SOGo on Nethserver 7B2
NethServer Version: 7 Beta 2
Module: SOGo
Hi all, I have installed Nethserver 7 Beta 2, to use it mainly as Mail and Collaboration Server. I have installed LDAP, Mail components and SOGo.
My problem is that when I try to connect to http://my.fully.qualified.name/SOGo I have a 404 error, and in effect I cannot see anything under the html directory.
I have probably forgotten something, but what ? Can you help me ?
Thanks
Andrea
Did you install sogo too? :slight_smile:
Yes I did it :slight_smile:
Hi Andrea,
Did you try with https:// ?
yes, I tried both, but in both cases I had a 404
Thanks
Andrea
I can add that if I connect via ssh, I can see SOGo processes running. But /var/www/html dir is empty.
Andrea
Try with IP instead FQDN to see if is a problem with DNS.
it is not a DNS problem, because if I go to http://my.fully.qualified.name I can see the NethServer welcome page and on http://my.fully.qualified.name:980 the server manager.
Thanks
Andrea
What about MX registration?
The email server is mail.fqdn/sogo, or fqdn/sogo?
(sorry, I type from my phone and is not so comfortable)
MX registration is still pointing to the old server. I’m just testing Nethserver and I would like to understand how it works, in particular SOGo and integration with Mobile Phones.
As of now, I’m just trying to connect to the WebInterface.
Thank you for your support.
Andrea
You’re welcome!
Enjoy NS.
You will love it!
Hi Andrea (and @GG_jr),
I chip in for some suggestions, unfortunately i ditched the VM with sogo running just a few hours ago…
So you know your way around the liunx file system, but first i suggest to restart the webserver:
in the UI goto services look for httpd (HTTP) and restart it -or-
from the terminal
systemctl restart httpd
and as we ar at this resart sogo as well: sogod in the UI -or-
systemctl restart sogod
SOGo is not located in /var/www/html but elsewhere.
Thank you Mark. I have restarted both the httpd server and the sogod server. But still I cannot see the webinterface :frowning:
Do I need to have any other component installed to use SOGo ? samba4 or something else ?
Thanks again
Andrea
No, - as always :joy:- it should work.
You can confirm sogod and httpd are running?
Could it be you installed sogo before Ldap?
Yes, I confirm that both the server are running, and also that I installed SOGo before LDAP. Is it an error ?
Andrea
Yeh i think that could be a problem.
We can try to reconfigure SOGo; IIRC:
from the terminal
signal-event nethserver-sogo-update
Tried, but still 404. Maybe I can unistall and reinstall the package ?
Andrea
Before reinstalling could you have a look at
/etc/sogo/sogo.conf
there should be something like this in there:
  /* 45 ldap authentication */
        id = groups;
       type = ldap;
Yes, there are these lines.
But I’m not sure they are fine. I installed samba4, then SOGo, but after that I removed samba and installed LDAP, maybe this created a problem.
Andrea
Sorry have to leave the answer to this to real experts on the this subject :open_mouth:
