Now i am finished with the homework. My wife is happy.
I have now set it with the command above. And I feel itâs running a little faster. But itâs only a feeling.
Regards
Uwe
Regards
Uwe
I played with the official demo of sogo and there is a delay also when you change from the mail panel and the calendar/contact panel.
I will release a new rpm and increase this value
please can you update from nethforge-testing, firstly go back to the original setting
config setprop sogod WOWorkersCount 3
signal-event nethserver-sogo-update
verify that you can see the value â3â
config show sogod
then update the rpm
yum update --enablerepo=nethforge-testing nethserver-sogo
and verify that the new value is equal to â10â
config show sogod
thank
after the command âyum update --nethforge-testing nethserver-sogoâ i received this error:
Command line error: no such option: --nethforge-testing.
Regards and a nice SundayâŠ
Uwe
my bad it was late :â(
Ok,
here comes the result of config show sogod:
config show sogod
sogod=service
ActiveSync=enabled
AdminUsers=admin
Certificate=
Dav=enabled
DraftsFolder=Drafts
MailAuxiliaryUserAccountsEnabled=YES
Notifications=Appointment,EMail
SOGoInternalSyncInterval=10
SOGoMaximumPingInterval=10
SOGoMaximumSyncInterval=30
SOGoMaximumSyncResponseSize=2048
SOGoMaximumSyncWindowSize=100
SentFolder=Sent
SxVMemLimit=512
TrashFolder=Trash
VirtualHost=
WOWatchDogRequestTimeout=10
WOWorkersCount=10
status=enabled
I thought this night that we should start a wiki documentation page on sogo. Why ?. Because when you install Sogo it is destinated for a personnal use, but when you want to work you need to increase a lot of values in db.
For example, you need one worker per activesync connection, you have tricks also for fine tune https://sogo.nu/files/docs/SOGoInstallationGuide.html#_microsoft_enterprise_activesync_tuning
thank, released
My feeling about the speed is as before. Something faster but not as fast as neighborâs cat.
yes, I tested the official sogo demo, and I feel a bit faster than on my LAN, but not so much. Can you have a go ?
We could maybe increase to 15 workersâŠ
definitively sogo2 is faster than sogo3
Stephane,
I have a problem to properly understand the term worker.
What do you mean with that? Is this a real person who has a SOGo account on the server?
a worker is like a thread, more you have users (at the same time), more you need workers.
activesync needs one worker per user
the web UI is less consumer
Does it make a difference whether the account provider is LDAP or Samba4?
sogo2 is almost a plain html app
sogo3 is not⊠itâs something heavily based on js on client side⊠the slowness is not on the server side, but on the client one, due to rendering the pageâŠ
anyway, I have a 220 user install with 10 GB ram⊠at least 150 concurrent users, all in lan, but even from remote (the server is about 900km from here) the web interface is fast enough to work
if you (generally speaking) need something really faster, a web interface is not an option, use a client
I donât think so. To be honest Iâm stuck on sogo2⊠I donât like changes, I still have the same wife after 17 years.
I can build sogo2 also, we can let the choice to the sysadmin
There is also a problem with the contacts. When I create a new contact, I do not see it in the contact list after saving it. Only when I log out and then log in again, the contact is visible.
I also have the attitude. 14 years withe the same wife, and 26 years with the same car.![]()
Hi Stefano,
this is absolutly right. I have two All in One Computers here. One with Nvidia Graphic Card and the older one only with an Intel Graphik Chip on the Mainboard. When i visit the SOGo site withe the first one, itâs much faster.
Regards
Uwe
seems an issue on your side⊠doesnât happen here
