Crowdsec not banning
I sent 30 failed login attempts through a vpn to cluster-admin, and 15 failed dovecot authentications within a few minutes without ban. What are some things I can do to test further and fix this?
OS Rocky 9
There’s a bug filed here
hello @peter1
Maybe you could help the NS8 development by performing a QA
to install it on a VM, enable the testing repo, or update the module
api-cli run update-module --data '{"module_url":"ghcr.io/nethserver/crowdsec:1.0.7-dev.1","instances":["crowdsec1"],"force":true}'
if you agreed I can give some guidances on what to test
Tested the crowdsec upgrade to 1.7.0-dev.1 and ssh bruteforce gets banned now and it’s all viewable in the crowdsec web app. :+1:
Can you follow the other QA please
thanks a lot @mrmarkuz :smiley:
One step more in the world of container, now the bouncer itself is a container, no more deb or rpm installed on the host
Please some braves to break it
I did an update on 2 nodes of a Debian NS8 cluster and it’s just working and banning IPs as expected. :+1:
