I couldn’t reproduce it for now (/cc @m.traeumner)
Tried using following machines as remote DC:
Windows 2012r2
NethServer 7.4
Since the error is “Server not found in Kerberos database.”, you probably have some network troubles, maybe only on DNS resolution. Are you sure you don’t have multiple DC on the same forest?
When the messages are showing? During access to the Server Manager?
Samba: authenticated access to file shares
Mail server
sending and receiving mail
antivirus filter on received mail
Groupware
basic mail features
access to calendars and contacts
Web proxy
web access with transparent proxy
antivirus filter on using EICAR test
Web applications (eg. NextCloud)
Asterisk with dahdi kernel modules and FreePBX
usually, on Status\Dashboard or in Management\Users and group…
i too think something on the net or some timeout on AD server (Users
819,Groups 298, Machine accounts 1843)i must investigate…
so as not related to 7.5 i think we can split this (or i reopen in future) in a new thread and go on here with testing 7.5
i don’t think…
personally, being in alpha, usually, I try to check that everything is installable correctly and then go on with more detailed tests on individual packages
and judging by the messages of the last few weeks I would add to the hot points also
Deep packet inspection (DPI) (upgrade and installation)
I would keep it in alpha for a few days (for the things I miss to test)
if instead others already have at least installed everything … let us know
updating now… i was almost sure i’ve updated 3 hours ago…
btw, i only see the package after a yum clean & update from shell. installed with others (now i am in beta) but Virtual machines manager is still there
ah i don’t know if the fstab-update event here can give problems…
Yes there’s a nethserver-release update named “beta”. However consider it still “alpha” until we turn the symbolic link in repository from 7 -> 7.4.1708 to 7 -> 7.5.1805!
I confirm that groups metadata should be ok, this is the actual file.
By the way everything should be simpler to test when we switch the directly to 7.5.
Another great catch: it doesn’t have side-effects but the migration procedure will be marked as failed. I’m going to remove it, thank you!
yes, there had to be some problem with the repo (even if I do not understand why,I use the same procedure) now seems to be all ok both with mail (2) and with sogo (and webvirt)
I’m sorry to have wasted your time
step to test other
@giacomo i was thinking (reading posts on forum) that maybe before go on with tests of installation from iso it’s better to spend some time in test upgrade from 7.4 to 7.5beta
could you like please write the correct upgrade procedure so i will be sure to not make errors, and maybe some others can help us in testing?
