NethServer Version: 7.9
Module: ntopng
Hi everyone, I need some help with ntopng and I hope you guys could give me some hand.
The ntopng was working just fine, but it was showing a message about Geolocation and a link.
I have tried to follow de steps using the MaxMind GeoIP file.
After executing the proccess I was unable to open ntopng in the browser, it shows the error ERR_TOO_MANY_REDIRECTS
lookint into the logs it shows the following content…
The first error seems to be:
Script failure [/usr/share/ntopng/scripts/callbacks/system/startup.lua][…are/ntopng/scripts/lua/modules/recipients/recipients.lua:583: attempt to index a nil value]
the file recipients.lua in the line 583 says:
builtin_recipients_cache = { recipients.get_recipient_by_name(“builtin_recipient_sqlite”).recipient_id }
that recipients.get_recipient_by_name function seems to be returning null
But I have no idea what to do to make it work again.
I already tried to reinstall the application “bandwith monitor”
and also use “yum remove pfring” that I saw in other topic, but no success
Log result:
Mai 13 17:24:12 ns.intraclima.pg systemd[1]: Stopped ntopng high-speed web-based traffic monitoring and analysis tool.
Mai 13 17:24:12 ns.intraclima.pg systemd[1]: Starting ntopng high-speed web-based traffic monitoring and analysis tool…
Mai 13 17:24:12 ns.intraclima.pg systemd[1]: Started ntopng high-speed web-based traffic monitoring and analysis tool.
Mai 13 17:24:12 ns.intraclima.pg ntopng[25963]: 13/May/2021 17:24:12 [Prefs.cpp:1181] Localhost HTTP user login disabled
Mai 13 17:24:12 ns.intraclima.pg ntopng[25963]: 13/May/2021 17:24:12 [Prefs.cpp:1139] ntopng will use redis 127.0.0.1@0
Mai 13 17:24:12 ns.intraclima.pg ntopng[25963]: 13/May/2021 17:24:12 [Ntop.cpp:2347] Setting local networks to 127.0.0.0/8,fe80::/10
Mai 13 17:24:12 ns.intraclima.pg ntopng[25963]: 13/May/2021 17:24:12 [Redis.cpp:157] Successfully connected to redis 127.0.0.1:6378@0
Mai 13 17:24:12 ns.intraclima.pg ntopng[25963]: 13/May/2021 17:24:12 [NtopPro.cpp:320] [LICENSE] Reading license from Redis
Mai 13 17:24:12 ns.intraclima.pg ntopng[25963]: 13/May/2021 17:24:12 [NtopPro.cpp:464] [LICENSE] Unable to validate license [Empty license file]
Mai 13 17:24:12 ns.intraclima.pg ntopng[25963]: [NtopPro.cpp:533] WARNING: [LICENSE] Invalid license [Empty license file]
Mai 13 17:24:12 ns.intraclima.pg ntopng[25963]: [NtopPro.cpp:550] WARNING: [LICENSE] ntopng will now run in Enterprise L edition for 10 minutes
Mai 13 17:24:12 ns.intraclima.pg ntopng[25963]: 13/May/2021 17:24:12 [NtopPro.cpp:533] WARNING: [LICENSE] Invalid license [Empty license file]
Mai 13 17:24:12 ns.intraclima.pg ntopng[25963]: 13/May/2021 17:24:12 [NtopPro.cpp:550] WARNING: [LICENSE] ntopng will now run in Enterprise L edition for 10 minutes
Mai 13 17:24:12 ns.intraclima.pg ntopng[25963]: 13/May/2021 17:24:12 [NtopPro.cpp:552] WARNING: [LICENSE] before returning to community mode
Mai 13 17:24:12 ns.intraclima.pg ntopng[25963]: [NtopPro.cpp:552] WARNING: [LICENSE] before returning to community mode
Mai 13 17:24:12 ns.intraclima.pg ntopng[25963]: 13/May/2021 17:24:12 [NtopPro.cpp:554] WARNING: [LICENSE] You can buy a permanent license at http://shop.ntop.org
Mai 13 17:24:12 ns.intraclima.pg ntopng[25963]: 13/May/2021 17:24:12 [NtopPro.cpp:556] WARNING: [LICENSE] or run ntopng in community mode starting
Mai 13 17:24:12 ns.intraclima.pg ntopng[25963]: 13/May/2021 17:24:12 [NtopPro.cpp:557] WARNING: [LICENSE] ntopng --community
Mai 13 17:24:12 ns.intraclima.pg ntopng[25963]: [NtopPro.cpp:554] WARNING: [LICENSE] You can buy a permanent license at http://shop.ntop.org
Mai 13 17:24:12 ns.intraclima.pg ntopng[25963]: [NtopPro.cpp:556] WARNING: [LICENSE] or run ntopng in community mode starting
Mai 13 17:24:12 ns.intraclima.pg ntopng[25963]: [NtopPro.cpp:557] WARNING: [LICENSE] ntopng --community
Mai 13 17:24:12 ns.intraclima.pg ntopng[25963]: [ViewInterface.cpp:89] WARNING: Empty view interface: “view:all”
Mai 13 17:24:12 ns.intraclima.pg ntopng[25963]: 13/May/2021 17:24:12 [ViewInterface.cpp:89] WARNING: Empty view interface: “view:all”
Mai 13 17:24:12 ns.intraclima.pg ntopng[25963]: 13/May/2021 17:24:12 [Ntop.cpp:2452] Registered interface view:all [id: 2]
Mai 13 17:24:12 ns.intraclima.pg ntopng[25963]: 13/May/2021 17:24:12 [main.cpp:312] PID stored in file /var/run/ntopng.pid
Mai 13 17:24:12 ns.intraclima.pg ntopng[25963]: 13/May/2021 17:24:12 [Geolocation.cpp:140] Loaded database GeoLite2-ASN.mmdb [/usr/share/GeoIP/GeoLite2-ASN.mmdb][ip_version: 6]
Mai 13 17:24:12 ns.intraclima.pg ntopng[25963]: 13/May/2021 17:24:12 [Geolocation.cpp:140] Loaded database GeoLite2-City.mmdb [/usr/share/GeoIP/GeoLite2-City.mmdb][ip_version: 6]
Mai 13 17:24:12 ns.intraclima.pg ntopng[25963]: 13/May/2021 17:24:12 [Geolocation.cpp:60] Using geolocation provided by MaxMind (https://maxmind.com)
Mai 13 17:24:12 ns.intraclima.pg ntopng[25963]: 13/May/2021 17:24:12 [HTTPserver.cpp:1554] Web server dirs [/usr/share/ntopng/httpdocs][//scripts]
Mai 13 17:24:12 ns.intraclima.pg ntopng[25963]: 13/May/2021 17:24:12 [HTTPserver.cpp:1557] HTTP server listening on 3000
Mai 13 17:24:12 ns.intraclima.pg ntopng[25963]: 13/May/2021 17:24:12 [Utils.cpp:764] User changed to ntopng
Mai 13 17:24:12 ns.intraclima.pg ntopng[25963]: 13/May/2021 17:24:12 [main.cpp:382] Working directory: /var/lib/ntopng
Mai 13 17:24:12 ns.intraclima.pg ntopng[25963]: 13/May/2021 17:24:12 [main.cpp:384] Scripts/HTML pages directory: /usr/share/ntopng
Mai 13 17:24:12 ns.intraclima.pg ntopng[25963]: 13/May/2021 17:24:12 [Ntop.cpp:440] Welcome to ntopng x86_64 v.4.2.210510 - © 1998-20 ntop.org
Mai 13 17:24:12 ns.intraclima.pg ntopng[25963]: 13/May/2021 17:24:12 [NtopPro.cpp:741] [LICENSE] System Id: 5E6B074600100F28
Mai 13 17:24:12 ns.intraclima.pg ntopng[25963]: 13/May/2021 17:24:12 [NtopPro.cpp:742] [LICENSE] Edition: Enterprise L (Bundle)
Mai 13 17:24:12 ns.intraclima.pg ntopng[25963]: 13/May/2021 17:24:12 [NtopPro.cpp:743] [LICENSE] License Type: Time-Limited [Empty license file] License
Mai 13 17:24:12 ns.intraclima.pg ntopng[25963]: 13/May/2021 17:24:12 [NtopPro.cpp:763] [LICENSE] Validity: Until Thu May 13 17:34:12 2021
Mai 13 17:24:12 ns.intraclima.pg ntopng[25963]: 13/May/2021 17:24:12 [PeriodicActivities.cpp:107] Started periodic activities loop…
Mai 13 17:24:13 ns.intraclima.pg ntopng[25963]: 13/May/2021 17:24:13 [startup.lua:50] Processing startup.lua: please hold on…
Mai 13 17:24:14 ns.intraclima.pg ntopng[25963]: 13/May/2021 17:24:14 [startup.lua:144] [lists_utils.lua:758] Refreshing category lists…
Mai 13 17:24:14 ns.intraclima.pg ntopng[25963]: 13/May/2021 17:24:14 [startup.lua:144] [lists_utils.lua:696] Category Lists (695 hosts, 3614 IPs, 98 JA3) loaded in 0 sec
Mai 13 17:24:14 ns.intraclima.pg ntopng[25963]: [LuaEngine.cpp:363] WARNING: Script failure [/usr/share/ntopng/scripts/callbacks/system/startup.lua][…are/ntopng/scripts/lua/modules/recipients/recipients.lua:583: attempt to index a nil value]
Mai 13 17:24:14 ns.intraclima.pg ntopng[25963]: 13/May/2021 17:24:14 [LuaEngine.cpp:363] WARNING: Script failure [/usr/share/ntopng/scripts/callbacks/system/startup.lua][…are/ntopng/scripts/lua/modules/recipients/recipients.lua:583: attempt to index a nil value]
Mai 13 17:24:14 ns.intraclima.pg ntopng[25963]: 13/May/2021 17:24:14 [PeriodicActivities.cpp:168] Each periodic activity script will use 2 threads
Mai 13 17:24:14 ns.intraclima.pg ntopng[25963]: 13/May/2021 17:24:14 [NetworkInterface.cpp:2749] Started packet polling on interface view:all [id: 2]…
Mai 13 17:25:00 ns.intraclima.pg ntopng[25963]: [LuaEngine.cpp:363] WARNING: Script failure [/usr/share/ntopng/scripts/callbacks/interface/5min.lua][…are/ntopng/scripts/lua/modules/recipients/recipients.lua:583: attempt to index a nil value]
Mai 13 17:25:00 ns.intraclima.pg ntopng[25963]: 13/May/2021 17:25:00 [LuaEngine.cpp:363] WARNING: Script failure [/usr/share/ntopng/scripts/callbacks/interface/5min.lua][…are/ntopng/scripts/lua/modules/recipients/recipients.lua:583: attempt to index a nil value]
Mai 13 17:25:00 ns.intraclima.pg ntopng[25963]: [LuaEngine.cpp:329] WARNING: Script failure [//scripts/callbacks/system/system.lua][cannot open //scripts/callbacks/system/system.lua: No such file or directory]
Mai 13 17:25:00 ns.intraclima.pg ntopng[25963]: 13/May/2021 17:25:00 [LuaEngine.cpp:329] WARNING: Script failure [//scripts/callbacks/system/system.lua][cannot open //scripts/callbacks/system/system.lua: No such file or directory]
Mai 13 17:25:05 ns.intraclima.pg ntopng[25963]: [LuaEngine.cpp:329] WARNING: Script failure [//scripts/callbacks/interface/interface.lua][cannot open //scripts/callbacks/interface/interface.lua: No such file or directory]
Mai 13 17:25:05 ns.intraclima.pg ntopng[25963]: 13/May/2021 17:25:05 [LuaEngine.cpp:329] WARNING: Script failure [//scripts/callbacks/interface/interface.lua][cannot open //scripts/callbacks/interface/interface.lua: No such file or directory]
Mai 13 17:25:05 ns.intraclima.pg ntopng[25963]: [LuaEngine.cpp:329] WARNING: Script failure [//scripts/callbacks/interface/network.lua][cannot open //scripts/callbacks/interface/network.lua: No such file or directory]
Mai 13 17:25:05 ns.intraclima.pg ntopng[25963]: 13/May/2021 17:25:05 [LuaEngine.cpp:329] WARNING: Script failure [//scripts/callbacks/interface/network.lua][cannot open //scripts/callbacks/interface/network.lua: No such file or directory]
Mai 13 17:25:05 ns.intraclima.pg ntopng[25963]: [LuaEngine.cpp:329] WARNING: Script failure [//scripts/callbacks/interface/host.lua][cannot open //scripts/callbacks/interface/host.lua: No such file or directory]
Mai 13 17:25:05 ns.intraclima.pg ntopng[25963]: 13/May/2021 17:25:05 [LuaEngine.cpp:329] WARNING: Script failure [//scripts/callbacks/interface/host.lua][cannot open //scripts/callbacks/interface/host.lua: No such file or directory]
Mai 13 17:25:07 ns.intraclima.pg ntopng[25963]: [LuaEngine.cpp:329] WARNING: Script failure [//scripts/callbacks/system/snmp_device.lua][cannot open //scripts/callbacks/system/snmp_device.lua: No such file or directory]
Mai 13 17:25:07 ns.intraclima.pg ntopng[25963]: 13/May/2021 17:25:07 [LuaEngine.cpp:329] WARNING: Script failure [//scripts/callbacks/system/snmp_device.lua][cannot open //scripts/callbacks/system/snmp_device.lua: No such file or directory]
