rSpamd Maps: Connection refused
Server: NS 7.9, full updated
rSpamd: 2.5
I have 2 different web servers with different domains. Both are configured as mail server.
On both systems I’m getting identical error messages in rspamd-history, like:
error reading https://maps.rspamd.com/freemail/free.txt.zst(135.181.149.121:443): connection with http server terminated incorrectly: ssl connect error: syscall fail: Connection refused
error reading https://maps.rspamd.com/rspamd/surbl-whitelist.inc.zst(135.181.149.121:443): connection with http server terminated incorrectly: ssl connect error: syscall fail: Connection refused
…and so on with the other maps.
What is happened here?
I’ve tried to download the file few seconds ago, succeeding.
So, maybe your mirror is… experiencing issues.
After a lookup i found these ip addresses:
A maps.rspamd.com 135.181.149.121
Hetzner Online GmbH (AS24940)
60 min
A maps.rspamd.com 151.115.41.123
ONLINE S.A.S. (AS12876)
60 min
Maybe Hetzner is experiencing some issues? IDK…
Did you try to download the file from your computer? (around 20k )
Yes I did, it’s impossible.
ps.:
from my Laptop:
dig is possible, ping also
curl https://maps.rspamd.com/freemail/free.txt.zst curl: (35) error:1400410B:SSL routines:CONNECT_CR_SRVR_HELLO:wrong version number
Same issue - Debian 10, LXC, my quick workaround:
echo "151.115.41.123 maps.rspamd.com" >> /etc/hosts
systemctl restart rspamd
This resolves only problems with DNS resolution. But dig is possible.
I tried to curl https://maps.rspamd.com/freemail/free.txt.zst from my server: curl is possible.
Issues seem outside rSpamd/your system…
I checked the IPs in logs:
  • Thread shield
  • IPS
  • Firewall
–> no log entries
only in var/log/maillog-yyyymmdd
resolved by…
:slight_smile:
The problem persits:
error reading https://maps.rspamd.com/rspamd/redirectors.inc.zst(151.115.41.123:443): connection with http server terminated incorrectly: ssl connect error: syscall fail: Connection timed out
On Github exits an issue: https://github.com/rspamd/rspamd/issues/3616
I tried to wget the file from web console … without any problems.
Heinlein has committed an individual fix: https://github.com/HeinleinSupport/rspamd/commit/8ebcc2d409d82e40c2e7adafe682f7504bdd4318
Can we do anything on Nethserver?
Did you install the latest updates?
We are testing the rspamd 3.0 it works well since a while on my server
yum update rspamd --enablerepo=nethserver-testing
It seems the fix has been pushed to 2.8 and probably you run 2.7
@stephdl how confident you feel to tell people “try it”?
I am using a “going to production” installation, feeling bold enough to start it.
You can safely come back with a
yum downgrade rspamd
Eventually restart all the services stack
signal-event nethserver-mail-filter-update
Well for sure your are the captain of your server :slight_smile:
For whom still not used any kind of testing package, might ask you to approve the key of the server.
yes, I did.
I will try it
I did it. The installtion was w7o n issue. After installation, one error occurs in history section:
8.10.2021, 19:37:00 controller 1015 csession 0a4878 http error occurred: Not found
I think it can only be definitively evaluated once the filter has been running for a few hours.
I found a lot of new errors again, all the same IP:
Time Worker type PID Module Internal ID Message
9.10.2021, 07:00:19 controller 1015 map o33omj error reading https://maps.rspamd.com/rspamd/mime_types.inc.zst(151.115.41.123:443): connection with http server terminated incorrectly: ssl connect error: syscall fail: Connection timed out
9.10.2021, 06:51:18 rspamd_proxy 1014 proxy 735623 cannot compare parts with more than 8192 words: (5080 + 5151)
9.10.2021, 06:02:51 controller 1015 map fdp86m error reading https://maps.rspamd.com/freemail/free.txt.zst(151.115.41.123:443): connection with http server terminated incorrectly: ssl connect error: syscall fail: Connection timed out
9.10.2021, 05:50:59 controller 1015 map qamb1r error reading https://maps.rspamd.com/rspamd/dmarc_whitelist_new.inc.zst(151.115.41.123:443): connection with http server terminated incorrectly: ssl connect error: syscall fail: Connection timed out
9.10.2021, 05:49:23 controller 1015 map 7n3qic error reading https://maps.rspamd.com/rspamd/mid.inc.zst(151.115.41.123:443): connection with http server terminated incorrectly: ssl connect error: syscall fail: Connection timed out
9.10.2021, 04:31:31 controller 1015 map o33omj error reading https://maps.rspamd.com/rspamd/mime_types.inc.zst(151.115.41.123:443): connection with http server terminated incorrectly: ssl connect error: syscall fail: Connection timed out
9.10.2021, 03:57:27 controller 1015 map 1u5hdp error reading https://maps.rspamd.com/rspamd/redirectors.inc.zst(151.115.41.123:443): connection with http server terminated incorrectly: ssl connect error: syscall fail: Connection timed out
9.10.2021, 03:33:02 controller 1015 map yhcyzt error reading https://maps.rspamd.com/rspamd/phishing_whitelist.inc.zst(151.115.41.123:443): connection with http server terminated incorrectly: ssl connect error: syscall fail: Connection timed out
9.10.2021, 03:13:35 controller 1015 map fdp86m error reading https://maps.rspamd.com/freemail/free.txt.zst(151.115.41.123:443): connection with http server terminated incorrectly: ssl connect error: syscall fail: Connection timed out
9.10.2021, 03:00:17 controller 1015 map qamb1r error reading https://maps.rspamd.com/rspamd/dmarc_whitelist_new.inc.zst(151.115.41.123:443): connection with http server terminated incorrectly: ssl connect error: syscall fail: Connection timed out
The data are downloadable from webconsole.
The DNS record still exits in /etc/hosts
# # 40hosts_local #
IP Tools (www.iptools.su)
Whois
Hôte: maps.rspamd.com
Réponse DNS
Type: A
maps.rspamd.com. 1196 IN A 88.198.198.21
Type: A
maps.rspamd.com. 1196 IN A 151.115.41.123
@capote are you using Threatshield?
