stephdl
(Stéphane de Labrusse)
June 20, 2023, 2:06pm
1
New version of SOGo to test, upgrade seems fine on my server
see Release SOGo v5.8.3 · Alinto/sogo · GitHub
see Release SOGo-5.8.4 · Alinto/sogo · GitHub
yum update --enablerepo=nethforge-testing sope49* sogo* ytnef*
or for first install
yum install --enablerepo=nethforge-testing nethserver-sogo
royceb
(Royce)
June 26, 2023, 1:12am
3
In place update worked without issue. Nothing to report so far.
key_six
(Key Six)
June 29, 2023, 8:34am
4
sogo is realy great. i wanted to install it but it says :
input: yum install --enablerepo=nethforge-testing nethserver-sogo
Output: unkown package source
is there already a date when it should be available in the official package manager?
stephdl
June 29, 2023, 8:45am
5
Are you with en enteprise version ?
yum install nethserver-sogo --enablerepo=nethforge
key_six
(Key Six)
June 29, 2023, 10:14am
6
no only the community.
same output with “nethforge” rep is unkown. i use a clean install with new centos 9
stephdl
June 29, 2023, 10:16am
7
Check the nethserver repository are enabled or available
key_six
(Key Six)
June 29, 2023, 12:02pm
8
jes i activate the testing rep. but same error.
a question aside from sogo. the new gui makes a nice first impression and seems very simple. almost too simple, i can’t find the dhcp server for example !?
dnutan
(Marc)
June 29, 2023, 1:16pm
9
The update is for NethServer 7, not for NS8.
I hope for the stable version of NS8 you will have SOGo, I have plenty other jobs, like debian12 and crowdsec, but when time will be available then we will have SOGo
I use SOGo at home even if I know that a lot of people love to use webtop
