hi guys, I have a really weird problem with RspamD.
seems not to start correctly.
systemctl status rspamd
● rspamd.service - rapid spam filtering system
Loaded: loaded (/usr/lib/systemd/system/rspamd.service; enabled; vendor preset: enabled)
Drop-In: /usr/lib/systemd/system/rspamd.service.d
└─nethserver.conf
Active: active (running) since Fri 2020-09-04 04:50:28 CEST; 3 days ago
Docs: https://rspamd.com/doc/
Main PID: 11561 (rspamd)
CGroup: /system.slice/rspamd.service
├─11561 rspamd: main process; 0.1 msg/sec, 0.0 msg/sec spam, 0.1 msg/sec ham
├─11565 rspamd: fuzzy process (localhost:11335)
├─11566 rspamd: rspamd_proxy process (/var/run/rspamd/worker-proxy mode=0770 owner=_rspamd group=mail)
├─11567 rspamd: controller process (127.0.0.1:11334)
└─11568 rspamd: hs_helper process
Sep 07 18:06:29 srvup.XXX.it rspamd[11566]: <f0b605>; proxy; rspamd_lua_redis_prepare_connection: cannot connect to redis (...ectory
Sep 07 18:06:29 srvup.XXX.it rspamd[11566]: <f0b605>; lua; lua_redis.lua:950: cannot make redis request to: /var/run/redis-...rspamd
Sep 07 18:06:29 srvup.XXX.it rspamd[11566]: <f0b605>; proxy; rspamd_task_write_log: id: <8b55e698-2e8e-a528-3617-1fd871d162...M(0.00
Sep 07 18:06:29 srvup.XXX.it rspamd[11566]: <f0b605>; proxy; rspamd_protocol_http_reply: regexp statistics: 0 pcre regexps ... total
Sep 07 18:06:29 srvup.XXX.it rspamd[11566]: <2fd904>; proxy; proxy_milter_finish_handler: finished milter connection
Sep 07 18:06:39 srvup.XXX.it rspamd[11565]: <>; ; rspamd_redis_pool_new_connection: cannot connect to redis /var/run/redis-...ectory
Sep 07 18:07:39 srvup.XXX.it rspamd[11565]: <>; ; rspamd_redis_pool_new_connection: cannot connect to redis /var/run/redis-...ectory
Sep 07 18:08:39 srvup.XXX.it rspamd[11565]: <>; ; rspamd_redis_pool_new_connection: cannot connect to redis /var/run/redis-...ectory
Sep 07 18:09:39 srvup.XXX.it rspamd[11565]: <>; ; rspamd_redis_pool_new_connection: cannot connect to redis /var/run/redis-...ectory
Sep 07 18:10:39 srvup.XXX.it rspamd[11565]: <>; ; rspamd_redis_pool_new_connection: cannot connect to redis /var/run/redis-...ectory
Hint: Some lines were ellipsized, use -l to show in full.
more
systemctl status redis-rspamd
● redis-rspamd.service - Redis persistent key-value database Rspamd
Loaded: loaded (/usr/lib/systemd/system/redis-rspamd.service; static; vendor preset: disabled)
Active: failed (Result: exit-code) since Fri 2020-09-04 04:50:28 CEST; 3 days ago
Main PID: 11560 (code=exited, status=1/FAILURE)
Warning: Journal has been rotated since unit was started. Log output is incomplete or unavailable.
more
redis-cli -s /var/run/redis-rspamd/rspamd monitor
Could not connect to Redis at /var/run/redis-rspamd/rspamd: No such file or directory
what went wrong?
I realized only after I migrated from the same version of nethserver.
[root@srvmail ~]# systemctl status redis-rspamd
Active: failed (Result: exit-code) since Tue 2020-09-08 22:20:37 CEST; 4min 35s ago
Main PID: 807 (code=exited, status=1/FAILURE)
Sep 08 22:20:37 srvmail.XXX.it systemd[1]: Started Redis persistent key-value database Rspamd.
Sep 08 22:20:37 srvmail.XXX.it systemd[1]: redis-rspamd.service: main process exited, code=exited, status=1/FAILURE
Sep 08 22:20:37 srvmail.XXX.it systemd[1]: Unit redis-rspamd.service entered failed state.
Sep 08 22:20:37 srvmail.XXX.it systemd[1]: redis-rspamd.service failed.
and
[root@srvmail ~]# redis-cli -s /var/run/redis-rspamd/rspamd monitor
