NethServer Version: NethServer release 7.7.1908 (final) Module: sogo
suddenly SOGo stopped working. As far as I can tell I didn’t make any modifications to nethserver.
Tried to reboot the system
I can’t get any E-Mail via ActiveSync and when trying to connect to the web interface I get an unknown error.
/etc/sogo/sogo.log:
Jan 10 16:50:49 sogod [29531]: [WARN] <0x0x55eadd90e4d0[WOWatchDogChild]> pid 29533 has been hanging in the same request for 1 minutes
Jan 10 16:51:03 sogod [29531]: [WARN] <0x0x55eadd925bc0[WOWatchDogChild]> pid 29534 has been hanging in the same request for 2 minutes
Jan 10 16:51:25 sogod [29531]: [WARN] <0x0x55eadd926350[WOWatchDogChild]> pid 29535 has been hanging in the same request for 1 minutes
Jan 10 16:51:49 sogod [29531]: [WARN] <0x0x55eadd90e4d0[WOWatchDogChild]> pid 29533 has been hanging in the same request for 2 minutes
Jan 10 16:52:03 sogod [29531]: [WARN] <0x0x55eadd925bc0[WOWatchDogChild]> pid 29534 has been hanging in the same request for 3 minutes
Searching the web says I should increase workers, but I only have 2 Mailboxes. Increasing or decreasing doesn’t help.
tried that, no result.
here some more from the log:
Jan 11 18:04:10 sogod [24944]: [WARN] <0x0x562a50fc17c0[SOGoWebDAVAclManager]> entry ‘{DAV:}write’ already exists in DAV permissions table
Jan 11 18:04:10 sogod [24944]: [WARN] <0x0x562a50fc17c0[SOGoWebDAVAclManager]> entry ‘{DAV:}write-properties’ already exists in DAV permissions table
Jan 11 18:04:10 sogod [24944]: [WARN] <0x0x562a50fc17c0[SOGoWebDAVAclManager]> entry ‘{DAV:}write-content’ already exists in DAV permissions table
Jan 11 18:04:10 sogod [24944]: [ERROR] <0x0x562a50bdd970[WOHttpTransaction]> client disconnected during delivery of response for <WORequest[0x0x562a50bbca00]: method=POST uri=/SOGo/connect app=SOGo rqKey=connect rqPath=(null)> (len=42): the socket was shutdown
Jan 11 18:04:10 sogod [24944]: 192.168.0.138 “POST /SOGo/connect HTTP/1.1” 200 42/59 636.773 - - 9M
I did get some messages that the to much memory was used by sogo.
Can I deinstall sogo and reinstall it?
How about if I am attacked via the internet, that would explain that the heavy load of the workers. I can’t find any evidence for this theory…
Tried some more.
sogo kind of works, but very slow. On one machine I can get mails in outlook, but the web-interface /sogo still gives me undefined error.
Interested: I get the error on the web page and then the log file says I am connected.
I think it is some kind of time-out problem, maybe with http server?
How can I narrow the problem down?
done all that, but no success.
i think it is not so easy.
Sogo kind of works, but just to slow, so the web-interface runs into a time-out.
outlook syncs mails, but it take hours for new mails to sync.
where is the connection between httpd and sogo? maybe there is a problem.
can i reinstall the http integration of sogo???
Thomas
I can read my mails with POP3 and SMTP for sending, that works.
I tried to install webtop, but it didn’t work and i don’t want to destroy my installation.
I think it must be the connection between webserver and sogo.
I’ve tried to check the log files but can’t find any information or errors…
I’ve installed webtop, but the webpage was not reachable. Also I want to keep Outlook and Android as Mail clients and from what I read webtop doesn’t fully support it. I need contacts and calendar…
