NS8 +SAMBA on VPS - Add virtual interface
I am currently installing NS8 under Debian 12 on a vhost. When setting up SAMBA inclussive shares it asks for an IP address. Since I only have the WAN address, I need an additional internal one.
How do I do this? There is no dialogue in the GUI and I would have to do this on the command line.
ip addr shows me
root@mdol-ns8:~# ip addr show
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
    inet 127.0.0.1/8 scope host lo
       valid_lft forever preferred_lft forever
    inet6 ::1/128 scope host noprefixroute
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
    link/ether 76:37:e1:f2:75:d0 brd ff:ff:ff:ff:ff:ff
    altname enp0s3
    altname ens3
    inet 88.57.42.223/22 brd 88.57.42.255 scope global eth0
    inet6 2a03:4000:66:134:7437:e1ff:fef2:75d0/64 scope global
    inet6 fe80::7437:e1ff:fef2:75d0/64 scope link
3: wg0: <POINTOPOINT,NOARP,UP,LOWER_UP> mtu 1420 qdisc noqueue state UNKNOWN group default qlen 1000
    link/none
    inet 10.5.4.1/32 scope global wg0
cat /etc/network/interfaces shows me
# This file describes the network interfaces available on your system
# and how to activate them. For more information, see interfaces(5).
source /etc/network/interfaces.d/*
# The loopback network interface
auto lo
iface lo inet loopback
# The primary network interface
allow-hotplug ens3
Is it right to do:
nano /etc/network/interfaces
auto eth0
iface eth0 inet static
    address 88.57.42.223
    netmask 255.255.252.0
    gateway 88.56.41.1
    address 192.168.1.10
    netmask 255.255.255.0
and finally:
systemctl restart networking
or better:
auto lo
allow-hotplug ens3
iface ens3 inet dhcp
# Additional internal IP address
auto ens3:0
iface ens3:0 inet static
I think the best way is to add a virtual dummy interface as we did in NS7.
Debian instructions
To add the dummy interface either create the file /etc/network/interfaces.d/dummy or just use the file /etc/network/interfaces to add the following:
auto dummy0
iface dummy0 inet static
pre-up ip link add dummy0 type dummy
post-down ip link delete dummy0
To setiü loading the dummy module at boot, execute following command:
echo dummy > /etc/modules-load.d/dummy.conf
To load the module now:
modprobe dummy
To restart the network:
Check interfaces:
ip a
The new dummy interface should be there.
RHEL instructions
Instructions for RHEL Distros like Rocky and Alma about the creation of the virtual interface are in the old wiki.
I corrected the instructions and added
to the dummy interface to correctly remove dummy0, else restarting the network won’t work.
thank you, it works perfectly.
