Users permissions not functiun well with shared folders and permissions.
Here my informations
Account provider
i have saved again information and here is the ouput of /var/log/messages logs
Apr 30 12:13:25 srv-data systemd: Reloading.
Apr 30 12:13:25 srv-data systemd: Starting System Security Services Daemon…
Apr 30 12:13:25 srv-data sssd: Starting up
Apr 30 12:13:25 srv-data sssd[be[chabert.internal]]: Starting up
Apr 30 12:13:25 srv-data sssd[nss]: Starting up
Apr 30 12:13:25 srv-data sssd[pam]: Starting up
Apr 30 12:13:25 srv-data systemd: Started System Security Services Daemon.
Apr 30 12:13:25 srv-data esmith::event[20137]: [INFO] sssd has been started
Apr 30 12:13:25 srv-data esmith::event[20137]: Action: /etc/e-smith/events/actions/adjust-services SUCCESS [0.51964]
Apr 30 12:13:25 srv-data esmith::event[20137]: Event: nethserver-sssd-save SUCCESS
Apr 30 12:13:25 srv-data sssd: ; TSIG error with server: tsig verify failure
Apr 30 12:13:26 srv-data sssd: tkey query failed: GSSAPI error: Major = Unspecified GSS failure. Minor code may provide more information, Minor = Server not found in Kerberos database.
[root@srv-data ~]# config show dns
dns=configuration
NameServers=172.30.0.24,8.8.8.8
[root@srv-data ~]# config show nsdc
[root@srv-data ~]#
[root@srv-data ~]# cat /etc/hosts
# at NethServer official site: https://www.nethserver.org
# 10localhost
127.0.0.1 localhost localhost.localdomain
# 20hostname(s)
172.30.0.12 srv-data.chabert.internal srv-data
# 30hosts_remote
# 40hosts_local
you may try “ldaps://…” with STARTTLS “no” or “ldap://” with STARTTLS “yes”. Sometimes unbind and rejoin helps. Different system clocks could be a problem too.
1 -> Delete 8.8.8.8 from secondary DNS Server OK
2-> Validated again “Account provider” and ask to rejoin domain OK
3-> Go to “Domain account” -> Still “Could not connect to accounts provider!” error.
