NethServer Version: System version NethServer release 7.5.1804 (final)
Kernel release 3.10.0-862.14.4.el7.x86_64
Module: see below
Hello,
I do have again an issue with SW Upgrade and showing SW modules at the Software Center
Following pacakges are installed.
[root@homeserver1 ~]# rpm -qa | grep nethserver
nethserver-nextcloud-1.2.7-1.ns7.noarch
nethserver-mail-disclaimer-2.3.2-1.ns7.noarch
nethserver-lang-en-1.2.16-1.ns7.noarch
nethserver-webtop5-1.2.13-1.ns7.noarch
nethserver-httpd-3.2.7-1.ns7.noarch
nethserver-httpd-virtualhosts-3.2.7-1.ns7.noarch
nethserver-httpd-admin-2.3.4-1.ns7.noarch
nethserver-cgp-2.1.3-1.ns7.noarch
nethserver-mail-getmail-2.3.2-1.ns7.noarch
nethserver-base-3.5.2-1.ns7.noarch
nethserver-phonehome-1.3.0-1.ns7.noarch
nethserver-smartd-1.1.0-1.ns7.noarch
nethserver-lib-2.2.9-1.ns7.noarch
nethserver-libvirt-1.1.0-1.ns7.noarch
nethserver-mail-p3scan-2.3.2-1.ns7.noarch
nethserver-mail-smarthost-2.3.2-1.ns7.noarch
nethserver-firewall-base-ui-3.4.3-1.ns7.noarch
nethserver-yum-1.4.1-1.ns7.noarch
nethserver-release-7-8.ns7.noarch
nethserver-duc-1.4.5-1.ns7.noarch
nethserver-dnsmasq-1.6.7-1.ns7.noarch
nethserver-net-snmp-1.1.0-1.ns7.noarch
nethserver-sssd-1.4.4-1.ns7.noarch
nethserver-rh-php71-php-fpm-1.0.0-1.ns7.noarch
nethserver-memcached-1.1.0-1.ns7.noarch
nethserver-postgresql-1.1.0-1.ns7.noarch
nethserver-rh-php56-php-fpm-1.0.0-1.ns7.noarch
nethserver-mail-server-2.3.2-1.ns7.noarch
nethserver-nut-1.3.2-1.ns7.noarch
nethserver-mail-filter-2.3.2-1.ns7.noarch
nethserver-firewall-base-3.4.3-1.ns7.noarch
nethserver-unbound-1.1.0-1.ns7.noarch
nethserver-unixODBC-1.0.0-1.ns7.noarch
nethserver-hosts-1.2.2-1.ns7.noarch
nethserver-letsencrypt-1.1.6-1.ns7.noarch
nethserver-ntp-1.1.3-1.ns7.noarch
nethserver-mail-common-2.3.2-1.ns7.noarch
nethserver-lang-it-1.2.16-1.ns7.noarch
nethserver-antivirus-1.2.1-1.ns7.noarch
nethserver-mysql-1.1.4-1.ns7.noarch
nethserver-httpd-proxypass-3.2.7-1.ns7.noarch
nethserver-nethforge-release-7-2.ns7.noarch
nethserver-diagtools-1.0.3-1.ns7.noarch
nethserver-php-1.2.0-1.ns7.noarch
nethserver-restore-data-1.2.5-1.ns7.noarch
nethserver-backup-config-2.2.1-1.ns7.noarch
nethserver-lsm-1.2.3-1.ns7.noarch
nethserver-sogo-1.7.7-1.ns7.noarch
nethserver-vsftpd-1.1.1-1.ns7.noarch
nethserver-collectd-3.0.7-1.ns7.noarch
nethserver-directory-3.3.1-1.ns7.noarch
nethserver-backup-data-1.4.3-1.ns7.noarch
nethserver-openssh-1.2.2-1.ns7.noarch
At SoftwareCenter the indication of SW updates is given.
However,
I do not see any list of other available packages
I do not see correct list of installed packages
When I try to “Download and Install” the indication that YUM cache should be cleaned is given.
After trying to “Download and Install” the message to clear the YUM cache is given:
After trying to clear the YUM Cache no available update is shown and it looks like the updates have been installed.
However comparing the packages before and after the upgrade I see no difference (when pushing the “package” button in the “Installed” Tab)
/var/log/messages shows following logs - not sure if they are related:
Feb 25 21:38:02 homeserver1 dbus[672]: [system] Rejected: destination has a full message queue, 0 matched rules; type=“signal”, sender="(unset)" ((bus)) interface=“org.freedesktop.DBus” member=“NameOwnerChanged” error name="(unset)" requested_reply=“0” destination=“org.freedesktop.DBus” (uid=995 pid=681 comm="/usr/bin/perl /usr/libexec/nethserver/smwingsd “)
Feb 25 21:38:02 homeserver1 systemd: Starting Session 245623 of user sogo.
Feb 25 21:38:02 homeserver1 dbus[672]: [system] Rejected: destination has a full message queue, 0 matched rules; type=“signal”, sender=”(unset)" ((bus)) interface=“org.freedesktop.DBus” member=“NameOwnerChanged” error name="(unset)" requested_reply=“0” destination=“org.freedesktop.DBus” (uid=995 pid=681 comm="/usr/bin/perl /usr/libexec/nethserver/smwingsd “)
Feb 25 21:38:05 homeserver1 dbus[672]: [system] Rejected: destination has a full message queue, 0 matched rules; type=“signal”, sender=”(unset)" ((bus)) interface=“org.freedesktop.DBus” member=“NameOwnerChanged” error name="(unset)" requested_reply=“0” destination=“org.freedesktop.DBus” (uid=995 pid=681 comm="/usr/bin/perl /usr/libexec/nethserver/smwingsd “)
Feb 25 21:38:05 homeserver1 systemd: Removed slice User Slice of sogo.
Feb 25 21:38:05 homeserver1 systemd: Stopping User Slice of sogo.
Feb 25 21:38:06 homeserver1 dbus[672]: [system] Rejected: destination has a full message queue, 0 matched rules; type=“signal”, sender=”(unset)" ((bus)) interface=“org.freedesktop.DBus” member=“NameOwnerChanged” error name="(unset)" requested_reply=“0” destination=“org.freedesktop.DBus” (uid=995 pid=681 comm="/usr/bin/perl /usr/libexec/nethserver/smwingsd ")
Any hint what could here be the issue?
Many thanks for your help!
Regards
