SoGo gives a lot of PID timeouts
Just a question about Sogo
It is running good, but i see a lot PID timeout errors in the log
Is this normal ? It look it holds the push mail sometimes for a short period
When i google this it gives me not much info
I tried to expand the workers but this gives no other result
2024-11-14T19:16:20+01:00 [1:sogo1:sogo-app] Nov 14 19:16:20 sogod [7]: [WARN] <0x0x55eb438b36e0[WOWatchDogChild]> pid 113 <mark>has been hanging in the same</mark> request for 6 minutes
2024-11-14T19:16:28+01:00 [1:sogo1:sogo-app] Nov 14 19:16:28 sogod [7]: [WARN] <0x0x55eb438b39b0[WOWatchDogChild]> pid 119 <mark>has been hanging in the same</mark> request for 11 minutes
2024-11-14T19:16:44+01:00 [1:sogo1:sogo-app] Nov 14 19:16:44 sogod [7]: [WARN] <0x0x55eb438d0010[WOWatchDogChild]> pid 120 <mark>has been hanging in the same</mark> request for 4 minutes
2024-11-14T19:17:11+01:00 [1:sogo1:sogo-app] Nov 14 19:17:11 sogod [7]: [WARN] <0x0x55eb4389db20[WOWatchDogChild]> pid 105 <mark>has been hanging in the same</mark> request for 32 minutes
2024-11-14T19:17:20+01:00 [1:sogo1:sogo-app] Nov 14 19:17:20 sogod [7]: [WARN] <0x0x55eb438b36e0[WOWatchDogChild]> pid 113 <mark>has been hanging in the same</mark> request for 7 minutes 2024-11-14T19:17:28+01:00 [1:sogo1:sogo-app] Nov 14 19:17:28 sogod [7]: [WARN] <0x0x55eb438b39b0[WOWatchDogChild]> pid 119 <mark>has been hanging in the same</mark> request for 12 minutes
2024-11-14T19:17:44+01:00 [1:sogo1:sogo-app] Nov 14 19:17:44 sogod [7]: [WARN] <0x0x55eb438d0010[WOWatchDogChild]> pid 120 <mark>has been hanging in the same</mark> request for 5 minutes
2024-11-14T19:18:11+01:00 [1:sogo1:sogo-app] Nov 14 19:18:11 sogod [7]: [WARN] <0x0x55eb4389db20[WOWatchDogChild]> pid 105 <mark>has been hanging in the same</mark> request for 33 minutes
2024-11-14T19:18:20+01:00 [1:sogo1:sogo-app] Nov 14 19:18:20 sogod [7]: [WARN] <0x0x55eb438b5340[WOWatchDogChild]> pid 115 <mark>has been hanging in the same</mark> request for 1 minutes
2024-11-14T19:18:20+01:00 [1:sogo1:sogo-app] Nov 14 19:18:20 sogod [7]: [WARN] <0x0x55eb438b36e0[WOWatchDogChild]> pid 113 <mark>has been hanging in the same</mark> request for 8 minutes
2024-11-14T19:18:28+01:00 [1:sogo1:sogo-app] Nov 14 19:18:28 sogod [7]: [WARN] <0x0x55eb438b39b0[WOWatchDogChild]> pid 119 <mark>has been hanging in the same</mark> request for 13 minutes
2024-11-14T19:19:11+01:00 [1:sogo1:sogo-app] Nov 14 19:19:11 sogod [7]: [WARN] <0x0x55eb4389db20[WOWatchDogChild]> pid 105 <mark>has been hanging in the same</mark> request for 34 minutes
2024-11-14T19:19:20+01:00 [1:sogo1:sogo-app] Nov 14 19:19:20 sogod [7]: [WARN] <0x0x55eb438b5340[WOWatchDogChild]> pid 115 <mark>has been hanging in the same</mark> request for 2 minutes
2024-11-14T19:19:20+01:00 [1:sogo1:sogo-app] Nov 14 19:19:20 sogod [7]: [WARN] <0x0x55eb438b36e0[WOWatchDogChild]> pid 113 <mark>has been hanging in the same</mark> request for 9 minutes
I think it is a normal log messages. Activsync has released the pid
You have some messages more important to track. It could come from a lack of workers
I’ve seen this post and tried it.
Did not make any difference
I made a ticket on the Sogo platform 0006088: WOWatchDogChild pid has been hanging - SOGo | BTS
What is the best way to enable debug mode on Sogo?
SOGoDebugRequests = YES;
I noticed that in the SOGo.conf the timeout=360 and i saw that it is advised to set this to timeout=3600
Has this been set to 360 with a reason ?
How can i change this to survice an update ?
which timeout
this one can be adjusted by an environment variable
Hi Stephane
I mean this setting in SOGo.conf
ProxyPass /Microsoft-Server-ActiveSync \
 http://127.0.0.1:20000/SOGo/Microsoft-Server-ActiveSync \
 retry=60 connectiontimeout=5 timeout=3600
Don’t confuse sogo.conf with SOGo.conf.
Strange to have both the (almost) same names in the same directory
See also other posts on this forum with the setting : timeout=3600
seems a typo of me, we used 3600 with NS7
but the documentation of sSOGo states on 360
https://www.sogo.nu/files/docs/SOGoInstallationGuide.html#_microsoft_enterprise_activesync
https://www.sogo.nu/files/docs/SOGoInstallationGuide.html#_microsoft_enterprise_activesync_tuning
The above line sets a timeout for up to 360 seconds, or 6 minutes. If you want to let EAS clients keep their HTTP connections open for up to an hour, you must change the timeout parameter and set it to 3600.
change it locally in the tempalet and check what it occurs
we set the directive to
SOGOINTERNALSYNCINTERVAL=30
SOGOMAXIMUMPINGINTERVAL=3540
SOGOMAXIMUMSYNCINTERVAL=3540
I think it is safe to push to 3600
I had changed yesterday timeout=3600 and WOWatchDogRequestTimeout = 60 in the template and i experienced today an improvement.
I have released a version with 3600 s of timeout in the reverse proxy
