NS8-N8N App ready, with a few validation issues
ok, thank you,
and what does this error mean
2024-01-30T07:25:07+03:00 [3:n8n2:conmon] conmon ef2bae8fe46ec74494b4 <nwarn>: Failed to open cgroups file: /sys/fs/cgroup/user.slice/user-1006.slice/user@1006.service/user.slice/user-libpod_pod_b91fad370f57b6e1522f7d1530a36e158f52ff63137b226b635d2b1d7bd4daa7.slice/libpod-ef2bae8fe46ec74494b449bc0507163c69564872400bb64e724272fda882b88f.scope/container/memory.events
Relevant to a pod but when you start and configure the services the first time it is easier to find the first error
ok,
what about these erros
2024-01-30T10:51:28+03:00 [3:n8n3:n8n-redis] 1:M 30 Jan 2024 07:51:28.255 * Ready to accept connections tcp
2024-01-30T10:51:28+03:00 [3:n8n3:runagent] Traceback (most recent call last):
2024-01-30T10:51:28+03:00 [3:n8n3:runagent]   File "<frozen os>", line 574, in execvp
2024-01-30T10:51:28+03:00 [3:n8n3:runagent]   File "<frozen os>", line 607, in _execvpe
2024-01-30T10:51:28+03:00 [3:n8n3:systemd] n8n-server.service: Control process exited, code=exited, status=1/FAILURE
file frozen os in execvp and in _execvpe
Just to be clear, for I am also waisting time, are you now working with a posix dev environment and NOT on a Winblows environment?
Hello Laylow, I actually deployed vscode on a Linux dev box. And that’s what am using to dev.
After Countless and Numerous Errors, and many lessons learnt as well.
I am happy to report that the N8N module is now ready for use…
Feature Announcement Here: NS8-n8n: Nodemation module - Feature - NethServer Community
Is there anyway to update the version of n8n that comes with ns8?
Current installed version is v1.50.1 and there’s a warning nudging an update to v2.0.2
I’m going to work on a NethForge version of n8n and hope to provide an update soon.
Thank you. Also let me know if there’s anything I can do to help out
will update too latest version this weekend
hello
help in testing n8n
add-module ghcr.io/geniusdynamics/n8n:dev 1
Sorry to keep you outdated
Test backup , configuration and restoration
I will test later tonight and provide feedback. I haven’t implemented any workflow on my instance (still getting the hang of n8n) so I doubt there’d be any value in backup and restore
Okay sure will appreciate
Currently adding external worker
Not sure if I’m doing something wrong. But I’m still getting v1.50.1
Hello @airsay
use this for installing
Test installation, backup and restore
Aleady did that before my last post. It still shows Version 1.0.6
Just for info, the add-module command installs a new app instance of n8n, it doesn’t update your current version.
I get that. I uninstalled my previous instance of n8n, ran the command add-module ghcr.io/geniusdynamics/n8n:dev 1 refreshed repository on the ns8 GUI, then installed n8n from the GUI. I visited the URL, went to the newly installed instance, and it pops up to update to v2.1 from v1.50.1
So its okay now
No it isn’t. My current re-installed instance:
