jfhoyosm
(Julian Felipe Hoyos Montoya)
February 10, 2021, 12:07pm
1
Good morning friends, I have a problem installing the phpVirtualBox-5.2, I would appreciate the help.
[root@nethserver ~]# echo '{"action":"install","packages":["@nethserver-virtualbox-5.2-phpvirtualbox"]}' | /usr/bin/setsid /usr/bin/sudo /usr/libexec/nethserver/api/system-packages/update | jq
"state": "running",
"steps": -1,
"event": "Initialization"
"state": "running",
"steps": -1,
"event": "Resolving RPM dependencies"
"state": "running",
"steps": -1,
"event": "Downloading Packages"
"state": "running",
"steps": -1,
"event": "Check Package Signatures"
"state": "running",
"steps": -1,
"event": "Running Test Transaction"
"status": "failed",
"message": "[YumRPMCheckError] [u'ERROR with transaction check vs depsolve:', 'php-common(x86-64) = 5.4.16-48.el7 is needed by php-ldap-5.4.16-48.el7.x86_64', 'php-common(x86-64) = 5.4.16-48.el7 is needed by php-soap-5.4.16-48.el7.x86_64', 'php-common(x86-64) = 5.4.16-48.el7 is needed by php-gd-5.4.16-48.el7.x86_64']",
"steps": -1,
"event": null
"id": "1612958717",
"type": "EventFailed",
"message": "See /var/log/messages"
mrmarkuz
(Markus Neuberger)
February 10, 2021, 1:19pm
2
jfhoyosm:
You may try to install from command line to maybe see more error output:
yum clean all
yum --enablerepo=nethforge install nethserver-virtualbox-5.2-phpvirtualbox
Please also check /var/log/messages for errors.
jfhoyosm
February 10, 2021, 1:52pm
3
this is what appears to me:
Error: Package: php-ldap-5.4.16-48.el7.x86_64 (ce-base)
Requires: php-common(x86-64) = 5.4.16-48.el7
Installed: php-common-5.6.40-22.el7.remi.x86_64 (@remi-php56)
php-common(x86-64) = 5.6.40-22.el7.remi
Available: php-common-5.4.16-48.el7.x86_64 (ce-base)
Error: Package: php-soap-5.4.16-48.el7.x86_64 (ce-base)
Error: Package: php-gd-5.4.16-48.el7.x86_64 (ce-base)
You could try using --skip-broken to work around the problem
mrmarkuz
(Markus Neuberger)
February 10, 2021, 2:02pm
4
Do you know why you have php-common-5.6.40-22 from remi repo installed?
Maybe this helps:
yum --enablerepo=nethforge --disablerepo=remi-php56 install nethserver-virtualbox-5.2-phpvirtualbox
Just to check what’s installed from remi repo:
yum list installed | grep remi
stephdl
(Stéphane de Labrusse)
February 10, 2021, 2:19pm
5
never ever upgrade a version of software like php, please just use PHP-SCL solution
jfhoyosm
February 10, 2021, 2:23pm
6
Yes, I installed it because php was giving me some problems, and what you tell me is on the internet and it gets the same error, how can I return to php5.4 remi repo
jfhoyosm
February 10, 2021, 2:24pm
7
Yes, I see that it was my fault, how can I return to php5.4 remi repo ?
jfhoyosm
February 10, 2021, 2:25pm
8
[root@nethserver ~]# yum list installed | grep remi
libicu65.x86_64 65.1-1.el7.remi @remi-safe
libzip5.x86_64 1.7.3-1.el7.remi @remi-safe
php.x86_64 5.6.40-22.el7.remi @remi-php56
php-cli.x86_64 5.6.40-22.el7.remi @remi-php56
php-common.x86_64 5.6.40-22.el7.remi @remi-php56
php-intl.x86_64 5.6.40-22.el7.remi @remi-php56
php-mbstring.x86_64 5.6.40-22.el7.remi @remi-php56
php-mysqlnd.x86_64 5.6.40-22.el7.remi @remi-php56
php-pdo.x86_64 5.6.40-22.el7.remi @remi-php56
php-pecl-jsonc.x86_64 1.3.10-2.el7.remi.5.6 @remi-php56
php-pecl-zip.x86_64 1.19.0-1.el7.remi.5.6 @remi-php56
php-xml.x86_64 5.6.40-22.el7.remi @remi-php56
remi-release.noarch 7.8-1.el7.remi installed
stephdl
February 10, 2021, 2:45pm
9
yum remove rpm1 rpm2 rpm3
but the command above can remove some important other rpm, take care what you remove before to press Y
else you can do, no dependencies removal
rpm -e --nodeps rpm1 rpm2 rpm3
at the end, think to reinstall the good rpm of ce-base
you can keep @remi-safe
jfhoyosm
February 10, 2021, 3:08pm
10
What I did exactly was the following:
root@server: ~ # wget http://rpms.famillecollet.com/enterprise/remi-release-7.rpm
root@server: ~ # rpm -Uhv remi-release-7.rpm
warning: remi-release-7.rpm: Header V4 DSA/SHA1 Signature, key ID 00f97f56: NOKEY
Preparing... ################################# [100%]
Updating / installing...
1:remi-release-7.2-1.el7.remi ################################# [100%]
root@server: ~ # vim /etc/yum.repos.d/remi.repo
[remi-php56]
name=Remi's PHP 5.6 RPM repository for Enterprise Linux 7 - $basearch
mirrorlist=http://rpms.remirepo.net/enterprise/7/php56/mirror
enabled=1
gpgcheck=1
gpgkey=file:///etc/pki/rpm-gpg/RPM-GPG-KEY-remi
root@server: ~ # yum update
root@server: ~ # yum --enablerepo=remi-php56 install php-cli
