Is Openchange enabled/supported in Nethserver?
If not, there is any plan/roadmap to support it?
I’m not a nethserver developer so i speak for myself, but openchange is far from to be ready for a production environment, so imap is the way imho
Hi @gmaoret have you already seen this topic?
Openchange is not directly supported/enabled by/in NethServer but you can install SOGO Groupware in beta to test the Openchange side.
Keep in mind @AbsyntH words.
Nope, i have to contradict you, my friend
Unfortunately there isn’t a support for Opencange/OulookMAPI on the NethServer SOGo implementation, you can use it with
- IMAP + commercial plugin as cfos or outlookdav for calendars/contacts
- ActiveSync only for Oulook 2013
Openchange support is not on the card at the moment
Sorry @gmaoret @AbsyntH @alefattorini
My mistake.
No worries, you have to pay a few beers To us
That’s OK, then I’m going to do many mistakes in the future
I have here an example found whether the well with the nethserver works?Sogo Outlook Native PDF
