lorentedford
(Loren Tedford (Kc9Zhv))
July 15, 2017, 8:09pm
1
I was trying to install some dependencies for my minecraft server on nethserver 6.8 and I have run into an issue with my new program where my dependencies are not willing to install… However they seem to install on the other distros is it possible we are running a stripped down version of epel?
[root@webserver McMyAdmin]# yum install socat tmux
Loaded plugins: changelog, fastestmirror, nethserver_events, presto
Setting up Install Process
* centos-base: ca.mirror.babylon.network
* centos-updates: mirror.gpmidi.net
* nethserver-base: mirror.nethserver.org
* nethserver-updates: mirror.nethserver.org
No package socat available.
No package tmux available.
Error: Nothing to do
[root@webserver McMyAdmin]# yum install epel-release
* centos-base: mirror.gpmidi.net
Nothing to do
Here is my directions for my webfrontend for minecraft server…
https://cubecoders.com/AMPDownload
Any thoughts?
dnutan
(Marc)
July 15, 2017, 8:32pm
2
The epel-release package can be found in Centos-Extras repository, which is disabled on NethServer 6.
yum --enablerepo=extras install epel-release
You may consider disabling the epel repo afterwards as updates could bring conflicting packages.
lorentedford
July 15, 2017, 8:35pm
3
lorentedford:
That didn’t seem to work got any other ideas?
[root@webserver ~]# yum --enablerepo=extras install epel-release
* centos-updates: mirror2.evolution-host.com
* extras: ca.mirror.babylon.network
Package epel-release-6-8.noarch already installed and latest version
Nothing to do
[root@webserver ~]# yum install epel-release
Nothing to do
[root@webserver ~]# yum install socat tmux
* centos-base: centos.bhs.mirrors.ovh.net
* centos-updates: centos.bhs.mirrors.ovh.net
[root@webserver ~]#
dnutan
(Marc)
July 15, 2017, 8:43pm
4
Maybe it’s disabled. Try with:
yum --enablerepo=epel install tmux socat
BTW, NethServer 6.9 is the latest release for the v6 branch.
lorentedford
July 15, 2017, 8:45pm
5
You Rock!!! Thank You so much!!!
It workded <3
Nothing to do
[root@webserver ~]# yum --enablerepo=epel install tmux socat
epel/metalink | 13 kB 00:00
* epel: fedora-epel.mirrors.tds.net
epel | 4.3 kB 00:00
epel/primary_db | 5.9 MB 00:00
Resolving Dependencies
--> Running transaction check
---> Package socat.x86_64 0:1.7.2.3-1.el6 will be installed
--> Processing Dependency: libreadline.so.5()(64bit) for package: socat-1.7.2.3-1.el6.x86_64
---> Package tmux.x86_64 0:1.6-3.el6 will be installed
---> Package compat-readline5.x86_64 0:5.2-17.1.el6 will be installed
Dependencies Resolved
Package Arch Version Repository Size
Installing:
socat x86_64 1.7.2.3-1.el6 epel 246 k
tmux x86_64 1.6-3.el6 epel 208 k
Installing for dependencies:
compat-readline5 x86_64 5.2-17.1.el6 centos-base 130 k
Transaction Summary
Install 3 Package(s)
Total download size: 583 k
Installed size: 1.7 M
Is this ok [y/N]: y
Downloading Packages:
Setting up and reading Presto delta metadata
Processing delta metadata
Package(s) data still to download: 583 k
(1/3): compat-readline5-5.2-17.1.el6.x86_64.rpm | 130 kB 00:00
(2/3): socat-1.7.2.3-1.el6.x86_64.rpm | 246 kB 00:00
(3/3): tmux-1.6-3.el6.x86_64.rpm | 208 kB 00:00
Total 551 kB/s | 583 kB 00:01
Running rpm_check_debug
Running Transaction Test
Transaction Test Succeeded
Running Transaction
Installing : compat-readline5-5.2-17.1.el6.x86_64 1/3
Installing : socat-1.7.2.3-1.el6.x86_64 2/3
Installing : tmux-1.6-3.el6.x86_64 3/3
Verifying : socat-1.7.2.3-1.el6.x86_64 1/3
Verifying : compat-readline5-5.2-17.1.el6.x86_64 2/3
Verifying : tmux-1.6-3.el6.x86_64 3/3
Installed:
socat.x86_64 0:1.7.2.3-1.el6 tmux.x86_64 0:1.6-3.el6
Dependency Installed:
Complete!
[root@webserver ~]#
