Hi folks
Minor upgrade of sogo to the version 4.0.7, check the announcements and changelog
yum update sogo\* sope\* --enablerepo=nethforge-testing
Should be safe enough, my server has survived
Please test and report before we release to nethforge
Hi folks
As desired here a short status:
a) Installaion went through without problems
b) Web interface works
c) CalDav and CardDav works
d) Calendar perfect!
It seems to me that the calendar runs much smoother than under the 4.06, but that’s my personal impression.
Everything works and works without recognizable errors!
Works very smooth ! THX
Update worked smooth and without issue.
I have the same impression as @gerald_FS, that the webinterface runs more responsive than before.
Thanks a lot for your work Stephane!!
