Testing NethServer 7.5.1804 alpha
We can start to test NethServer on the newly available CentOS 7.5.1804 ISO. Just follow this procedure:
@giacomo has backed an ISO!
Download NethServer 7.5.1804 Alpha 2 ISO (993MB) temporary download link :arrow_down:
As alternative, install NethServer on CentOS 7.5.1804 Minimal:
(1) Download and install CentOS-7-x86_64-Minimal-1804.iso from CentOS mirrors
(2) Install nethserver-release:
yum install http://packages.nethserver.org/nethserver/7.5.1804/updates/x86_64/Packages/nethserver-release-7-5.0.2.g2ec7a1c.ns7.noarch.rpm
(3) Require a fixed NethServer release number
echo 7.5.1804 > /etc/yum/vars/nsrelease
(4) Enable nethserver-testing repo, by editing /etc/yum.repos.d/NethServer.repo. Set enabled=1.
(5) Run nethserver-install as usual
(6) Connect to Server Manager
The development of 7.5.1804 is tracked here:
https://github.com/NethServer/dev/milestone/11
This is a screenshot of a fresh NS 7.5, with new “Automatic updates” and “Subscription” menu entries pre-installed!
10 posts were split to a new topic: Is it still Open Source? Are we all beta testers?
I tested the install in a VM and it worked so far. Subscription and Autoupdates are there.
I guess I am too impatient but I could not install nethserver-firewall-base-ui from Software Center or via yum. Other packages are already installable.
Required: nethserver-firewall-base = 3.3.2-1.ns7
Installed: nethserver-firewall-base-3.3.2-1.15.ga382b7d.ns7.noarch (@nethserver-base)
:clap::clap::clap:
same problem here… installation was fine, same problem with firewall but also with other packages like backup or bandwidth. i must disable mirrorlist and enable baseurl in NethServer.repo as it seems not all mirror have 7.5.1804 folder.
after that i can install backup and bandwidth, still problems with firewall
other tests in progress…
for firewall it seems the updated ui package is not available on repo (also if it is)
→ Processing Dependency: nethserver-firewall-base = 3.3.2-1.ns7 for package: nethserver-firewall-base-ui-3.3.2-1.ns7.noarch
—> Package nethserver-firewall-base-ui.noarch 0:3.3.2-1.15.ga382b7d.ns7 will be installed
→ Finished Dependency Resolution
Error: Package: nethserver-firewall-base-ui-3.3.2-1.ns7.noarch (nethserver-updates)
Requires: nethserver-firewall-base = 3.3.2-1.ns7
forcing installation with
yum install http://mirror.nethserver.org/nethserver/7.5.1804/base/x86_64/Packages/nethserver-firewall-base-ui-3.3.2-1.15.ga382b7d.ns7.noarch.rpm
seems to work
Sorry I cannot reproduce it on my VM (no customizations). What I did:
  • Installed updates from Software Center (yellow banner about 7.5 was present)
  • Installed Basic firewall module
Dependencies were resolved correctly. Did you enable nethserver-testing?
With nethserver-testing enabled I get similar error with testing version. I tried it on a fresh VM (no customization). The error occurs after 7.5 install when I wanted to add the firewall-base-ui package.
Required: nethserver-firewall-base = 3.3.2-1.14.g790405e.ns7
There’s “.noarch” missing in required package but the version of the installed package is higher than the required one.
I can confirm: This way it works.
3 posts were split to a new topic: Local LDAP accounts provider fails to install on 7.5.1804 alpha
Alpha packages are in nethserver-testing repo too… We need to (temporarily) enable it in our testing machines.
tnx! i missed it. enabled, i can confirm the problem with nethserver-firewall-ui installation is solved
the strange thing is that i am quite sure i’ve setup nsrelease as you say in first post, but when i checked it was empty :thinking: i’ll try in a new install
edit1: ok retested on a new install.
fixed release number, checked the file (just to be sure :slight_smile: )
enabled testing repo and installed nethserver,
now /etc/yum/vars/nsrelease is still there but is empty
nethserver-testing is still enabled but without rel version yum check against 7.4 repo
edit2: mhhh no there is something else… after setup /etc/yum/vars/nsrelease another time, now is again empty, i’ve just made the first installation wizard
It’s a template, could be overwritten. Echo 7.5.1804 again to it, or prepare a custom-template, like explained here: How to lock to a specific distribution release
nDPI has been reverted to release 1.1.7 because of a major issue.
You can find updated packages in nethserver-testing which should restore a correct behavior.
More info here:
some other install tests:
other packages installed without fail/error:
Backup
Bandwidth monitor
Basic firewall
FTP server
IM-XMPP/Jabber chat server
IPS
MariaDB (MySQL) server
OpenVPN
Print Server
Reverse proxy
SNMP server
Statistics
Web filter
Web proxy
UPS nethserver-nut+collectd-nut
WebTop 5 groupware
Packages with install notes:
Nextcloud (ok but still on version 13.0.1)
Email2: some warnings/error during installation to check (updated after test… retry installation)
pop3 connector 2
pop3 proxy 2
Smtp2
Install of local AD:
systemd-nspawn: Failed to create directory /var/lib/machines/nsdc//sys/fs/selinux: Read-only file system
realmd: Enter Administrator’s password:DNS update failed: NT_STATUS_UNSUCCESSFUL
realmd: DNS Update for ns75f1.framassa.org failed: ERROR_DNS_GSS_ERROR
sssd: tkey query failed: GSSAPI error: Major = Unspecified GSS failure. Minor code may provide more information, Minor = Server not found in Kerberos database.
ns75f1 sssd: tkey query failed: GSSAPI error: Major = Unspecified GSS failure. Minor code may provide more information, Minor = Server not found in Kerberos database.
File Server + Samba audit (with local AD)
May 11 18:36:36 ns75f1 esmith::event[10881]: Can’t open directory /etc/e-smith/events/fstab-update
May 11 18:36:36 ns75f1 esmith::event[10881]: Action: /etc/e-smith/events/nethserver-samba-update/S20nethserver-samba-conf FAILED: 2 [0.314591]
May 11 18:36:39 ns75f1 esmith::event[10881]: Event: nethserver-samba-update FAILED
Note: there is no fstab-update folder…
if i install ns75 without enable testing i have the folder
/etc/e-smith/events/fstab-update/ (package installed nethserver-base-3.1.5-1.ns7.noarch)
if i use testing repo bedore install the package installed is nethserver-base-3.1.5-1.4.gba58ecc.ns7.noarch.rpm and there is no the requeste folder… i’ll check on github…
In Nethserver is available the update to 7.5. It is stable or not?
We are here in the 7.5 alpha testing thread so it’s not stable. The stable 7.5 will be announced…
Thank you for your detailed test @dz00te, it’s a great contribution towards a stable release! I hope to see more people involved in the @quality_team, expecially during transition phases like this!
I have update from Software Center, but in the Dashboard the version is 7.4. I have to reboot the server?
If want to contribute with alpha 7.5 tests run steps 3 and 4 of the initial post. Then run
 yum update
Be prepared to reinstall from scratch or restore a backup/snapshot of your server.
Reboot runs the new kernel but doesn’t change the release number: you need to update from 7.5.1804/testing repo for that.
