Hello everyone,
I started using NethServer yesterday and so far, so good, like really good.
I installed Openfire and it took me a while to find how to properly configure OpenLDAP with Openfire but got it working.
Now, I’m stuck with a problem/error.
I’m trying to connect to the Openfire server thru Jitsi and it doesn’t connect.
Back on the server, I ran nmap to troubleshoot if the ports were open.
nmap localhost
PORT STATE SERVICE
22/tcp open ssh
25/tcp open smtp
80/tcp open http
139/tcp open netbios-ssn
389/tcp open ldap
443/tcp open https
445/tcp open microsoft-ds
3306/tcp open mysql
5222/tcp open xmpp-client
5269/tcp open xmpp-server
7070/tcp open realserver
7443/tcp open oracleas-https
7777/tcp open cbt
9090/tcp open zeus-admin
9091/tcp open xmltec-xmlmail
They are working for localhost.
If I nmap they external domain, says the port is closed.
nmap myexternaldomain.com
PORT STATE SERVICE
80/tcp open http
1152/tcp closed winpoplanmess
1723/tcp open pptp
5050/tcp open mmcc
5100/tcp open admd
5101/tcp open admdog
Reading on other posts, I found that other users opened TCP ports on NethServer BUT here’s the thing, I don’t have the firewall module installed.
Should I still open the ports?
Something like this?
config set fw_Openfire service status enabled TCPPort 3478,3479,5222,5223,5229,7070,7443,7777,9090,9091 access public signal-event firewall-adjust
and…
config setprop Openfire status enabled TCPPort 3478,3479,5222,5223,5229,7070,7443,7777,9090,9091 access public
I need Openfire to be accessible from outside, external access.
In NethServer terminology, GREEN and RED.
Another error I found BUT I believe it’s just a syntax error on Openfire:
On the Openfire administration panel, it shows all ports listening on all interfaces, except 5222 and 5223.
I believe this is just a syntax error because nmap properly showed that those ports are open.
Server is behind a router and port forwarding is configured. I’m able to access other services but Openfire.
Am I missing something else here?
Openfire runs on the same ports of ejabberd so if anybody got any ideas on how to solve this, really appreciate it.
NethServer Configuration
Version 6.6. Interactive Installation.
NIC: eth0 only. Standard configuration.
yum upgrade.
Modules Installed: File Server, MySQL Server and Web Server.
Additional Packages: vim, nmap, glibc.i686 and NethServer Password Policies.
PS: As soon as I get this problem solved, I’ll make a proper HOWTO about NethServer+Openfire+OpenLDAP.
Thanks in advance.
Tim.
