Hello everyone, who uses proxmox I would have to ask:
I activated in a cluster of 3 nodes the vlan aware option, an option that as I read allows the management of VM vlans between them on the cluster structure. I tried and everything works well only when the vlan tags e.g. 200 or other value are only and exclusively inserted into the VMs of the same node. If I try to give the same tag to another node in the same cluster it doesn’t work. I would like to point out that this option (unless I’m wrong or you were misinformed) should work regardless of any switch. I just have a doubt, having a DLINK des 1100-24 switch and not managed, you need to have a switch that supports vlan even if as written before you do not need to configure anything? Thank you
