Jan 15 21:33:16 diener.mds4u.local systemd[1]: Starting SOGo is a groupware server…
Jan 15 21:33:16 diener.mds4u.local systemd[1]: Started SOGo is a groupware server.
I do get Mails via Activesync on outlook, but very slow, takes half an hour for a mail to show up in outlook. On android I get an error too.
I still think it’s a timeout problem…
Didn’t work, same problem.
I still think it’s not SOGo but the web-server, proxy, ip config or such…
Who wants to get on my server and look for the error?
do not know your starting point, in general this is a bit of a known issue:
If a client has mail (or contacts / appointments) before a activesync connection was setup and the server also contains these items they do not get syschronized. As if the “link” between the item on the client (outlook) and the server does not exist…
Unfortunately have not found a solution for this , other in the line as you did:
make a backup of the ost file
If the items are present on the server start with a new ost file and let activesync/outlook pull in all items
or
If there are no items on the server (new install) start with a new ost file, restore al items from the ost backup and let activesync/outlook push all item to the server.
Also note: You need a valid certificate to let outlook work reasonably smoothly .
I will try, thx, but i still think, that this is an Outlook problem, certificate is valid, letsencrypt. Somethimes with IMAP, at some accounts, i have to repair Office, than works again. Thunderbird had never such a problems
Yes,
Outlook is not very open, in it’s core it is a frontend / client for M$ exchange which stores item as MAPI (no not a typo) objects. However M$ extended quit a lot on this standard making it impossible to provide a alternative mapi-server as backend.
With active-sync one can “glue” outlook to other backends, the only one I found to be really reliable in this setup is Kopano as backend for z-push.
But kopano is a “all in one” solution not an extension for a (nethserver) mail-server.
I am good with Nethserver, till now everything works, and stable. Sometimes can be problems, but not very big. What i miss is only search in backups, works with a new interface, but not very well for Mails.
