I am not able to install on CentOS 6.6
I followed the guide in Nethserver docs. Please refer the below log and suggest.
I installed CentOS 6.6 fresh install., Updated.
root@rcloud rtadmin]# yum localinstall -y http://mirror.nethserver.org/nethserver/nethserver-release-6.6.rpm
Loaded plugins: fastestmirror, refresh-packagekit, security
Setting up Local Package Process
nethserver-release-6.6.rpm | 24 kB 00:00
Examining /var/tmp/yum-root-L6i14l/nethserver-release-6.6.rpm: nethserver-release-6.6-2.ns6.noarch
/var/tmp/yum-root-L6i14l/nethserver-release-6.6.rpm: does not update installed package.
Nothing to do
[root@rcloud rtadmin]# nethserver-install
Starting installation process. It will take a while…
Installing base system…
Setting up Install Process
Error: Cannot find a valid baseurl for repo: centos-base
Could not retrieve mirrorlist http://mirrorlist.nethserver.org/6.6/centos?release=6&repo=os&arch=i386 error was
14: PYCURL ERROR 22 - "The requested URL returned error: 404 Not Found"
Configuring system, please wait…
/usr/sbin/nethserver-install: line 45: /sbin/e-smith/signal-event: No such file or directory
You can access the Web interface at:
/usr/sbin/nethserver-install: line 51: /sbin/e-smith/db: No such file or directory
/usr/sbin/nethserver-install: line 52: /sbin/e-smith/db: No such file or directory
https://.:980/usr/sbin/nethserver-install: line 48: /sbin/e-smith/db: No such file or directory
Login: root
Password: <your_root_password>
Installation log can be found here: /var/log/nethserver-install.log
[root@rcloud rtadmin]# yum update
Setting up Update Process
[root@rcloud rtadmin]# yum localinstall http://mirror.nethserver.org/nethserver/nethserver-release-6.6.rpm -y
Nothing to do
Login: root
[root@rcloud rtadmin]# cat /var/log/nethserver-install.log
Sat May 30 19:08:20 IST 2015 Starting installation
Sat May 30 19:08:20 IST 2015 rpm --import /etc/pki/rpm-gpg/
Sat May 30 19:08:21 IST 2015 yum --disablerepo=* --enablerepo=nethserver-base,nethserver-updates,centos-base,centos-updates install @nethserver-iso -y
Sat May 30 19:08:22 IST 2015 /sbin/e-smith/signal-event system-init
Sat May 30 19:08:22 IST 2015 End
Sat May 30 19:13:40 IST 2015 Starting installation
Sat May 30 19:13:40 IST 2015 rpm --import /etc/pki/rpm-gpg/*
Sat May 30 19:13:40 IST 2015 yum --disablerepo=* --enablerepo=nethserver-base,nethserver-updates,centos-base,centos-updates install @nethserver-iso -y
Sat May 30 19:13:41 IST 2015 /sbin/e-smith/signal-event system-init
Sat May 30 19:13:41 IST 2015 End*
