Rspamd Module loading error: timeout, module: fontawesome
Hi All and Merry Christmas…
I keep on getting this error when loading rspamd from nethserver web interface.
I am still on NethServer 7.9.2009.
I’ve searched hi and lo, on some post someone suggested removing and re-installing httpd-admin, but no joy.
Anyone seen this?
Thank you and best regards
bosco
Hi Bosco, I’m not sure I understood your issue. AFAIK Rspamd UI requires a trailing slash in the URL to work properly. Did you add a trailing slash to the Rspamd UI URL? E.g.
This has problems:
https://<HOST_IP>:980/rspamd
This may work instead:
https://<HOST_IP>:980/rspamd/
At least in NS8 this is the requirement. For NS7, I don’t remember.
For completeness, this is the relevant NS7 manual section Email — NethServer 7 Final (trailing slash not documented :thinking:)
Hi Davide and thanks for the reply… Checked and there is a trailing /…
Thanks
