NethServer Version: 7.9.2009
Module: Email
Hi guys
I have this problem, i have acronis send me report for my backup to mygroup mail: backup@mydomain.tld and i don’t receive any mail, but if i try to send to another group for example assistenza@mydomain.tld the email arrived
This is the Mail log when i try to send to backup@mydomain.tld
Mar 29 12:05:46 mail rspamd[26944]: <3y4jzj>; lua; bayes_expiry.lua:440: finished expiry step 19: 992 items checked, 154 significant (7 made persistent), 2 insignificant (0 ttls set), 0 common (0 discriminated), 836 infrequent (0 ttls set), 1 mean, 1 std
Mar 29 12:06:48 mail rspamd[26944]: <3y4jzj>; lua; bayes_expiry.lua:440: finished expiry step 20: 995 items checked, 157 significant (6 made persistent), 1 insignificant (0 ttls set), 1 common (1 discriminated), 836 infrequent (0 ttls set), 1 mean, 2 std
This is the Mail log when i try to send to assistenza@mydomain.tld
Mar 29 12:07:47 mail postfix/smtpd[7519]: connect from m229-208.mailgun.net[159.135.229.208]
Mar 29 12:07:47 mail rspamd[26943]: ; proxy; proxy_accept_socket: accepted milter connection from /var/run/rspamd/worker-proxy port 0
Mar 29 12:07:48 mail postfix/smtpd[7519]: C493D120B: client=m229-208.mailgun.net[159.135.229.208]
Mar 29 12:07:48 mail rspamd[26943]: ; milter; rspamd_milter_process_command: got connection from 159.135.229.208:21687
Mar 29 12:07:49 mail postfix/cleanup[7533]: C493D120B: message-id=8XBsASZofbr9nAiD3wmKVF.0@eu8-cloud.acronis.com
Mar 29 12:07:49 mail rspamd[26943]: ; proxy; rspamd_message_parse: loaded message; id: 8XBsASZofbr9nAiD3wmKVF.0@eu8-cloud.acronis.com; queue-id: ; size: 78652; checksum: <95686de04e6d18d548bf24876b03d816>
Mar 29 12:07:49 mail rspamd[26943]: ; proxy; rspamd_mime_part_detect_language: detected part language: en
Mar 29 12:07:49 mail clamd[6905]: SelfCheck: Database status OK.
Mar 29 12:07:49 mail rspamd[26943]: ; proxy; dkim_module_key_handler: stored DKIM key for mailo._domainkey.cloud.acronis.com in LRU cache for 3600 seconds, 106/2000 elements in the cache
Mar 29 12:07:49 mail rspamd[26943]: ; proxy; rspamd_spf_record_postprocess: increasing ttl from 60 to 300 as it lower than a limit
Mar 29 12:07:49 mail rspamd[26943]: ; proxy; rspamd_spf_maybe_return: stored record for cloud.acronis.com (0xd3591d2de198b9e9) in LRU cache for 300 seconds, 110/2000 elements in the cache
Mar 29 12:07:49 mail rspamd[26943]: ; proxy; rspamd_symcache_finalize_item: slow rule: MX_INVALID(261): 428.88 ms; enable slow timer delay
Mar 29 12:07:49 mail rspamd[26943]: ; proxy; rspamd_redis_connected: skip obtaining bayes tokens for BAYES_SPAM of classifier bayes: not enough learns 103; 200 required
Mar 29 12:07:49 mail rspamd[26943]: ; proxy; rspamd_redis_connected: skip obtaining bayes tokens for BAYES_HAM of classifier bayes: not enough learns 116; 200 required
Mar 29 12:07:49 mail rspamd[26943]: ; proxy; rspamd_stat_classifiers_process: skip statistics as SPAM class is missing
Mar 29 12:07:49 mail rspamd[26943]: ; lua; neural.lua:315: skip ham sample to keep spam/ham balance; probability 0.7330508474576272; 63 spam and 235 ham vectors stored
Mar 29 12:07:49 mail rspamd[26943]: ; proxy; rspamd_task_write_log: id: 8XBsASZofbr9nAiD3wmKVF.0@eu8-cloud.acronis.com, qid: , ip: 159.135.229.208, from: bounce@cloud.acronis.com, (default: F (no action): [-1.51/20.00] [DWL_DNSWL_LOW(-1.00){acronis.com:dkim;},DMARC_POLICY_ALLOW(-0.50){cloud.acronis.com;none;},FORGED_SENDER(0.30){noreply-abc@cloud.acronis.com;bounce@cloud.acronis.com;},MIME_HTML_ONLY(0.20){},R_DKIM_ALLOW(-0.20){cloud.acronis.com:s=mailo;},R_SPF_ALLOW(-0.20){+ip4:159.135.224.0/20;},MIME_GOOD(-0.10){multipart/mixed;},MX_GOOD(-0.01){},IP_REPUTATION_HAM(-0.00){asn: 33070(0.00), country: US(-0.00), ip: 159.135.229.208(0.00);},ASN(0.00){asn:33070, ipnet:159.135.229.0/24, country:US;},DKIM_TRACE(0.00){cloud.acronis.com:+;},FROM_NEQ_ENVFROM(0.00){noreply-abc@cloud.acronis.com;bounce@cloud.acronis.com;},FROM_NO_DN(0.00){},HAS_ATTACHMENT(0.00){},MID_RHS_MATCH_FROMTLD(0.00){},MIME_TRACE(0.00){0:+;1:~;2:~;},NEURAL_HAM(0.00){-0.998;},RCPT_COUNT_ONE(0.00){1;},RCVD_COUNT_TWO(0.00){2;},RCVD_IN_DNSWL_NONE(0.00){159.135.229.208:from;},RCVD_TLS_LAST(0.00){},RWL_MAILSPIKE_POSSIBLE(0.00){159.135.229.208:from;},TAGGED_FROM(0.00){4fc62d.5e9113-assistenza=mydomain.tld;},TO_DN_NONE(0.00){},TO_MATCH_ENVRCPT_ALL(0.00){}]), len: 78652, time: 627.285ms, dns req: 40, digest: <95686de04e6d18d548bf24876b03d816>, rcpts: assistenza@mydomain.tld, mime_rcpts: assistenza@mydomain.tld
Mar 29 12:07:49 mail rspamd[26943]: ; proxy; rspamd_protocol_http_reply: regexp statistics: 82 pcre regexps scanned, 1 regexps matched, 175 regexps total, 11 regexps cached, 34.53KiB scanned using pcre, 34.53KiB scanned total
Mar 29 12:07:49 mail postfix/qmgr[26933]: C493D120B: from=bounce+4fc62d.5e9113-assistenza=mydomain.tld@cloud.acronis.com, size=78924, nrcpt=2 (queue active)
Mar 29 12:07:49 mail dovecot: lmtp(7555): Connect from local
Mar 29 12:07:49 mail dovecot: lmtp(user1@mydomain.tld): save: box=Assistenza, uid=292, msgid=8XBsASZofbr9nAiD3wmKVF.0@eu8-cloud.acronis.com, from=noreply-abc@cloud.acronis.com, subject=DAILY REPORT ON Mar 29, 2022 12:07 PM, flags=()
Mar 29 12:07:49 mail dovecot: lmtp(user1@mydomain.tld): sPokOnXaQmKDHQAANIBgBA: sieve: msgid=8XBsASZofbr9nAiD3wmKVF.0@eu8-cloud.acronis.com: stored mail into mailbox ‘Assistenza’
Mar 29 12:07:49 mail postfix/lmtp[7554]: C493D120B: to=user1@mydomain.tld, orig_to=assistenza@mydomain.tld, relay=mail.mydomain.tld[/var/run/dovecot/lmtp], delay=1.4, delays=1.4/0/0/0.01, dsn=2.0.0, status=sent (250 2.0.0 user1@mydomain.tld sPokOnXaQmKDHQAANIBgBA Saved)
Mar 29 12:07:49 mail dovecot: lmtp(user2@mydomain.tld): save: box=Assistenza, uid=50, msgid=8XBsASZofbr9nAiD3wmKVF.0@eu8-cloud.acronis.com, from=noreply-abc@cloud.acronis.com, subject=DAILY REPORT ON Mar 29, 2022 12:07 PM, flags=()
Mar 29 12:07:49 mail dovecot: lmtp(user2@mydomain.tld): sPokOnXaQmKDHQAANIBgBA:2: sieve: msgid=8XBsASZofbr9nAiD3wmKVF.0@eu8-cloud.acronis.com: stored mail into mailbox ‘Assistenza’
Mar 29 12:07:49 mail postfix/lmtp[7554]: C493D120B: to=user2@mydomain.tld, orig_to=assistenza@mydomain.tld, relay=mail.mydomain.tld[/var/run/dovecot/lmtp], delay=1.4, delays=1.4/0/0/0.02, dsn=2.0.0, status=sent (250 2.0.0 user2@mydomain.tld sPokOnXaQmKDHQAANIBgBA:2 Saved)
Mar 29 12:07:49 mail dovecot: lmtp(7555): Disconnect from local: Successful quit
