Sogo couldn't start
NethServer Version: 7.9
Module: Sogo
In Services Sogo show Stopped.
I check sogo status Found it’s fails
systemd[1]: Starting SOGo is a groupware server…
systemd[1]: sogod.service: control process exited, code=killed status=11
systemd[1]: Failed to start SOGo is a groupware server.
systemd[1]: Unit sogod.service entered failed state.
systemd[1]: sogod.service failed.
and out put show
#rpm -qa | grep sogo
sogo-tool-5.8.2-1.ns7.x86_64
nethserver-sogo-1.8.5-1.16.g1eb9c6c.ns7.noarch
sogo-ealarms-notify-5.8.2-1.ns7.x86_64
sogo-5.8.2-1.ns7.x86_64
sogo-activesync-5.8.2-1.ns7.x86_64
#rpm -qa | grep sope
[root@mail ~]# rpm -qa | grep sope
sope49-ldap-4.9-5.8.2.1.ns7.x86_64
sope49-appserver-4.9-5.8.2.1.ns7.x86_64
sope49-core-4.9-5.8.2.1.ns7.x86_64
sope49-gdl1-mysql-4.9-5.8.2.1.ns7.x86_64
sope49-cards-5.8.2-1.ns7.x86_64
sope49-gdl1-4.9-5.8.2.1.ns7.x86_64
sope49-gdl1-contentstore-5.8.2-1.ns7.x86_64
sope49-mime-4.9-5.8.2.1.ns7.x86_64
sope49-xml-4.9-5.8.2.1.ns7.x86_64
sope49-sbjson-2.3.1-5.8.2.1.ns7.x86_64
In Database I can found sogo
Please advise what should I future check.
Thanks
UPDATE
In Cockpid UI Application Configuration, I press Save there is Error Show
Error
The settings have not well updated
The following command has failed:
nethserver-sogo/update
Unfortunately we couldn’t catch the exact error. If you want to help, please click on the button below to copy the failed command to the clipboard, paste it into the Terminal and submit command output to the developers.
Did you gave that a try?
Hello Reply as following
[root@mail ~]# echo ‘{“action”:“configuration”,“status”:“enabled”,“ActiveSync”:“enabled”,“Dav”:“enabled”,“webAccess”:“public”,“AdminUsers”:“admin”,“VirtualHost”:“”,“WOWorkersCount”:“10”,“SOGoInternalSyncInterval”:“30”,“Notifications”:“Appointment,EMail”,“MailAuxiliaryUserAccountsEnabled”:“YES”}’ | /usr/bin/setsid /usr/bin/sudo /usr/libexec/nethserver/api/nethserver-sogo/update | jq
“steps”: 10,
“pid”: 5374,
“args”: “”,
“event”: “nethserver-sogo-update”
“step”: 1,
“pid”: 5374,
“action”: “S00initialize-default-databases”,
“event”: “nethserver-sogo-update”,
“state”: “running”
“progress”: “0.10”,
“time”: “0.186468”,
“exit”: 0,
“state”: “done”,
“step”: 1,
“pid”: 5374,
“step”: 2,
“pid”: 5374,
“action”: “S05generic_template_expand”,
“state”: “running”
“progress”: “0.20”,
“time”: “0.098845”,
“exit”: 0,
“state”: “done”,
“step”: 2,
“pid”: 5374,
“step”: 3,
“pid”: 5374,
“action”: “S10nethserver-sogo-mysqlsetup”,
“state”: “running”
“progress”: “0.30”,
“time”: “0.006666”,
“exit”: 0,
“state”: “done”,
“step”: 3,
“pid”: 5374,
“step”: 4,
“pid”: 5374,
“action”: “S20nethserver-sogo-gnustepsetup”,
“state”: “running”
“progress”: “0.40”,
“time”: “0.00151”,
“exit”: 0,
“state”: “done”,
“step”: 4,
“pid”: 5374,
“step”: 5,
“pid”: 5374,
“action”: “S30nethserver-sogo-MigrationV3.2.10ToV4.0.0”,
“state”: “running”
“progress”: “0.50”,
“time”: “2.989862”,
“exit”: 0,
“state”: “done”,
“step”: 5,
“pid”: 5374,
“step”: 6,
“pid”: 5374,
“action”: “S31nethserver-sogo-MigrationV5.3.0ToV5.6.0”,
“state”: “running”
“progress”: “0.60”,
“time”: “0.010215”,
“exit”: 0,
“state”: “done”,
“step”: 6,
“pid”: 5374,
“step”: 7,
“pid”: 5374,
“action”: “S40nethserver-sogo-create-selfHost”,
“state”: “running”
“progress”: “0.70”,
“time”: “1.757792”,
“exit”: 0,
“state”: “done”,
“step”: 7,
“pid”: 5374,
“step”: 8,
“pid”: 5374,
“action”: “S50nethserver-sogo-disable-webtop-activesync”,
“state”: “running”
“progress”: “0.80”,
“time”: “0.031458”,
“exit”: 0,
“state”: “done”,
“step”: 8,
“pid”: 5374,
“step”: 9,
“pid”: 5374,
“action”: “S60nethserver-sogo-remove-slice-messages”,
“state”: “running”
“progress”: “0.90”,
“time”: “0.001633”,
“exit”: 0,
“state”: “done”,
“step”: 9,
“pid”: 5374,
“step”: 10,
“pid”: 5374,
“action”: “S90adjust-services”,
“state”: “running”
“progress”: “1.00”,
“time”: “0.945561”,
“exit”: 256,
“state”: “done”,
“step”: 10,
“pid”: 5374,
“pid”: 5374,
“status”: “failed”,
“type”: “EventError”,
“id”: 1684918557,
“message”: “update_action_failed”
[root@mail ~]#
I feel like no one help, and I’m sad.
Did you agree?
Hi @i_combo,
may be @stephdl is the right man for your problem.
Regards…
Uwe
It seems you’re using a testing version, most recent is 1.8.6.
Did you try to update in Software Center or on command line by executing
yum update
If that’s not working, could you please share the relevant log entries of /var/log/messages and /var/log/sogo/sogo.log
Maybe a complete reinstallation could help (deletes all sogo data):
You should also go to /var/log/messages and sogo logs and report us what are the exact failure messages. Without details we cannot help
Dear Markus
yes it is sogo 1.8.5. Can I uninstall and reinstall to 1.8.6?
I’m using Nethserver Enterprise ver 7.9.2009. look like SoGo do not have link to install.
yum update : No packages marked for update
In /var/log/messages I found
kernel: sogo-ealarms-no[21775]: segfault at 7ffd0bf19a78 ip 00007f250f55a9cf sp 00007ffd0bf19a60 error 6 in libgnustep-base.so.1.24.9[7f250f1c8000+4dc000]
But there is nothing in /var/log/sogo/sogo.log
For your uninstall guide, I’ll try after working hour.
Thanks and Best Regards,
Maybe this post may help a bit:
https://bugs.sogo.nu/view.php?id=5074
Yes but you will loose the data when you do the full reinstall method.
Sogo is provided by Nethforge repo, maybe you need to enable it?
yum --enablerepo=nethforge install nethserver-sogo
BTW, Sogo isn’t supported in Nethserver Enterprise but it should be possible to install I think.
See also SOGo — NethServer 7 Final
Dear Markuz, Stephdl
Regarding your instruction about Uninstall and Reinstall (SOGo does not start - segfault error 6 in libgnustep-base - #10 by stephdl)
I do separate into 12 Session and your 2 important remarks
Session 1:
yum remove sogo* sope* gnustep* libwbxml* lasso* libobjc* libwbxml* memcached* nethserver-memcached* xmlsec1* xmlsec1-openssl* zip* -y
Session 2:
SYSTEMD_LOG_TARGET=console SYSTEMD_LOG_LEVEL=debug /usr/bin/systemd-tmpfiles --remove
Session 3:
SYSTEMD_LOG_TARGET=console SYSTEMD_LOG_LEVEL=debug /usr/bin/systemd-tmpfiles --clean
Session 4 to 10
rm -rf /etc/sogo/
rm -rf /usr/lib64/GNUstep/
rm -rf /etc/rsyslog.d/ignore-systemd-session-slice-sogo.conf
rm -rf /var/lib/sogo/GNUstep
rm -rf /usr/lib64/sogo
rm -rf /etc/sysconfig/sogo.rpmsave
rm -rf /etc/e-smith/events/nethserver-sogo-update
Session 11:
reboot
Session 12:
yum install nethserver-sogo
Mine is Enterprise version then enable nethforge repo with install
[root@mail ~]# yum --enablerepo=nethforge install nethserver-sogo
Before remark I see /var/log/message shown
May 26 23:31:28 mail systemd: Starting SOGo is a groupware server…
May 26 23:31:28 mail sogod: 2023-05-26 23:31:28.556 sogod[4153:4153] unable to get status of descriptor 2 - Bad file descriptor
And Web UI also show :
Service Unavailable - (Server temporarily unable to service …)
Below is needed.
Remark 1:
chown sogo:sogo -R /var/log/sogo/
Remark 2:
signal-event nethserver-sogo-update
Then Sogo now available to operate.
Thank you for your great suggestion. All work for me.
i_combo
Thank you for your patience and detailed feedback!
