try with this rpm
yum install http://mirror.de-labrusse.fr/nethserver/nethserver-owncloud-1.1.7/nethserver-owncloud-1.1.7-1.ns7.sdl.noarch.rpm --enablerepo=epel,ce_stable
try with this rpm
Works on a clean NS install!!!
But If trying to upgrade the owncloud installed with NS:
[root@centos-2gb-nyc3-01 ~]# yum install http://mirror.de-labrusse.fr/nethserver/nethserver-owncloud-1.1.7/nethserver-owncloud-1.1.7-1.ns7.sdl.noarch.rpm --enablerepo=epel,ce_stable
nethserver-owncloud-1.1.7-1.ns7.sdl.noarch.rpm | 21 kB 00:00:00
Examining /var/tmp/yum-root-TFMmxd/nethserver-owncloud-1.1.7-1.ns7.sdl.noarch.rpm: nethserver-owncloud-1.1.7-1.ns7.sdl.noarch
/var/tmp/yum-root-TFMmxd/nethserver-owncloud-1.1.7-1.ns7.sdl.noarch.rpm: does not update installed package.
Error: Nothing to do
then
yum reinstall http://mirror.de-labrusse.fr/nethserver/nethserver-owncloud-1.1.7/nethserver-owncloud-1.1.7-1.ns7.sdl.noarch.rpm --enablerepo=epel,ce_stable
yum update owncloud --enablerepo=epel,ce_stable
[root@centos-2gb-nyc3-01 ~]# yum reinstall http://mirror.de-labrusse.fr/nethserver/nethserver-owncloud-1.1.7/nethserver-owncloud-1.1.7-1.ns7.sdl.noarch.rpm --enablerepo=epel,ce_stable
No package matched to remove: nethserver-owncloud-0:1.1.7-1.ns7.sdl
Error: Problem in reinstall: no package matched to remove
is it installed ???
rpm -qa |grep nethserver-owncloud
what about to upgrade only owncloud
[root@centos-2gb-nyc3-01 ~]# rpm -qa |grep nethserver-owncloud
nethserver-owncloud-1.1.7-1.15.g05e5475.ns7.noarch
[root@centos-2gb-nyc3-01 ~]# yum update owncloud --enablerepo=epel,ce_stable
base | 3.6 kB 00:00:00
ce_stable | 1.2 kB 00:00:00
epel/x86_64/metalink | 13 kB 00:00:00
epel | 4.3 kB 00:00:00
extras | 3.4 kB 00:00:00
nethserver-base | 3.6 kB 00:00:00
nethserver-updates | 4.1 kB 00:00:00
updates | 3.4 kB 00:00:00
ce_stable/primary | 2.4 kB 00:00:00
- base: mirror.umd.edu
- epel: mirror.cs.princeton.edu
- extras: mirror.netdepot.com
- nethserver-base: mirror.framassa.org
- nethserver-updates: mirror.framassa.org
- updates: ftpmirror.your.org
ce_stable 5/5
Resolving Dependencies
â Running transaction check
â> Package owncloud.noarch 0:8.2.2-1.1 will be obsoleted
â Processing Dependency: owncloud = 8.2.2-1.1 for package: nethserver-owncloud-1.1.7-1.15.g05e5475.ns7.noarch
â> Package owncloud-config-apache.noarch 0:8.2.2-1.1 will be obsoleted
â> Package owncloud-files.noarch 0:9.0.0-1.1 will be obsoleting
â> Package owncloud-server.noarch 0:8.2.2-1.1 will be obsoleted
â Finished Dependency Resolution
Error: Package: nethserver-owncloud-1.1.7-1.15.g05e5475.ns7.noarch (@nethserver-base)
Requires: owncloud = 8.2.2-1.1
Removing: owncloud-8.2.2-1.1.noarch (@nethserver-base)
Obsoleted By: owncloud-files-9.0.0-1.1.noarch (ce_stable)
Not found
Available: owncloud-8.0.10-1.el7.noarch (epel)
owncloud = 8.0.10-1.el7
Available: owncloud-9.0.0-1.1.noarch (ce_stable)
owncloud = 9.0.0-1.1
You could try using --skip-broken to work around the problem
You could try running: rpm -Va --nofiles --nodigest
ok I understand what is occurring, my rpm cannot upgrade the default nethserver-owncloud, and since it is installed, you cannot upgrade owncloud.
Well let to the core developers the care of this rpm, and just test for them if Owncloud9 can be used. Install it from scratch and test and report what is broken on OC9
OK!!!
Testing itâŠno problem for nowâŠthere is a NS7 fail2ban package to try with?
UPDATE:
Some litle change to made:
1)Max upload filesize is 2MB!?!?
2)Cron is set to ajaxâŠit will be a good idea to set on cron (last one) and add a cron job:
Add a cron job same user as webserver.
crontab -u apache -e
*/15 * * * * php -f /var/www/html/owncloud/cron.php > /dev/null 2>&1
Great work @jackyes thanks for your effort
So we can easily upgrade to 9 version. /cc @alep @fasttech @giacomo
Upgrade to version 9
Sorry I meant 9
8 posts were merged into an existing topic: Test OC8/9 with nethserver-fail2ban
Guys can you make a recap to me? @jackyes @stephdl @fasttech
How can I safely upgrade to Owncloud 9 on NethServer 7?
https://download.owncloud.org/download/repositories/stable/owncloud/
CentOS_7 owncloud-9.0.1-1
Run the following shell commands as root to trust the repository.
rpm --import https://download.owncloud.org/download/repositories/stable/CentOS_7/repodata/repomd.xml.key
Run the following shell commands as root to add the repository and install from there.
wget http://download.owncloud.org/download/repositories/stable/CentOS_7/ce:stable.repo -O /etc/yum.repos.d/ce:stable.repo
then
Is this for upgrade or install from scratch?
`[root@test ~]# yum install http://mirror.de-labrusse.fr/nethserver/nethserver-owncloud-1.1.7/nethserver-owncloud-1.1.7-1.ns7.sdl.noarch.rpm --enablerepo=epel,ce_stable
Examining /var/tmp/yum-root-hf5TSq/nethserver-owncloud-1.1.7-1.ns7.sdl.noarch.rpm: nethserver-owncloud-1.1.7-1.ns7.sdl.noarch
/var/tmp/yum-root-hf5TSq/nethserver-owncloud-1.1.7-1.ns7.sdl.noarch.rpm: does not update installed package.
[root@test ~]# yum install owncloud
ce_stable/primary | 2.5 kB 00:00:03
@stephdl
I installed oC v9 on NS 7a2 with your repo and it did install v9 with dependencies but when I click the link in Applications to oC the page https://ip/owncloud comes back with a 404, looking in the software center it offers an update for nethserver-owncloud-1.1.7-1.15.g05e5475, which states in the changelog it requires oC 8.2.2 and attempting the upgrade fails with;
Apr 28 16:19:57 localhost pkgaction[2210]: remove: Apr 28 16:19:57 localhost pkgaction[2210]: update: * Apr 28 16:19:59 localhost pkgaction[2210]: install: Apr 28 16:20:00 localhost pkgaction[2210]: [YumRPMCheckError] [u'ERROR with transaction check vs depsolve:', 'owncloud = 8.2.2-1.1 is needed by nethserver-owncloud-1.1.7-1.15.g05e5475.ns7.noarch']
Maybe you already know this and Iâm just pissing in the wind. shrug.
yes I just removed the require with a version number in the .spec file for a test purpose, but maybe you found a bug for giacomo. It is just to install it from scratch, for an upgrade I suppose that he will see at a beta stage, or sooner.
