Hi @stephdl
what if I dedided to start learning developing watching your rpm?
@filippo_carletti any advice?
Hi @stephdl
The source is visible on my github account GitHub - stephdl/nethserver-crontabmanager at ns6 however the rpm is maybe a bit complex to understand for a first shoot. I would suggest something more trivial like GitHub - NethServer/nethserver-openssh
I tried but I cannot see the source code, maybe I need to play a little bit more with github.
Suggestion accepted.
Thank you.
be aware that I don’t use the standard build script of NethServer, you must look after the branch ‘ns6’ if you want to see the code in the repository…same for my sme server rpm, master is for sme8, sme9 is for …
Interesting discussion, this may be a hub for every easy question about dev’s good practice. Love it.
