It is not nextcloud office, rather collabora online
I broken down the collabora online. Now in nextcloud clicking the file is only downloading. Pls tell me what does I did wrong. I only disable the Collabora CODE from the browser in the + APP
This means you are using the Nextcloud internal collabora. That could be the reason for perfomance problems.
I recommend to uninstall âCollabora Online - Built-in CODE Serverâ and enable/install âNextcloud Officeâ which is just a connector to the official Collabora server provided in the Software Center of NethServer.
To resetup Collabora after uninstalling the internal one:
signal-event nethserver-collabora-update
If needs to be enabled again. If itâs disabled, Nextcloud falls back to how it would work without Office and provides the download.
Its the collabora online which is enable. See below
The CODE is shown in the menu in + APP but not showing installed see below
But when opening the file, it shows Collabora CODE at the startup.
Yes and itâs the internal wrong app, you need Nextcloud office (search for office on apps page).
Please install/enable this app in Nextcloud, if not already done.
Then you should be able to paste a screenshot like I posted above to check if the settings of the (Nextcloud) Office app are correct.
I found you already posted a screenshot for using the official dedicated server instead of the internal one here. Are the settings still the same?
Iâm sorry, the app names changed and itâs really a little confusing.
EDIT2:
Is your system up to date?
Not quite well. I donât want to break the Nextcloud, thatâs why I was selective in upgrading.
Updates provide fixes so there may be issues because of an old system.
What do you mean by posting earlier screen shot when the collabora was not working â Problem was with the certificate and the vhost using cli which was fixed. This one is the new
BTW I am unable to find any APP Nextcloud Office in the APP section.
I asked you for a screenshot and just showed you an example.
Usually when you can click save on the settings page and itâs still green, it should be working.
This could be because of old versions. They changed the namesâŚ
Updating the Nextcloud. There are 214 updates available. Will update at night. Is it possible to integrate the externally installed Office such as Onlyoffice installed in Synology NAS. P.s NAS is usually without load except Restic Backup.
I assume you are talking about updates in NethServer software center?
Itâs always good to have a backup/snapshot before starting big updates.
It should be possible with the Nextcloud Onlyoffice app to connect to an external server.
If itâs about performance, I donât know if your Synology NAS is enoughâŚeven without load.
Ya Proxmox backup is there plus Restic Backup of the NS7
For testing purpose only. Or will use a desktop with onlyoffice/collabora externally in the same network.
8 posts were split to a new topic: Unable to access Nextcloud after update
