NS8 Crowdsec questions
I’m using NS8 on Debian together With Nethsecurity.
I was using Fail2ban in ClearOS en NS7 which normally blocked 5-10 IP’s per day. Mainly on Postfix since this is one of the few open ports
Now i see after a few days that Crowdsec has not blocked any IP on Postfix
This doesn make me feel very confident with NS8 security
Is there maybe a setting not correct in my setup ?
--------- 2 ---------
How to i get the token for Crowdsec. On the website of Crowdsec i cannot find this, or is it only for paid users ?
--------- 3 ---------
Is it possible to extend the ban time.
600 minutes is for my feeling to short
Recently I’ve seen a report of a bug regarding crowdsec and nextcloud (an older one with other modules: Crowdsec not banning) but unaware if something similar happens with postfix.
ns8-crowdsec readme.
Maybe a run of crowdsec’s cscli explain can bring some light on what happens when it processes the postfix log.
runagent -m crowdsec1 cscli explain --file "dontknowthepathtopostfixlogfile" --type <typecorrespondingtopostfix-maybe-syslog-or-maybe-not>  # or --log instead of file to specify a line
…or similar.
extended ban time: should be possible form command line but better if devs tweak the UI, if your request is considered valid.
You can sign-up for free (see pricing for feature comparison) and get your enrollment key (creating an account on https://app.crowdsec.net)
Interesting topic
Fai2lban is became stronger bugs after bugs because people has tested it and reviewed it
I know it because I started it on my own
Maybe your IP was known and thus tested by hackers but with a new IP you have less popularity … who knows
You have to parse and watch your logs or attempt to do yourself brute force login against your services
Honestly I do not see much interest, a machine is never bored to do thing again and again. So when the IP will be released a new ban will occur
What is the issue ?
Furthermore crowdsec uses a dynamic bantime so first ban is x minutes, second bans is 2X x minutes etc
Agree, interested in motivation.
Every attack is a change, so why don’t try to avoid it with a longer periode
Also how much effort is it to change the value in the UI to a large number
Then we can choose our self
My IP has not changed
How can i do this test
Thanks for your support
-Search in your log first you will see brute force attempts
-do bad login to smtp and imap/pop3 with thunderbird or use curl to simulate it
https://wiki.nethserver.org/doku.php?id=curl_howto
Shot in the dark here…
see last line
Oct 08 22:06:57 R2-pve.rocky9-pve2.org crowdsec1-firewall-bouncer[22478]: time=“2024-10-08T20:06:57Z” level=info msg=“1 decision added”
Oct 08 22:06:56 R2-pve.rocky9-pve2.org postfix/smtpd[23708]: warning: leo-stephdl-dynu-net.stephdl.dynu.net[192.168.13.25]: SASL PLAIN authentication failed: (reason unavailable), sasl_username=stephane
Oct 08 22:06:56 R2-pve.rocky9-pve2.org postfix/smtpd[23708]: lost connection after AUTH from leo-stephdl-dynu-net.stephdl.dynu.net[192.168.13.25]
Oct 08 22:06:56 R2-pve.rocky9-pve2.org postfix/smtpd[23708]: disconnect from leo-stephdl-dynu-net.stephdl.dynu.net[192.168.13.25] ehlo=2 starttls=1 auth=0/1 commands=3/4
Oct 08 22:06:56 R2-pve.rocky9-pve2.org rspamd[1934]: (rspamd_proxy) <676bee>; milter; rspamd_milter_process_command: got connection from 192.168.13.25:35806
Oct 08 22:06:56 R2-pve.rocky9-pve2.org rspamd[1934]: (rspamd_proxy) <676bee>; proxy; proxy_milter_finish_handler: finished milter connection
Oct 08 22:06:56 R2-pve.rocky9-pve2.org crowdsec1[22917]: time="2024-10-08T20:06:56Z" level=info msg="Ip 192.168.13.25 performed 'crowdsecurity/postfix-spam' (7 events over 19.250864434s) at 2024-10-08 20:06:56.638141212 +0000 UTC"
Oct 08 22:06:56 R2-pve.rocky9-pve2.org crowdsec1[22917]: time="2024-10-08T20:06:56Z" level=info msg="(localhost/crowdsec) crowdsecurity/postfix-spam by ip 192.168.13.25 : 8m ban on Ip 192.168.13.25"
Oct 08 22:06:56 R2-pve.rocky9-pve2.org crowdsec1[22917]: time="2024-10-08T20:06:56Z" level=info msg="127.0.0.1 - [Tue, 08 Oct 2024 20:06:56 UTC] \"POST /v1/alerts HTTP/1.1 201 2.635751ms \"crowdsec/v1.6.3-4851945a-docker\" \""
Oct 08 22:06:57 R2-pve.rocky9-pve2.org crowdsec1[22917]: time="2024-10-08T20:06:57Z" level=info msg="127.0.0.1 - [Tue, 08 Oct 2024 20:06:57 UTC] \"GET /v1/decisions/stream HTTP/1.1 200 5.757288ms \"crowdsec-firewall-bouncer/v0.0.28-debian-pragmatic-af6e7e25822c2b1a02168b99ebbf8458bc6728e5\" \""
Oct 08 22:06:57 R2-pve.rocky9-pve2.org crowdsec1-firewall-bouncer[22478]: time="2024-10-08T20:06:57Z" level=info msg="1 decision added"
curl -k -n --ssl-reqd --url "smtp://rocky9-pve2.org:587" --mail-from stephane@de-labrusse.fr --mail-rcpt stephane@rocky9-pve2.org --upload-file /dev/null -u 'stephane@rocky9-pve2.org':'password' -v
see the last line
wall-bouncer/v0.0.28-debian-pragmatic-af6e7e25822c2b1a02168b99ebbf8458bc6728e5" ""
Oct 08 22:36:57 R2-pve.rocky9-pve2.org crowdsec1-firewall-bouncer[22478]: time=“2024-10-08T20:36:57Z” level=info msg=“1 decision added”
Oct 08 22:36:47 R2-pve.rocky9-pve2.org samba-dc[1894]: Auth: [LDAP,simple bind/TLS] user [ROCKY9-PVE2]\[ldapservice@ad.rocky9-pve2.org] at [Tue, 08 Oct 2024 20:36:47.451935 UTC] with [Plaintext] status [NT_STATUS_OK] workstation [DC1] remote host [ipv4:192.168.12.111:47818] became [ROCKY9-PVE2]\[ldapservice] [S-1-5-21-4246221167-834095538-3919285230-1103]. local host [ipv4:192.168.12.111:636]
Oct 08 22:36:47 R2-pve.rocky9-pve2.org samba-dc[1894]: TLS ../../source4/lib/tls/tls_tstream.c:1378 - Decryption has failed.
Oct 08 22:36:47 R2-pve.rocky9-pve2.org samba-dc[1894]: Auth: [LDAP,simple bind/TLS] user [ROCKY9-PVE2]\[CN=stephane,CN=Users,DC=ad,DC=rocky9-pve2,DC=org] at [Tue, 08 Oct 2024 20:36:47.496345 UTC] with [Plaintext] status [NT_STATUS_WRONG_PASSWORD] workstation [DC1] remote host [ipv4:192.168.12.111:47818] mapped to [ROCKY9-PVE2]\[stephane]. local host [ipv4:192.168.12.111:636]
Oct 08 22:36:47 R2-pve.rocky9-pve2.org dovecot[23491]: auth-worker(88): conn unix:auth-worker (pid=86,uid=90): auth-worker<2>: ldap(stephane,192.168.13.25,<xjxoGP0jmIfAqA0Z>): Password mismatch (for LDAP bind)
Oct 08 22:36:49 R2-pve.rocky9-pve2.org dovecot[23491]: imap-login: Disconnected: Connection closed (auth failed, 1 attempts in 6 secs): user=<stephane>, method=PLAIN, rip=192.168.13.25, lip=192.168.12.111, TLS, session=<xjxoGP0jmIfAqA0Z>
Oct 08 22:36:49 R2-pve.rocky9-pve2.org crowdsec1[22917]: time="2024-10-08T20:36:49Z" level=info msg="Ip 192.168.13.25 performed 'crowdsecurity/dovecot-spam' (4 events over 8.498841924s) at 2024-10-08 20:36:49.387145739 +0000 UTC"
Oct 08 22:36:49 R2-pve.rocky9-pve2.org crowdsec1[22917]: time="2024-10-08T20:36:49Z" level=info msg="(localhost/crowdsec) crowdsecurity/dovecot-spam by ip 192.168.13.25 : 12m ban on Ip 192.168.13.25"
Oct 08 22:36:49 R2-pve.rocky9-pve2.org crowdsec1[22917]: time="2024-10-08T20:36:49Z" level=info msg="127.0.0.1 - [Tue, 08 Oct 2024 20:36:49 UTC] \"POST /v1/alerts HTTP/1.1 201 2.491463ms \"crowdsec/v1.6.3-4851945a-docker\" \""
Oct 08 22:36:50 R2-pve.rocky9-pve2.org crowdsec1[22917]: time="2024-10-08T20:36:50Z" level=info msg="127.0.0.1 - [Tue, 08 Oct 2024 20:36:50 UTC] \"GET /v1/heartbeat HTTP/1.1 200 211.855µs \"crowdsec/v1.6.3-4851945a-docker\" \""
Oct 08 22:36:54 R2-pve.rocky9-pve2.org crowdsec1[22917]: time="2024-10-08T20:36:54Z" level=info msg="Signal push: 1 signals to push"
Oct 08 22:36:57 R2-pve.rocky9-pve2.org crowdsec1[22917]: time="2024-10-08T20:36:57Z" level=info msg="127.0.0.1 - [Tue, 08 Oct 2024 20:36:57 UTC] \"GET /v1/decisions/stream HTTP/1.1 200 6.620503ms \"crowdsec-firewall-bouncer/v0.0.28-debian-pragmatic-af6e7e25822c2b1a02168b99ebbf8458bc6728e5\" \""
Oct 08 22:36:57 R2-pve.rocky9-pve2.org crowdsec1-firewall-bouncer[22478]: time="2024-10-08T20:36:57Z" level=info msg="1 decision added"
curl -kv imaps://stephane:password@rocky9-pve2.org
Thanks guys. Still not succeeded in a good test, but will try it again
I see the following error in the log
2024-10-10T19:04:03+02:00 [1:loki1:loki-server] level=error ts=2024-10-10T17:04:03.287282692Z caller=retry.go:73 org_id=fake traceID=5a7721e0b742f734 msg="error processing request" try=0 query="{node_id=\"1\"} | json syslog_id=\"SYSLOG_IDENTIFIER\",message=\"MESSAGE\" | line_format \"[{{.node_id}}:{{.module_id}}:{{.syslog_id}}] {{.message}}\" |= \"crowd\"" err="could not acquire work: context canceled"
2024-10-10T19:04:03+02:00 [1:loki1:loki-server] level=error ts=2024-10-10T17:04:03.287305384Z caller=retry.go:73 org_id=fake traceID=5a7721e0b742f734 msg="error processing request" try=0 query="{node_id=\"1\"} | json syslog_id=\"SYSLOG_IDENTIFIER\",message=\"MESSAGE\" | line_format \"[{{.node_id}}:{{.module_id}}:{{.syslog_id}}] {{.message}}\" |= \"crowd\"" err="could not acquire work: context canceled"
2024-10-10T19:04:03+02:00 [1:loki1:loki-server] level=error ts=2024-10-10T17:04:03.287328153Z caller=retry.go:73 org_id=fake traceID=5a7721e0b742f734 msg="error processing request" try=0 query="{node_id=\"1\"} | json syslog_id=\"SYSLOG_IDENTIFIER\",message=\"MESSAGE\" | line_format \"[{{.node_id}}:{{.module_id}}:{{.syslog_id}}] {{.message}}\" |= \"crowd\"" err="could not acquire work: context canceled"
2024-10-10T19:04:03+02:00 [1:loki1:loki-server] level=error ts=2024-10-10T17:04:03.287344035Z caller=retry.go:73 org_id=fake traceID=5a7721e0b742f734 msg="error processing request" try=0 query="{node_id=\"1\"} | json syslog_id=\"SYSLOG_IDENTIFIER\",message=\"MESSAGE\" | line_format \"[{{.node_id}}:{{.module_id}}:{{.syslog_id}}] {{.message}}\" |= \"crowd\"" err="could not acquire work: context canceled"
2024-10-10T19:04:03+02:00 [1:loki1:loki-server] level=error ts=2024-10-10T17:04:03.288135147Z caller=retry.go:73 org_id=fake traceID=5a7721e0b742f734 msg="error processing request" try=0 query="{node_id=\"1\"} | json syslog_id=\"SYSLOG_IDENTIFIER\",message=\"MESSAGE\" | line_format \"[{{.node_id}}:{{.module_id}}:{{.syslog_id}}] {{.message}}\" |= \"crowd\"" err="context canceled"
2024-10-10T19:04:03+02:00 [1:loki1:loki-server] level=error ts=2024-10-10T17:04:03.28821734Z caller=retry.go:73 org_id=fake traceID=5a7721e0b742f734 msg="error processing request" try=0 query="{node_id=\"1\"} | json syslog_id=\"SYSLOG_IDENTIFIER\",message=\"MESSAGE\" | line_format \"[{{.node_id}}:{{.module_id}}:{{.syslog_id}}] {{.message}}\" |= \"crowd\"" err="context canceled"
2024-10-10T19:04:03+02:00 [1:loki1:loki-server] level=error ts=2024-10-10T17:04:03.288277671Z caller=retry.go:73 org_id=fake traceID=5a7721e0b742f734 msg="error processing request" try=0 query="{node_id=\"1\"} | json syslog_id=\"SYSLOG_IDENTIFIER\",message=\"MESSAGE\" | line_format \"[{{.node_id}}:{{.module_id}}:{{.syslog_id}}] {{.message}}\" |= \"crowd\"" err="context canceled"
2024-10-10T19:04:03+02:00 [1:loki1:loki-server] level=error ts=2024-10-10T17:04:03.291205054Z caller=retry.go:73 org_id=fake traceID=5a7721e0b742f734 msg="error processing request" try=0 query="{node_id=\"1\"} | json syslog_id=\"SYSLOG_IDENTIFIER\",message=\"MESSAGE\" | line_format \"[{{.node_id}}:{{.module_id}}:{{.syslog_id}}] {{.message}}\" |= \"crowd\"" err="could not acquire work: context canceled"
2024-10-10T19:04:03+02:00 [1:loki1:loki-server] level=error ts=2024-10-10T17:04:03.291293837Z caller=retry.go:73 org_id=fake traceID=5a7721e0b742f734 msg="error processing request" try=0 query="{node_id=\"1\"} | json syslog_id=\"SYSLOG_IDENTIFIER\",message=\"MESSAGE\" | line_format \"[{{.node_id}}:{{.module_id}}:{{.syslog_id}}] {{.message}}\" |= \"crowd\"" err="could not acquire work: context canceled"
2024-10-10T19:04:03+02:00 [1:loki1:loki-server] level=error ts=2024-10-10T17:04:03.291327914Z caller=retry.go:73 org_id=fake traceID=5a7721e0b742f734 msg="error processing request" try=0 query="{node_id=\"1\"} | json syslog_id=\"SYSLOG_IDENTIFIER\",message=\"MESSAGE\" | line_format \"[{{.node_id}}:{{.module_id}}:{{.syslog_id}}] {{.message}}\" |= \"crowd\"" err="could not acquire work: context canceled"
What is ithis ?
I think this has been overlooked in the mix of questions.
Form the CLI it can be done as described here.
Thanks. That helps.
Still more configuration options in the UI would be great
It is now very lean
An other question which is a bit on topic
During installation I remove the Crowdsec instance to start a new clean instance
After creating a new Crowdsec instance it create Crowdsec2
Not a big problem but all commands etc… are with Crowsec1
Is it possible to rename the instance to Crowdsec1 :yum:
The question is as old as Nethserver 8 itself.
Here yo can find the answer.
deleted.
I recently moved my mail server from a (very,very old) ClearOS to NS8. My compliments to the authors, works like a charm. I’m now an enthusiastic new ns8 advocate.
However on the ClearOS box i had fail2ban running, which would ban an IP after 3 failed attempts for 72 hours and ban the same IP for 1 year after 3 bans. Inspecting the f2b log collected over several years would not show a single IP with more than 10 attempts. Running crowdsec I saw after a few weeks IPs with 43 or 45 attempts. Personally, I believe that is quite lenient to the serial offenders behind those IPs. I would be in favor of MadPatrick’s suggestion to allow for a much longer ban time, be it through the GUI or some config file.
A sloppy workaround I’ve found so far is to edit /var/lib/nethserver/crowdsec1/bin/expand-configuration which creates the ……../profiles.yaml.local configuration file on container startup, setting ban time to 3 days:
It will survive a container restart, but probably not a software update or an update from the GUI (didn’t try) but does appear to work:
Anybody any better idea ?
hello @jos
not a big fan of this solution, I am personally a lazzy guy and I have no time to answer after my family and offer support to unban people. the dynamical ban gives me the flexible way to ban the annoying guys any time more longer when they come back and allow the others to make an error.
set the the dynamic ban to 600 minutes and you will send in jail for a long time I bet
