Moin Ralf,
I have tried here Nethserver 7.3 Final with SOGo 3.2.6a as VM and also on the described real hardware. The described behavior is the same for both variants.
Regards
Uwe
Moin Ralf,
Regards
Uwe
Hi Uwe,
Sorry, maybe my post was unclear. My VM is also a NS7-final installation migrated from RC4.1 with SOGo 3.2.6a. I use virtualbox on the TX100S3 with NS6.8 installed.
What migration path do you have?
Hi Ralf,
i have the same Migration path. I will test now with a fresh Final on my Hyper V 2008 R2.
Sogo released in nethforge, you should not need anymore to restart the sogod service, the process is automatic.
sogo 3.2.6a on a vm with 10 GB of ram and 220 users⊠no issue⊠please be sure not to have squid/proxy enabled
sogo-3.2.7 in nethforge-testing
yum install nethserver-sogo --enablerepo=nethforge-testing
yum update sogo\* sope\* --enablerepo=nethforge-testing
Thatâs a great news. Ehi @transocean @quality_team @hucky @mark_nl @asl @frx44 could you help that guy?
No problem. I will test it tomorrow with a fresh installation of NS7 Final on my Hyper-V Server.
Regards
Uwe
have update it yesterday and it seems ok
Hi @ all,
I installed NS 7 as a virtual machine with four virtual processors and 8 GB RAM. As an account provider, I use LDAP. SOGo in version 3.2.7 runs on the virtual machine as a brand new installation. Everything looks good and seems to work well. But I have as before a problem with the speed of SOGo. In my opinion it works too slowly.
When switching between calendar and mail, it sometimes takes up to five seconds for the system to respond. This did not exist in the earlier SOGo version (2 âŠ) on a NS 6.8 machine.
I have NS7 final installed on a physical machine. AccountProvider is LDAP. Mail done Roundcube. And for sharing, Nextcloud works. The system is in the DMZ and does a good job. Originally, I had planned to replace Roundcube with SOGo. At the moment I do not want to do this because SOGo is too slow for me.
Here in the forum, a user has expressed the idea to use HORDE Groupware instead of SOGo. A suggestion that I like very much. I had before Nethserver beside my Windows servers also always a SME server, which has worked with HORDE Groupware. This was a very reliable matter. Unfortunately I miss the Linux experience. Otherwise, I would like to try as a test system.
Regards and a nice weekendâŠ
Uwe
I suppose a brand new with nothing at all ?
I can reproduce it but my machine gets some rpm installed (java with madsonic, samba ADâŠ)
itâs a quite complex web app⊠5 seconds are acceptable⊠there are webmail that are slower out there
and you canât compare sogo2 with sogo3, they just share the name
Yes.
I nowâŠ
for a matter of tests, can you play with prefork value in
vim /etc/sysconfig/sogo
increase it, about 15, 20, 30âŠ
restart the service
systemctl restart sogod
I have the feeling that it is better :-?
in fact the good command is
config setprop sogod WOWorkersCount 30
signal-event nethserver-sogo-update
Okay,
i will test it later. Just now my wife is calling. I have to do some work here in the house.
good luck, my wife is behind my back today
Have fun - women love shopping
It happend, because you didnât have enough workers for the rush.
For such rush traffic you also could increase WOListenQueueSize.
This tells sogod to queue up that count of requests for its workers.
This will not decrease your workload, but clients are not rejected
instantly, when no worker is available.You do not need to kill those workers by yourself.
Instead you can decrease WOWatchDogRequestTimeout (in minutes) which is
set to 10 minutes by default.
Then the SOGo WatchDog will kill those processes for you.Your RAM should be approx.:
worker count * SxVMemLimit (which is in MB)In your case 20 * 384 MB = 7680 MB (~ 8GB)
With 20 workers you should be able to handle all 200 users, as long as
they use web interface and/or calDAV/cardDAV.If you have ActiveSync users, you have to reserve one worker per
ActiveSync connection!Kind regards,
Christian Mack
an interesting link https://lists.inverse.ca/sogo/arc/users/2015-09/msg00196.html
