100%[===================================================================================================================================================================>] 4.591 --.-K/s in 0s
Additional information…
I am experiencing the same error on another server with a different IP and DNS zone.
However, Thread Shield is not even installed there.
this make me thing that you have used the maximum of the free policy that the lead developer offers, probably your IP has been blocked
First try to remove the dns entry you have forced, like this you won’t use all the time the same IP, maybe you will need to ask also to the lead dev if your IP is not banned
Hello Stephane,
I may not have expressed myself correctly.
Both server installations have nothing in common with each other - no IP, no DNS zone… no other resources. They are completely independent installations. Nevertheless, the error occurs with both of them.
Therefore, I cannot classify and interpret your hint. Otherwise, I don’t know what I could do concretely.
Sincerely, Marko
me too
You are experiencing an issue that we cannot reproduce. Sometimes you might have the same errors written in logs, but not all the time, see my picture below
verify you are full updated
restart rspamd or better trigger the event signal-event nethserver-mail-filter-update
and check again
Relative to the possible ban of your IP by the server of rspamd, I state on it but obviously it is not sure because about 1 year ago, the lead dev has banned all IP used by synology system that were using a really old version of rspamd and it has flooded the rspamd infrastructure.
Maybe you ip is inside that IP list, the rspamd telegram channel is probably a good place to ask.
Other idea, open a ticket to nethesis to check what is occurring
