some ideas, of course work in progress, if you think I missed some options, please say it
Nice!
(Long outstanding wish that i could never accomplish)
Absolutely great work @stephdl!
For the brave
yum install http://packages.nethserver.org/nethserver/7.5.1804/nethforge-autobuild/x86_64/Packages/nethserver-sogo-1.7.5-1.17.pr30.gf5665b2.ns7.noarch.rpm
new feature :
- make access on exclusive domain name list if specified in the panel (old feature removed but back again). For instance you can say to SOGo to only answer on webmail.domain.com and sogo.domain.com and … Domain name specified are automatically added (and removed) to the self domain name database of NS
- dashboard url is aware of the multiple domaine name configuration (it takes the first)
- Webtop activesync is disabled when active sync is enabled in SOGo (if nethserver-webtop is installed)
- online help (need to be merged)
please take it, break it and comment it
Installed and working like a charm. Great work @stephdl!!!
I like it so much i’ll post the screen-shot again!
Still need to test notifications, all other functionality works !!
Kudos @stephdl
do you think we could make an input field for SOGoMaximumSyncWindowSize ?
yum install http://packages.nethserver.org/nethserver/7.5.1804/nethforge-testing/x86_64/Packages/nethserver-sogo-1.7.5-1.1.g63b1de3.ns7.noarch.rpm
for those who wants to test
- Dav checkbox
- ActiveSync checkbox (if webtop installed then $webtop{‘Activesync’} is set to disabled and nethserver-webtop-update is launched
- MailAuxiliaryUserAccountsEnabled checkbox
- AdminUsers textarea
- Notifications checkbox
- VirtualHost
- WOWorkersCount
- SOGoInternalSyncInterval
all these options must be modified by the UI, and the event nethserver-sogo-update and nethserver-sogo-save must be launched without errors
Did read it solved some issues with it and was looking at config show sogod too:
EDIT: BTW all the changes in the UI are reflected in the config correctly!
config show sogod
sogod=service
ActiveSync=enabled
AdminUsers=admin,even
BackupTime=30 0
Certificate=
CustomEmailField=userPrincipalName
Dav=enabled
DraftsFolder=Drafts
MailAuxiliaryUserAccountsEnabled=YES
Notifications=ACLs,Folders,Appointment,EMail
SOGoInternalSyncInterval=30
SOGoMaximumPingInterval=3540
SOGoMaximumSyncInterval=3540
SOGoMaximumSyncResponseSize=2048
SOGoMaximumSyncWindowSize=100
SentFolder=Sent
SessionDuration=1440
SxVMemLimit=512
TrashFolder=Trash
VirtualHost=sogo.example.com
WOWatchDogRequestTimeout=60
WOWorkersCount=5
status=enabled
Lets invite some extra users @planet_jeroen @hucky @flatspin
which option(s) would you like to have in the pannel?
On vacation this week. Will jump in next week. Looks great. Love it. Can’t wait to test it. Really curious.
Thanks @stephdl ans @mark_nl
Might be a good idea. I’ve had problems with two different Samsung mobiles where the resolution was to tweak this parameter. I’m guessing now but I believe Samsung is quite a popular brand so I presume it’s not just me.
But I cannot assess the effort needed to have such a fid implemented. Perhaps a nice to have and not a must have.
the option I had in mind could solve the problem of few people and can be hazardous if used when all is good…I would prefer to not display it.
when you want to disabled SOGoMaximumSyncWindowSize, set it to zero
I will release it, could you set it to verifed @mark_nl if it is the case
Agree
It’s better to release early and enhance later ![]()
Will do so!
(checked on arm too, with nethserver-mail2
Thanx!)
