Report Bandwith usage - could not decode ntopng response
Hi!
Does the report module (Bandwidth usage) only work if Ntopng sets no authentication?
When I enable authentication I get a message "Could not communicate with ntopng. See /var/log/messages for details"
LOG - neth httpd: [ERROR] NethServer\Module\NtopngStatus: could not decode ntopng
System version
NethServer release 7.4.1708
Hi @pablo,
I tested it now on 7.4.1708 and got the same error, maybe something changed from ntop version 2 to 3 but this is not intended I think. The ntopng application is working but Reports/Bandwidth Usage shows this, when authentication is enabled:
After a reboot the already changed password for ntopng admin was reset to default admin.
This one is already raised:
I think you found a bug. Thank you.
AFAIK authentication should always be disabled on from localhost.
I will check the code next week and let you know
@mrmarkuz was right, you hit a bug @pablo.
You can find the fixed packaged in nethserver-testing:
Thanks for help! :slight_smile:
Thanks for you’re time, we are going to release the update soon! :wink:
