Jul 17 21:38:05 intranet httpd: [Sun Jul 17 21:38:05.346694 2016] [alias:warn] [pid 4584] AH00671: The Alias directive in /etc/httpd/conf.d/wpad.conf at line 17 will probably never match because it overlaps an earlier Alias.
WebTop (no users/groups set up beforehandâŚ)
Jul 17 22:47:15 intranet pkgaction[14608]: install: @nethserver-webtop-groupware
Jul 17 22:48:11 intranet server: INFO: The APR based Apache Tomcat Native library which allows optimal performance in production environments was not found on the java.library.path: /usr/java/packages/lib/amd64:/usr/lib64:/lib64:/lib:/usr/lib
Jul 17 22:48:16 intranet esmith::event[14939]: Canât locate object method ânewâ via package âURIâ (perhaps you forgot to load âURIâ?) at /usr/share/perl5/vendor_perl/NethServer/SSSD.pm line 148.
Jul 17 22:48:16 intranet esmith::event[14939]: Action: /etc/e-smith/events/nethserver-webtop4-update/S40nethserver-webtop4-domain FAILED: 255 [0.447778]
(âŚ)
Jul 17 22:48:18 intranet server: SEVERE: Could not contact localhost:8005. Tomcat may not be running.
Jul 17 22:48:18 intranet server: Jul 17, 2016 10:48:18 PM org.apache.catalina.startup.Catalina stopServer
Jul 17 22:48:18 intranet server: SEVERE: Catalina.stop:
Jul 17 22:48:18 intranet server: java.net.ConnectException: Connection refused
Jul 17 22:48:18 intranet server: at java.net.PlainSocketImpl.socketConnect(Native Method)
Jul 17 22:48:18 intranet server: at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:339)
Jul 17 22:48:18 intranet server: at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:200)
Jul 17 22:48:18 intranet server: at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:182)
Jul 17 22:48:18 intranet server: at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392)
Jul 17 22:48:18 intranet server: at java.net.Socket.connect(Socket.java:579)
Jul 17 22:48:18 intranet server: at java.net.Socket.connect(Socket.java:528)
Jul 17 22:48:18 intranet server: at java.net.Socket.(Socket.java:425)
Jul 17 22:48:18 intranet server: at java.net.Socket.(Socket.java:208)
Jul 17 22:48:18 intranet server: at org.apache.catalina.startup.Catalina.stopServer(Catalina.java:498)
Jul 17 22:48:18 intranet server: at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
Jul 17 22:48:18 intranet server: at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
Jul 17 22:48:18 intranet server: at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
Jul 17 22:48:18 intranet server: at java.lang.reflect.Method.invoke(Method.java:606)
Jul 17 22:48:18 intranet server: at org.apache.catalina.startup.Bootstrap.stopServer(Bootstrap.java:370)
Jul 17 22:48:18 intranet server: at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:457)
Jul 17 22:48:18 intranet systemd: tomcat.service: control process exited, code=exited status=1
Jul 17 22:48:18 intranet systemd: Unit tomcat.service entered failed state.
Jul 17 22:48:18 intranet systemd: tomcat.service failed.
Jul 17 22:48:18 intranet systemd: Started Apache Tomcat Web Application Container.
Jul 17 22:48:18 intranet systemd: Starting Apache Tomcat Web Application ContainerâŚ
Jul 17 22:48:18 intranet esmith::event[14939]: [INFO] tomcat restart
Jul 17 22:48:18 intranet esmith::event[14939]: Action: /etc/e-smith/events/actions/adjust-services SUCCESS [1.987779]
Jul 17 22:48:18 intranet esmith::event[14939]: Event: nethserver-webtop4-update FAILED
(âŚ)
Jul 17 22:48:24 intranet server: log4j:WARN No appenders could be found for logger (org.apache.commons.beanutils.converters.BooleanConverter).
Jul 17 22:48:24 intranet server: log4j:WARN Please initialize the log4j system properly.
Jul 17 22:48:24 intranet server: log4j:WARN See http://logging.apache.org/log4j/1.2/faq.html#noconfig for more info.
(âŚ)
Jul 17 22:48:31 intranet server: INFO: Server startup in 12808 ms
