Guys,
I’m running System version
NethServer release 7.7.1908 (final)
Kernel release
3.10.0-1062.1.2.el7.x86_64
Everything was fine till this morning, when we had a power outage. Now, I’ve got the server back, but RAID is not well:
From the Dashboard:
md1 CRITICAL
Level RAID1
Devices 1/2 (sda1)
md2 CRITICAL
Level RAID1
Devices 1/2 (sda2)
This is a vanilla Nethserver build, I changed nothing from the way the disks were built by the install process.
Now I can see there is something wrong, but you will be able to see from what I have tried, that I know NOTHING about rebuilding RAID:
cat /proc/mdstat outputs the following:
Personalities : [raid1]
md1 : active raid1 sda1[0]
1046528 blocks super 1.2 [2/1] [U_]
bitmap: 1/1 pages [4KB], 65536KB chunk
md2 : active raid1 sda2[0]
974531584 blocks super 1.2 [2/1] [U_]
bitmap: 7/8 pages [28KB], 65536KB chunk
unused devices:
so its U_ instead of UU so I think I’m running on half a RAID array, but I don’t know which disk has been removed and I don’t know how to re-add them. I tried this:
mdadm /dev/md1 -a /dev/sda2
but got this response:
mdadm: Cannot open /dev/sda2: Device or resource busy
which makes me think I’m playing with the wrong disk, so I backed off from that!
I also got this output:
[root@bastion dev]# mdadm -D /dev/md1
/dev/md1:
Version : 1.2
Creation Time : Thu Feb 28 21:53:46 2019
Raid Level : raid1
Array Size : 1046528 (1022.00 MiB 1071.64 MB)
Used Dev Size : 1046528 (1022.00 MiB 1071.64 MB)
Raid Devices : 2
Total Devices : 1
Persistence : Superblock is persistent
Intent Bitmap : Internal
Update Time : Sat Oct 19 14:37:38 2019
State : clean, degraded
Active Devices : 1
Working Devices : 1
Failed Devices : 0
Spare Devices : 0
Consistency Policy : bitmap
UUID : 0438973a:a588a669:aa17a4a9:1347d2c1
Events : 393
Number Major Minor RaidDevice State
0 8 1 0 active sync /dev/sda1
- 0 0 1 removed
[root@bastion dev]# mdadm -D /dev/md2
/dev/md2:
Version : 1.2
Creation Time : Thu Feb 28 21:53:23 2019
Raid Level : raid1
Array Size : 974531584 (929.39 GiB 997.92 GB)
Used Dev Size : 974531584 (929.39 GiB 997.92 GB)
Raid Devices : 2
Total Devices : 1
Update Time : Sat Oct 19 20:19:49 2019
Active Devices : 1
Working Devices : 1
Failed Devices : 0
Spare Devices : 0
UUID : ebd5c302:96e2a3b9:21f695e0:a1f08008
Events : 362063
0 8 2 0 active sync /dev/sda2
- 0 0 1 removed
It’s only a “domestic” server, so its not the end of the world, and it seems to be running OK on one disk for the time being, but I’d like to learn a bit about this, I’ve run RAID arrays before on “home grown” servers , but never tinkered with the internals of Nethserver. Some other info I dug out:
[root@bastion ~]# lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
sda 8:0 0 931.5G 0 disk
├─sda1 8:1 0 1G 0 part
│ └─md1 9:1 0 1022M 0 raid1 /boot
└─sda2 8:2 0 929.5G 0 part
└─md2 9:2 0 929.4G 0 raid1
├─VolGroup-lv_root 253:0 0 921.5G 0 lvm /
└─VolGroup-lv_swap 253:1 0 7.9G 0 lvm [SWAP]
sdb 8:16 0 931.5G 0 disk
├─sdb1 8:17 0 1G 0 part
└─sdb2 8:18 0 930.5G 0 part
sdc 8:32 0 1.8T 0 disk
└─sdc1 8:33 0 1.8T 0 part
sdd 8:48 1 7.5G 0 disk
sr0 11:0 1 1024M 0 rom
[root@bastion dev]# ls sd*
sda sda1 sda2 sdb sdb1 sdb2 sdc sdc1 sdd
[root@bastion dev]# ls md*
md1 md2
md:
1 2
I’d be grateful for some guidance…one last thing: the server is fully backed up daily to an external 1T USB drive, so if the worst comes to the worst…
Thanks
Jim
