Hello, I yesterday updated my NS8 machine that is running just Samba with AD services.
Now after restarting the VM (Rocky Linux) I get these logs in NS8 UI. The container starts and runs well, it just takes multiple retries for it to start. Anyone experiencing similar issue?
2025-08-20T03:06:06+03:00 [1:samba1:systemd] Started D-Bus User Message Bus.
2025-08-20T03:06:06+03:00 [1:samba1:] Ready
2025-08-20T03:06:06+03:00 [1:samba1:systemd] Created slice Slice /user.
2025-08-20T03:06:06+03:00 [1:samba1:systemd] libpod-43b52b70608152ebcb29f2e54a3b98fbf0b3c49ad862acba8b9cb6b27281827e.scope: unit configures an IP firewall, but not running as root.
2025-08-20T03:06:06+03:00 [1:samba1:systemd] (This warning is only shown for the first unit using IP firewalling.)
2025-08-20T03:06:06+03:00 [1:samba1:systemd] Started libcrun container.
2025-08-20T03:06:06+03:00 [1:samba1:podman] 43b52b70608152ebcb29f2e54a3b98fbf0b3c49ad862acba8b9cb6b27281827e
2025-08-20T03:06:06+03:00 [1:samba1:systemd] Started podman-pause-13686a14.scope.
2025-08-20T03:06:06+03:00 [1:samba1:systemd] Started TimescaleDB for Samba Audit logs.
2025-08-20T03:06:06+03:00 [1:samba1:systemd] Starting Samba DC and File Server...
2025-08-20T03:06:06+03:00 [1:samba1:timescaledb]
2025-08-20T03:06:06+03:00 [1:samba1:timescaledb] PostgreSQL Database directory appears to contain a database; Skipping initialization
2025-08-20T03:06:06+03:00 [1:samba1:timescaledb] 2025-08-20 00:06:06.608 UTC [1] LOG: starting PostgreSQL 17.5 on x86_64-pc-linux-musl, compiled by gcc (Alpine 14.2.0) 14.2.0, 64-bit
2025-08-20T03:06:06+03:00 [1:samba1:timescaledb] 2025-08-20 00:06:06.608 UTC [1] LOG: listening on IPv4 address "0.0.0.0", port 15432
2025-08-20T03:06:06+03:00 [1:samba1:timescaledb] 2025-08-20 00:06:06.608 UTC [1] LOG: listening on IPv6 address "::", port 15432
2025-08-20T03:06:06+03:00 [1:samba1:timescaledb] 2025-08-20 00:06:06.616 UTC [1] LOG: listening on Unix socket "/var/run/postgresql/.s.PGSQL.15432"
2025-08-20T03:06:06+03:00 [1:samba1:timescaledb] 2025-08-20 00:06:06.630 UTC [24] LOG: database system was shut down at 2025-08-20 00:05:34 UTC
2025-08-20T03:06:06+03:00 [1:samba1:timescaledb] 2025-08-20 00:06:06.661 UTC [1] LOG: database system is ready to accept connections
2025-08-20T03:06:06+03:00 [1:samba1:systemd] Started API Module Daemon (AMLD).
2025-08-20T03:06:06+03:00 [1:samba1:timescaledb] 2025-08-20 00:06:06.670 UTC [27] LOG: TimescaleDB background worker launcher connected to shared catalogs
2025-08-20T03:07:37+03:00 [1:samba1:systemd] samba-dc.service: start operation timed out. Terminating.
2025-08-20T03:07:37+03:00 [1:samba1:systemd] samba-dc.service: Control process exited, code=exited, status=1/FAILURE
2025-08-20T03:07:37+03:00 [1:samba1:podman] c45aa4ef209f5edc0d786170c90d34ecf88e5be9587f176913cf760ae74ce632
2025-08-20T03:07:37+03:00 [1:samba1:systemd] samba-dc.service: Failed with result 'timeout'.
2025-08-20T03:07:37+03:00 [1:samba1:systemd] Failed to start Samba DC and File Server.
2025-08-20T03:07:37+03:00 [1:samba1:systemd] samba-dc.service: Consumed 9.931s CPU time.
2025-08-20T03:07:37+03:00 [1:samba1:systemd] Reached target Main User Target.
2025-08-20T03:07:37+03:00 [1:samba1:systemd] Startup finished in 1min 31.432s.
2025-08-20T03:07:38+03:00 [1:samba1:systemd] samba-dc.service: Scheduled restart job, restart counter is at 1.
2025-08-20T03:07:38+03:00 [1:samba1:systemd] Stopped Samba DC and File Server.
2025-08-20T03:07:38+03:00 [1:samba1:systemd] samba-dc.service: Consumed 9.931s CPU time.
2025-08-20T03:07:38+03:00 [1:samba1:systemd] Starting Samba DC and File Server...
2025-08-20T03:08:07+03:00 [1:samba1:systemd] Starting Mark boot as successful...
2025-08-20T03:08:07+03:00 [1:samba1:systemd] Finished Mark boot as successful.
2025-08-20T03:09:08+03:00 [1:samba1:systemd] samba-dc.service: start operation timed out. Terminating.
2025-08-20T03:09:08+03:00 [1:samba1:systemd] samba-dc.service: Control process exited, code=exited, status=1/FAILURE
2025-08-20T03:09:08+03:00 [1:samba1:podman] 9ba393ac0f78f2c84057fa2b9013574b7601c1e2584ad0b2d6cc89ff8f9d9ee0
2025-08-20T03:09:08+03:00 [1:samba1:systemd] samba-dc.service: Failed with result 'timeout'.
2025-08-20T03:09:08+03:00 [1:samba1:systemd] Failed to start Samba DC and File Server.
2025-08-20T03:09:08+03:00 [1:samba1:systemd] samba-dc.service: Consumed 9.970s CPU time.
2025-08-20T03:09:08+03:00 [1:samba1:systemd] samba-dc.service: Scheduled restart job, restart counter is at 2.
2025-08-20T03:09:08+03:00 [1:samba1:systemd] Stopped Samba DC and File Server.
2025-08-20T03:09:08+03:00 [1:samba1:systemd] Starting Samba DC and File Server...
2025-08-20T03:09:53+03:00 [1:samba1:systemd] Started libcrun container.
2025-08-20T03:09:53+03:00 [1:samba1:podman] 33516dbb6c6328446240ba7a440b1bb2fae2987b60b023ec306b14aa2d063f37
2025-08-20T03:09:53+03:00 [1:samba1:bash] /usr/bin/bash: connect: Connection refused
2025-08-20T03:09:53+03:00 [1:samba1:bash] /usr/bin/bash: line 1: /dev/tcp/10.44.1.4/53: Connection refused
2025-08-20T03:09:54+03:00 [1:samba1:samba-dc] # Global parameters
2025-08-20T03:09:54+03:00 [1:samba1:samba-dc] [global]
2025-08-20T03:09:54+03:00 [1:samba1:samba-dc] bind interfaces only = Yes
2025-08-20T03:09:54+03:00 [1:samba1:samba-dc] interfaces = 127.0.0.1 xxx.xxx.xxx.xxx
2025-08-20T03:09:54+03:00 [1:samba1:samba-dc] ldap server require strong auth = No
2025-08-20T03:09:54+03:00 [1:samba1:samba-dc] ntlm auth = mschapv2-and-ntlmv2-only
2025-08-20T03:09:54+03:00 [1:samba1:samba-dc] obey pam restrictions = Yes
2025-08-20T03:09:54+03:00 [1:samba1:samba-dc] passdb backend = samba_dsdb
2025-08-20T03:09:54+03:00 [1:samba1:samba-dc] realm = AD.XXX.LOCAL
2025-08-20T03:09:54+03:00 [1:samba1:samba-dc] registry shares = Yes
2025-08-20T03:09:54+03:00 [1:samba1:samba-dc] server role = active directory domain controller
2025-08-20T03:09:54+03:00 [1:samba1:samba-dc] template homedir = /srv/homes/%U
2025-08-20T03:09:54+03:00 [1:samba1:samba-dc] workgroup = XXX
2025-08-20T03:09:54+03:00 [1:samba1:samba-dc] rpc_server:tcpip = no
2025-08-20T03:09:54+03:00 [1:samba1:samba-dc] rpc_daemon:spoolssd = embedded
2025-08-20T03:09:54+03:00 [1:samba1:samba-dc] rpc_server:spoolss = embedded
2025-08-20T03:09:54+03:00 [1:samba1:samba-dc] rpc_server:winreg = embedded
2025-08-20T03:09:54+03:00 [1:samba1:samba-dc] rpc_server:ntsvcs = embedded
2025-08-20T03:09:54+03:00 [1:samba1:samba-dc] rpc_server:eventlog = embedded
2025-08-20T03:09:54+03:00 [1:samba1:samba-dc] rpc_server:srvsvc = embedded
2025-08-20T03:09:54+03:00 [1:samba1:samba-dc] rpc_server:svcctl = embedded
2025-08-20T03:09:54+03:00 [1:samba1:samba-dc] rpc_server:default = external
2025-08-20T03:09:54+03:00 [1:samba1:samba-dc] winbindd:use external pipes = true
2025-08-20T03:09:54+03:00 [1:samba1:samba-dc] recycle:versions = yes
2025-08-20T03:09:54+03:00 [1:samba1:samba-dc] recycle:keeptree = yes
2025-08-20T03:09:54+03:00 [1:samba1:samba-dc] recycle:repository =
2025-08-20T03:09:54+03:00 [1:samba1:samba-dc] full_audit:failure = none
2025-08-20T03:09:54+03:00 [1:samba1:samba-dc] full_audit:success = none
2025-08-20T03:09:54+03:00 [1:samba1:samba-dc] full_audit:priority = INFO
2025-08-20T03:09:54+03:00 [1:samba1:samba-dc] full_audit:facility = LOCAL7
2025-08-20T03:09:54+03:00 [1:samba1:samba-dc] full_audit:prefix = %R|%I|%u|%S
2025-08-20T03:09:54+03:00 [1:samba1:samba-dc] acl_xattr:ignore system acls = yes
2025-08-20T03:09:54+03:00 [1:samba1:samba-dc] acl_xattr:security_acl_name = user.NTACL
2025-08-20T03:09:54+03:00 [1:samba1:samba-dc] idmap config * : backend = tdb
2025-08-20T03:09:54+03:00 [1:samba1:samba-dc] include = /etc/samba/include.conf
2025-08-20T03:09:54+03:00 [1:samba1:samba-dc] inherit owner = windows and unix
2025-08-20T03:09:54+03:00 [1:samba1:samba-dc] map archive = No
2025-08-20T03:09:54+03:00 [1:samba1:samba-dc] vfs objects = dfs_samba4 acl_xattr recycle full_audit
2025-08-20T03:09:54+03:00 [1:samba1:samba-dc] [sysvol]
2025-08-20T03:09:54+03:00 [1:samba1:samba-dc] inherit owner = no
2025-08-20T03:09:54+03:00 [1:samba1:samba-dc] path = /var/lib/samba/sysvol
2025-08-20T03:09:54+03:00 [1:samba1:samba-dc] read only = No
2025-08-20T03:09:54+03:00 [1:samba1:samba-dc] acl_xattr:ignore system acls = no
2025-08-20T03:09:54+03:00 [1:samba1:samba-dc] [netlogon]
2025-08-20T03:09:54+03:00 [1:samba1:samba-dc] path = /var/lib/samba/sysvol/ad.xxx.local/scripts
2025-08-20T03:09:54+03:00 [1:samba1:samba-dc] [homes]
2025-08-20T03:09:54+03:00 [1:samba1:samba-dc] browseable = No
2025-08-20T03:09:54+03:00 [1:samba1:samba-dc] comment = %u home directory
2025-08-20T03:09:54+03:00 [1:samba1:samba-dc] [xxx]
2025-08-20T03:09:54+03:00 [1:samba1:samba-dc] comment = AD xxx files
2025-08-20T03:09:54+03:00 [1:samba1:samba-dc] path = /srv/shares/xxx
2025-08-20T03:09:54+03:00 [1:samba1:samba-dc] comment = xxx
2025-08-20T03:09:54+03:00 [1:samba1:samba-dc] comment = xxx backups
2025-08-20T03:09:54+03:00 [1:samba1:samba-dc] 2025-08-20T00:09:54Z chronyd version 4.5 starting (+CMDMON +NTP +REFCLOCK +RTC +PRIVDROP +SCFILTER +SIGND +ASYNCDNS +NTS +SECHASH +IPV6 -DEBUG)
2025-08-20T03:09:54+03:00 [1:samba1:samba-dc] 2025-08-20T00:09:54Z Disabled control of system clock
2025-08-20T03:09:54+03:00 [1:samba1:samba-dc] 2025-08-20T00:09:54Z Loaded 0 symmetric keys
2025-08-20T03:09:54+03:00 [1:samba1:samba-dc] 2025-08-20T00:09:54Z MS-SNTP authentication enabled
2025-08-20T03:09:54+03:00 [1:samba1:samba-dc] [2025-08-20T00:09:54.162093] smart-multi-line: error opening smart-multi-line.fsm file; filename='/usr/share/syslog-ng/smart-multi-line.fsm', error='No such file or directory (2)'
2025-08-20T03:09:54+03:00 [1:samba1:samba-dc] [2025-08-20T00:09:54.162113] smart-multi-line: your smart-multi-line.fsm seems to be empty or non-existent, automatic multi-line log extraction will probably not work; filename='/usr/share/syslog-ng/smart-multi-line.fsm'
2025-08-20T03:09:54+03:00 [1:samba1:samba-dc] samba version 4.19.5-Ubuntu started.
2025-08-20T03:09:54+03:00 [1:samba1:samba-dc] Copyright Andrew Tridgell and the Samba Team 1992-2023
2025-08-20T03:09:54+03:00 [1:samba1:samba-dc] daemon 'samba' : Starting process...
2025-08-20T03:09:54+03:00 [1:samba1:samba-dc] /usr/sbin/smbd: smbd version 4.19.5-Ubuntu started.
2025-08-20T03:09:54+03:00 [1:samba1:samba-dc] /usr/sbin/smbd: Copyright Andrew Tridgell and the Samba Team 1992-2023
2025-08-20T03:09:54+03:00 [1:samba1:samba-dc] /usr/sbin/smbd: INFO: Profiling turned OFF from pid 26
2025-08-20T03:09:54+03:00 [1:samba1:samba-dc] /usr/sbin/winbindd: winbindd version 4.19.5-Ubuntu started.
2025-08-20T03:09:54+03:00 [1:samba1:samba-dc] /usr/sbin/winbindd: Copyright Andrew Tridgell and the Samba Team 1992-2023
2025-08-20T03:09:55+03:00 [1:samba1:samba-dc] /usr/bin/wsdd:935: DeprecationWarning: Testing an element's truth value will raise an exception in future versions. Use specific 'len(elem)' or 'elem is not None' test instead.
2025-08-20T03:09:55+03:00 [1:samba1:samba-dc] if scopes:
2025-08-20T03:09:58+03:00 [1:samba1:systemd] Started Samba DC and File Server.
