Not sure why but on my Dashboard under Stephdl Repository it is showing it to be offline. I am guessing it may be on my side that this is the case since I haven’t heard anyone else saying something about it lately… I believe the last times it was talked about was in the following posts.
Here is a screenshot -
Please let me know what I should check or where I can go to fix issue if you know.
Okay, well after much searching I came upon this post (which explains it all) -
I appreciate what stephdl was able to accomplish with his Stephdl Repository. Thanks Stephdl for your time and effort as it helped and made life easier for me and others like me.
Sad to see the development of it stop… Stephdl Repository was a great setup to allow running WordPress on Nethserver.
Wish stephdl would change his mind on still supporting it. But I understand. You got to do, what you got to do.
Now the only thing I don’t understand it that the dates of the last one I found is from 2015 and the three before this are from 2018, 2019, and 2020… So maybe I am incorrect and Stephdl still supports it???
Can someone verify if Stephdl Repository is still up and working? or is it no longer? Please let me know.
You are correct and observant. Thank you. I have been working in to the wee hours of the morning for the last two days. Not getting much rest. I just noticed the Dashboard said online and the other command gave me less issues, so it seemed and I didn’t look close enough… but I did another test this time paying attention and here is what I got…
