OPENVPN problem- users not found
NethServer Version: 7.9.2009 on RaspberryPI
Module: OPENVPN
Hello,
I wanted to start to use the Roadwarrior VPN. I configured everything like described, but for any user I made a roadwarrior entry I am getting the following error in the logfile. I used the option type “system-user”. The users are existing and can access e.g. their email without prioblems:
Account pre.name not present in vpn db
Sat Mar 4 14:36:09 2023 aa.bb.cc.dd:9137 WARNING: Failed running command (–auth-user-pass-verify): external program exited with error status: 1
Sat Mar 4 14:36:09 2023 aa.bb.cc.dd:9137 TLS Auth Error: Auth Username/Password verification failed for peer
Do I need to register the users in some separate VPN USER file or so? I did not read that …
So, what is wrong and should be corrected - I am lost here, with other server distros e.g. ZENTYAL it did work without problems …
Greeting,
Jürgen
Hi @jzick
Here it mostly works out of the box. Usually the ost issues come from people mixing their own installs (No fw adaption!)
Hello,
well, unfortunately nothing like that. It was/is running a clean install on the RaspberryPI and all other stuff is running perfect - except the VPN-tunnel …
Do you have an account provider?
LDAP or AD?
If you’re on the cloud / VPS, you may need this…
https://wiki.nethserver.org/doku.php?id=virtual_network_interface&s[]=dummy
I have a local AD configured …as I said, I am running NETHSERVER on a RaspberryPI …
More or less I followed
What Auth Mode are you using.
From memory, the user/password options can’t be used with system users. Although it was a verrrrrrrry long time ago when I set up my Roadwarrior configuration
Cheers.
Hello,
it is exactly that what I enabled, as it is offered from the VPN manager…So, then I should use VPN only and create different system users?
Greetz…
Hello eveybody,
after digging deaper in I found my error caused by misinterpreting ‘user’.
In my openvpn clients I really just used the user aka joe.smith, but it appeared that the user in the clients must be the full email adress, aka joe.smth@sub.dom.tld …
What a stupid misunderstanding :-)))
Now, all my roadwarriors can connect without problems…
Anyway, thanks to everybody for the help…
