I would like to ask if someone of you know an open source MDM and if we could use it under NS ?
Now that would be an interesting functionality. I know Meraki but it is a commercial, cloud based system by cisco. maybe there is something similar available as open source solution…
found:
- https://github.com/osx86/MDM
- https://github.com/jwilkins/mdm
- https://github.com/micromdm/micromdm
- https://github.com/longxing/MDM
- https://github.com/OpenMDM/OpenMDM
Furthermore this one looks interesting:
https://github.com/flyve-mdm/glpi-plugin
It is a plugin for ICT management solution GLPI
IMO it would be ubercool if these 2 could be implemented in NS…
not to mention that it is one of the few options that is actively maintained.
And GLPI is already available because of the effort of our community hero @stephdl https://wiki.nethserver.org/doku.php?id=glpi
More info on the plugin: http://flyve.org/glpi-plugin/
Rob this looks very nice, thank you for the infos.
- FLYVE MDM - How it works
Looking forward to your howto on installing it on NS with the GLPI module…
Only thing that concerns me a bit is the need of an agent running on the mobile device. For corporate mobile devices this isn’t a problem but I see great opportunities in BYOD (bring your own device) environments. But in BYOD scenario’s, an agent running on a personal phone or tablet might be a problem.
This would be the main target for me but lets see how it works…
Is it possible to update GLPI to ver 9.2.1 ?
@stephdl, is it possible to give your GLPI module an update?
I’m based on epel, where I could find the version 9.2.1 @fausp
I found 9.2 in remi repo: https://blog.remirepo.net/post/2017/09/26/GLPI-version-9.2-en
yum --enablerepo=remi,remi-test install glpi
my concern is the remi-test
You need to install php56 , definitively no way
First, you need to install a version of PHP ≥ 5.6, following the Wizard explanation (installation as Single version), then
So is this the end for the Flyve MDM Plugin for GLPI on NethServer ?
My Version:
[root@infra02 ~]# php -r \@phpinfo\(\)\; | grep 'PHP Version' -m 1
PHP Version => 5.4.16
You could look after php ugrade and find if the way is conform to your needs
Normally we use php software collection, but here the rpm calls the php56 as dependencies, therefore no chance to get it easily
Nextcloud shows me:
7.1.8 ?
Nextcloud 13 uses PHP 7.1 via FPM with the package nethserver-rh-php71-php-fpm.
http://php.net/manual/install.fpm.php
You may try to install nethserver-rh-php56-php-fpm and change the glpi httpd conf to use it but I don’t know if it works, never tried:
<FilesMatch \.php$>
SetHandler "proxy:fcgi://127.0.0.1:9000"
</FilesMatch>
Or use php-scl, then you have to set the port to 9056.
I just tried it and it seems to work.
Install everything needed:
yum --enablerepo=remi,remi-test install glpi nethserver-mysql rh-php56-php-mysql rh-php56-php-mbstring rh-php56-php-gd
In the /etc/httpd/conf.d/glpi.conf add the above snippet to the two <directory> directives and allow your clients ip to install:
<Directory /usr/share/glpi>
Options None
AllowOverride Limit Options FileInfo
<IfModule mod_authz_core.c>
Require all granted
</IfModule>
<IfModule !mod_authz_core.c>
Order deny,allow
Allow from all
</IfModule>
<FilesMatch \.php$>
</FilesMatch>
</Directory>
<Directory /usr/share/glpi/install>
# Install is only allowed via local access (from the GLPI server).
# Add your IP address if you need it for remote installation,
# but remember to remove it after installation for security.
# Apache 2.4
Require local
Require ip CLIENT_IP_TO_ALLOW_INSTALLATION
</IfModule>
# Apache 2.2
Order Deny,Allow
Deny from All
Allow from 127.0.0.1
Allow from ::1
</IfModule>
ErrorDocument 403 "<p><b>Restricted area.</b><br />Only local access allowed.<br />Check your configuration or contact your administrator.</p>"
<IfModule mod_php5.c>
# migration could be very long
php_value max_execution_time 0
php_value memory_limit -1
</IfModule>
<FilesMatch \.php$>
</FilesMatch>
</Directory>
Then restart the services:
systemctl restart httpd
systemctl restart rh-php56-php-fpm
Then browse to https://YOURNETHSERVER/glpi and install…
Awesome, you are working like a machine… ![]()
I wil try that out, maybe tomorrow… Thank you very much…
Error: Package: php-sabre-xml-1.5.0-2.el7.remi.noarch (remi)
Requires: php(language) >= 5.5.5
Removing: php-common-5.4.16-43.el7_4.x86_64 (@updates)
php(language) = 5.4.16
Updated By: php-common-5.4.45-14.el7.remi.x86_64 (remi)
php(language) = 5.4.45
Available: php-common-5.4.16-42.el7.x86_64 (base)
Available: php-common-5.4.16-43.el7_4.1.x86_64 (updates)
Available: php-common-5.4.45-13.el7.remi.x86_64 (remi)
Error: Package: php-zendframework-zend-serializer-2.8.1-1.el7.remi.noarch (remi)
Requires: php(language) >= 5.6
sure that your VM is not upgraded to php56, I got this following your commands
[root@infra02 ~]# yum --enablerepo=remi,remi-test install glpi nethserver-mysql rh-php56-php-mysql rh-php56-php-mbstring rh-php56-php-gd
Package Arch Version Repository Size
Installing:
glpi noarch 0.90.5-1.el7 epel 5.9 M
rh-php56-php-gd x86_64 5.6.25-1.el7 centos-sclo-rh 158 k
rh-php56-php-mbstring x86_64 5.6.25-1.el7 centos-sclo-rh 519 k
rh-php56-php-mysqlnd x86_64 5.6.25-1.el7 centos-sclo-rh 185 k
Installing for dependencies:
compat-libtidy x86_64 0.99.0-37.20091203.el7 epel 133 k
gnu-free-fonts-common noarch 20120503-8.el7 base 127 k
gnu-free-sans-fonts noarch 20120503-8.el7 base 1.3 M
libc-client x86_64 2007f-16.el7 epel 562 k
liblzf x86_64 3.6-7.el7 epel 22 k
libvpx x86_64 1.3.0-5.el7_0 base 498 k
php-IDNA_Convert noarch 0.8.0-2.el7 epel 36 k
php-PHPMailer noarch 5.2.26-1.el7 epel 135 k
php-ZendFramework2-Authentication noarch 2.4.11-1.el7 epel 34 k
php-ZendFramework2-Cache noarch 2.4.11-1.el7 epel 76 k
php-ZendFramework2-Captcha noarch 2.4.11-1.el7 epel 18 k
php-ZendFramework2-Code noarch 2.4.11-1.el7 epel 67 k
php-ZendFramework2-Config noarch 2.4.11-1.el7 epel 24 k
php-ZendFramework2-Console noarch 2.4.11-1.el7 epel 40 k
php-ZendFramework2-Crypt noarch 2.4.11-1.el7 epel 34 k
php-ZendFramework2-Db noarch 2.4.11-1.el7 epel 111 k
php-ZendFramework2-Di noarch 2.4.11-1.el7 epel 38 k
php-ZendFramework2-Escaper noarch 2.4.11-1.el7 epel 12 k
php-ZendFramework2-EventManager noarch 2.4.11-1.el7 epel 22 k
php-ZendFramework2-Feed noarch 2.4.11-1.el7 epel 79 k
php-ZendFramework2-Filter noarch 2.4.11-1.el7 epel 50 k
php-ZendFramework2-Form noarch 2.4.11-1.el7 epel 80 k
php-ZendFramework2-Http noarch 2.4.11-1.el7 epel 79 k
php-ZendFramework2-I18n noarch 2.4.11-1.el7 epel 99 k
php-ZendFramework2-InputFilter noarch 2.4.11-1.el7 epel 22 k
php-ZendFramework2-Json noarch 2.4.11-1.el7 epel 34 k
php-ZendFramework2-Ldap noarch 2.4.11-1.el7 epel 50 k
php-ZendFramework2-Loader noarch 2.4.11-1.el7 epel 19 k
php-ZendFramework2-Log noarch 2.4.11-1.el7 epel 38 k
php-ZendFramework2-Mail noarch 2.4.11-1.el7 epel 76 k
php-ZendFramework2-Math noarch 2.4.11-1.el7 epel 18 k
php-ZendFramework2-Mime noarch 2.4.11-1.el7 epel 17 k
php-ZendFramework2-ModuleManager noarch 2.4.11-1.el7 epel 29 k
php-ZendFramework2-Mvc noarch 2.4.11-1.el7 epel 88 k
php-ZendFramework2-Navigation noarch 2.4.11-1.el7 epel 24 k
php-ZendFramework2-Paginator noarch 2.4.11-1.el7 epel 24 k
php-ZendFramework2-Permissions-Acl noarch 2.4.11-1.el7 epel 21 k
php-ZendFramework2-Serializer noarch 2.4.11-1.el7 epel 22 k
php-ZendFramework2-Server noarch 2.4.11-1.el7 epel 24 k
php-ZendFramework2-ServiceManager noarch 2.4.11-1.el7 epel 24 k
php-ZendFramework2-Session noarch 2.4.11-1.el7 epel 37 k
php-ZendFramework2-Stdlib noarch 2.4.11-1.el7 epel 53 k
php-ZendFramework2-Text noarch 2.4.11-1.el7 epel 27 k
php-ZendFramework2-Uri noarch 2.4.11-1.el7 epel 21 k
php-ZendFramework2-Validator noarch 2.4.11-1.el7 epel 120 k
php-ZendFramework2-Version noarch 2.4.11-1.el7 epel 10 k
php-ZendFramework2-View noarch 2.4.11-1.el7 epel 85 k
php-ZendFramework2-common noarch 2.4.11-1.el7 epel 75 k
php-bcmath x86_64 5.4.16-43.el7_4.1 updates 57 k
php-doctrine-annotations noarch 1.2.7-4.el7 epel 28 k
php-doctrine-cache noarch 1.5.4-1.el7 epel 23 k
php-doctrine-collections noarch 1.3.0-2.el7 epel 17 k
php-doctrine-common noarch 2.5.3-3.el7 epel 51 k
php-doctrine-inflector noarch 1.1.0-4.el7 epel 12 k
php-doctrine-lexer noarch 1.0.1-8.el7 epel 9.8 k
php-fedora-autoloader noarch 1.0.0-1.el7 epel 9.6 k
php-gd x86_64 5.4.16-43.el7_4.1 updates 127 k
php-htmLawed noarch 1.1.21-1.el7 epel 102 k
php-imap x86_64 5.4.16-7.el7 epel 38 k
php-ircmaxell-random-lib noarch 1.2.0-1.el7 epel 20 k
php-ircmaxell-security-lib noarch 1.1.0-4.el7 epel 13 k
php-ldap x86_64 5.4.16-43.el7_4.1 updates 52 k
php-mbstring x86_64 5.4.16-43.el7_4.1 updates 505 k
php-mcrypt x86_64 5.4.16-7.el7 epel 20 k
php-mysql x86_64 5.4.16-43.el7_4.1 updates 101 k
php-password-compat noarch 1.0.4-1.el7 epel 10 k
php-pdo x86_64 5.4.16-43.el7_4.1 updates 99 k
php-pear noarch 1:1.9.4-21.el7 base 357 k
php-pear-CAS noarch 1.3.5-1.el7 epel 70 k
php-pecl-igbinary x86_64 1.2.1-1.el7 epel 38 k
php-pecl-lzf x86_64 1.6.2-4.el7 epel 13 k
php-process x86_64 5.4.16-43.el7_4.1 updates 56 k
php-simplepie noarch 1.3.1-4.el7 epel 463 k
php-symfony-class-loader noarch 2.8.12-2.el7 epel 26 k
php-symfony-common noarch 2.8.12-2.el7 epel 124 k
php-tcpdf noarch 6.2.13-1.el7 epel 2.1 M
php-tidy x86_64 5.4.16-7.el7 epel 23 k
php-zendframework-zendxml noarch 1.0.2-2.el7 epel 10 k
php-zetacomponents-base noarch 1.9-2.el7 epel 229 k
php-zetacomponents-graph noarch 1.5.2-3.el7 epel 134 k
rh-php56-php-common x86_64 5.6.25-1.el7 centos-sclo-rh 742 k
rh-php56-php-pdo x86_64 5.6.25-1.el7 centos-sclo-rh 100 k
rh-php56-php-pecl-jsonc x86_64 1.3.6-3.el7 centos-sclo-rh 44 k
rh-php56-runtime x86_64 2.3-1.el7 centos-sclo-rh 1.1 M
t1lib x86_64 5.1.2-14.el7 base 166 k
Transaction Summary
Install 4 Packages (+85 Dependent packages)
Total download size: 18 M
Installed size: 91 M
Is this ok [y/d/N]:
You are right, I missed the remi repo install and so the epel version was taken. My fault. Sorry @fausp, this does not help you. Nethserver requires php54 and gpli wants php56 so I have no solution at the moment.
I know remi (thank to the fosdem) if he uses the php56 and not the software collection (He is one of the best contributors), he surely gets a good reason
