NethServer Version: 7.9.2009
Module: nextcloud 1.17
Hi everyone!
My server installs updates by itself and I haven’t had any problem so far. Except now. A few months ago, I updated Nextcloud to 21.0.1.1, had issues with version number but it was working perfectly after that. Yesterday, it was working fine but today morning, it shows me Internal Server Error. I also got an error email at 6:20 AM. Every line of warning is about /usr/share/nextcloud and no such file or directory. I will try to paste the whole email here but it’s quite long.
I found out that 1.17 of the nextcloud module was released and I’m thinking that maybe it has problems with the versions or something. I couldn’t find any useful information in any log file.
Is there any way to roll back the nethserver-module to the previous version?
Can’t paste the whole email, too long but here is a portion of it:
/etc/cron.daily/0yum-daily.cron:
warning: file /usr/share/nextcloud/lib/public/User/Events/CreateUserEvent.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/lib/public/Settings/ISection.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/lib/public/AppFramework/Http/OCSResponse.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/lib/private/Hooks/LegacyEmitter.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/lib/private/Hooks/ForwardingEmitter.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/lib/private/DB/MDB2SchemaWriter.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/apps/user_ldap/appinfo/update.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/apps/user_ldap/appinfo/register_command.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/apps/user_ldap/appinfo/install.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/apps/text/js/vendor.js.map: remove failed: No such file or directory
warning: file /usr/share/nextcloud/apps/text/js/vendor.js: remove failed: No such file or directory
warning: file /usr/share/nextcloud/apps/text/js/highlight/tex.js.map: remove failed: No such file or directory
warning: file /usr/share/nextcloud/apps/text/js/highlight/tex.js: remove failed: No such file or directory
warning: file /usr/share/nextcloud/apps/text/js/highlight/nimrod.js.map: remove failed: No such file or directory
warning: file /usr/share/nextcloud/apps/text/js/highlight/nimrod.js: remove failed: No such file or directory
warning: file /usr/share/nextcloud/apps/text/js/highlight/cs.js.map: remove failed: No such file or directory
warning: file /usr/share/nextcloud/apps/text/js/highlight/cs.js: remove failed: No such file or directory
warning: file /usr/share/nextcloud/apps/settings/js/vue-vendors-settings-users-bcea665d3ab241c6619f.js.map: remove failed: No such file or directory
warning: file /usr/share/nextcloud/apps/settings/js/vue-vendors-settings-users-bcea665d3ab241c6619f.js: remove failed: No such file or directory
warning: file /usr/share/nextcloud/apps/settings/js/vue-vendors-settings-apps-settings-users-feb6e6add9aee6bcda40.js.map: remove failed: No such file or directory
warning: file /usr/share/nextcloud/apps/settings/js/vue-vendors-settings-apps-settings-users-feb6e6add9aee6bcda40.js: remove failed: No such file or directory
warning: file /usr/share/nextcloud/apps/settings/js/vue-vendors-settings-apps-0e3130278180acc1bb58.js.map: remove failed: No such file or directory
warning: file /usr/share/nextcloud/apps/settings/js/vue-vendors-settings-apps-0e3130278180acc1bb58.js: remove failed: No such file or directory
warning: file /usr/share/nextcloud/apps/settings/js/vue-settings-users-f21df1de93ddcf45e13b.js.map: remove failed: No such file or directory
warning: file /usr/share/nextcloud/apps/settings/js/vue-settings-users-f21df1de93ddcf45e13b.js: remove failed: No such file or directory
warning: file /usr/share/nextcloud/apps/settings/js/vue-settings-apps-489d5f46c67b4e8fbf67.js.map: remove failed: No such file or directory
warning: file /usr/share/nextcloud/apps/settings/js/vue-settings-apps-489d5f46c67b4e8fbf67.js: remove failed: No such file or directory
warning: file /usr/share/nextcloud/apps/files_sharing/css/sharedfilelist.css: remove failed: No such file or directory
warning: file /usr/share/nextcloud/apps/files_pdfviewer/js/pdfjs/web/images/treeitem-collapsed-rtl@2x.png: remove failed: No such file or directory
warning: file /usr/share/nextcloud/apps/files_pdfviewer/js/pdfjs/web/images/treeitem-collapsed-rtl.png: remove failed: No such file or directory
warning: file /usr/share/nextcloud/apps/files_pdfviewer/js/pdfjs/web/images/toolbarButton-viewOutline-rtl@2x.png: remove failed: No such file or directory
warning: file /usr/share/nextcloud/apps/files_pdfviewer/js/pdfjs/web/images/toolbarButton-viewOutline-rtl.png: remove failed: No such file or directory
warning: file /usr/share/nextcloud/apps/files_pdfviewer/js/pdfjs/web/images/toolbarButton-sidebarToggle-rtl@2x.png: remove failed: No such file or directory
warning: file /usr/share/nextcloud/apps/files_pdfviewer/js/pdfjs/web/images/toolbarButton-sidebarToggle-rtl.png: remove failed: No such file or directory
warning: file /usr/share/nextcloud/apps/files_pdfviewer/js/pdfjs/web/images/toolbarButton-secondaryToolbarToggle-rtl@2x.png: remove failed: No such file or directory
warning: file /usr/share/nextcloud/apps/files_pdfviewer/js/pdfjs/web/images/toolbarButton-secondaryToolbarToggle-rtl.png: remove failed: No such file or directory
warning: file /usr/share/nextcloud/apps/files_pdfviewer/js/pdfjs/web/images/toolbarButton-pageUp-rtl@2x.png: remove failed: No such file or directory
warning: file /usr/share/nextcloud/apps/files_pdfviewer/js/pdfjs/web/images/toolbarButton-pageUp-rtl.png: remove failed: No such file or directory
warning: file /usr/share/nextcloud/apps/files_pdfviewer/js/pdfjs/web/images/toolbarButton-pageDown-rtl@2x.png: remove failed: No such file or directory
warning: file /usr/share/nextcloud/apps/files_pdfviewer/js/pdfjs/web/images/toolbarButton-pageDown-rtl.png: remove failed: No such file or directory
warning: file /usr/share/nextcloud/apps/files_pdfviewer/js/pdfjs/web/images/findbarButton-previous-rtl@2x.png: remove failed: No such file or directory
warning: file /usr/share/nextcloud/apps/files_pdfviewer/js/pdfjs/web/images/findbarButton-previous-rtl.png: remove failed: No such file or directory
warning: file /usr/share/nextcloud/apps/files_pdfviewer/js/pdfjs/web/images/findbarButton-next-rtl@2x.png: remove failed: No such file or directory
warning: file /usr/share/nextcloud/apps/files_pdfviewer/js/pdfjs/web/images/findbarButton-next-rtl.png: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/web-auth/webauthn-lib/README.md: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/web-auth/metadata-service/README.md: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/web-auth/cose-lib/README.md: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/symfony/polyfill-util/composer.json: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/symfony/polyfill-util/TestListenerTrait.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/symfony/polyfill-util/TestListener.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/symfony/polyfill-util/README.md: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/symfony/polyfill-util/LegacyTestListener.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/symfony/polyfill-util/LICENSE: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/symfony/polyfill-util/BinaryOnFuncOverload.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/symfony/polyfill-util/BinaryNoFuncOverload.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/symfony/polyfill-util/Binary.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/symfony/polyfill-util: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/symfony/polyfill-php56/composer.json: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/symfony/polyfill-php56/bootstrap.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/symfony/polyfill-php56/README.md: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/symfony/polyfill-php56/Php56.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/symfony/polyfill-php56/LICENSE: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/symfony/polyfill-php56: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/swiftmailer/swiftmailer/.github/PULL_REQUEST_TEMPLATE.md: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/swiftmailer/swiftmailer/.github/ISSUE_TEMPLATE.md: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/swiftmailer/swiftmailer/.github: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/scssphp/scssphp/src/SourceMap/Base64VLQEncoder.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/sabre/dav/CONTRIBUTING.md: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/sabre/dav/CHANGELOG.md: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/sabre/dav/.gitignore: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/react/promise/src/functions_include.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/react/promise/src/functions.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/mtdowling/jmespath.php/phpunit.xml.dist: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/mtdowling/jmespath.php/Makefile: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/mtdowling/jmespath.php/CHANGELOG.md: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/mtdowling/jmespath.php/.gitignore: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/reflection/docs/en/reference: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/reflection/docs/en/index.rst: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/reflection/docs/en: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/reflection/docs: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/reflection/composer.json: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/reflection/README.md: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/reflection/LICENSE: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/reflection/.scrutinizer.yml: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/reflection: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/persistence/lib/Doctrine/Common/PropertyChangedListener.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/persistence/lib/Doctrine/Common/Persistence/Proxy.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/persistence/lib/Doctrine/Common/Persistence/PersistentObject.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/persistence/lib/Doctrine/Common/Persistence/ObjectRepository.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/persistence/lib/Doctrine/Common/Persistence/ObjectManagerDecorator.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/persistence/lib/Doctrine/Common/Persistence/ObjectManagerAware.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/persistence/lib/Doctrine/Common/Persistence/ObjectManager.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/persistence/lib/Doctrine/Common/Persistence/Mapping/StaticReflectionService.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/persistence/lib/Doctrine/Common/Persistence/Mapping/RuntimeReflectionService.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/persistence/lib/Doctrine/Common/Persistence/Mapping/ReflectionService.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/persistence/lib/Doctrine/Common/Persistence/Mapping/MappingException.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/persistence/lib/Doctrine/Common/Persistence/Mapping/Driver/SymfonyFileLocator.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/persistence/lib/Doctrine/Common/Persistence/Mapping/Driver/StaticPHPDriver.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/persistence/lib/Doctrine/Common/Persistence/Mapping/Driver/PHPDriver.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/persistence/lib/Doctrine/Common/Persistence/Mapping/Driver/MappingDriverChain.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/persistence/lib/Doctrine/Common/Persistence/Mapping/Driver/MappingDriver.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/persistence/lib/Doctrine/Common/Persistence/Mapping/Driver/FileLocator.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/persistence/lib/Doctrine/Common/Persistence/Mapping/Driver/FileDriver.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/persistence/lib/Doctrine/Common/Persistence/Mapping/Driver/DefaultFileLocator.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/persistence/lib/Doctrine/Common/Persistence/Mapping/Driver/AnnotationDriver.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/persistence/lib/Doctrine/Common/Persistence/Mapping/Driver: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/persistence/lib/Doctrine/Common/Persistence/Mapping/ClassMetadataFactory.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/persistence/lib/Doctrine/Common/Persistence/Mapping/ClassMetadata.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/persistence/lib/Doctrine/Common/Persistence/Mapping/AbstractClassMetadataFactory.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/persistence/lib/Doctrine/Common/Persistence/Mapping: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/persistence/lib/Doctrine/Common/Persistence/ManagerRegistry.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/persistence/lib/Doctrine/Common/Persistence/Event/PreUpdateEventArgs.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/persistence/lib/Doctrine/Common/Persistence/Event/OnClearEventArgs.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/persistence/lib/Doctrine/Common/Persistence/Event/ManagerEventArgs.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/persistence/lib/Doctrine/Common/Persistence/Event/LoadClassMetadataEventArgs.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/persistence/lib/Doctrine/Common/Persistence/Event/LifecycleEventArgs.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/persistence/lib/Doctrine/Common/Persistence/Event: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/persistence/lib/Doctrine/Common/Persistence/ConnectionRegistry.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/persistence/lib/Doctrine/Common/Persistence/AbstractManagerRegistry.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/persistence/lib/Doctrine/Common/Persistence: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/persistence/lib/Doctrine/Common/NotifyPropertyChanged.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/persistence/lib/Doctrine/Common: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/persistence/lib/Doctrine: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/persistence/lib: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/persistence/composer.json: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/persistence/README.md: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/persistence/LICENSE: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/persistence/.doctrine-project.json: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/persistence: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/inflector/lib/Doctrine/Common/Inflector/Inflector.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/inflector/lib/Doctrine/Common/Inflector: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/inflector/lib/Doctrine/Common: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/inflector/lib/Doctrine: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/inflector/lib: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/inflector/composer.json: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/inflector/README.md: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/inflector/LICENSE: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/inflector: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/dbal/psalm.xml: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/VersionAwarePlatformDriver.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Version.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Types/VarDateTimeType.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Types/VarDateTimeImmutableType.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Types/Types.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Types/TypeRegistry.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Types/Type.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Types/TimeType.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Types/TimeImmutableType.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Types/TextType.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Types/StringType.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Types/SmallIntType.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Types/SimpleArrayType.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Types/PhpIntegerMappingType.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Types/PhpDateTimeMappingType.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Types/ObjectType.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Types/JsonType.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Types/JsonArrayType.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Types/IntegerType.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Types/GuidType.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Types/FloatType.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Types/DecimalType.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Types/DateType.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Types/DateTimeTzType.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Types/DateTimeTzImmutableType.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Types/DateTimeType.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Types/DateTimeImmutableType.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Types/DateIntervalType.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Types/DateImmutableType.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Types/ConversionException.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Types/BooleanType.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Types/BlobType.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Types/BinaryType.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Types/BigIntType.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Types/ArrayType.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Types: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/TransactionIsolationLevel.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Tools/Dumper.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Tools/Console/Helper/ConnectionHelper.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Tools/Console/Helper: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Tools/Console/ConsoleRunner.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Tools/Console/Command/RunSqlCommand.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Tools/Console/Command/ReservedWordsCommand.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Tools/Console/Command/ImportCommand.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Tools/Console/Command: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Tools/Console: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Tools: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Statement.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Sharding/ShardingException.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Sharding/ShardManager.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Sharding/ShardChoser/ShardChoser.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Sharding/ShardChoser/MultiTenantShardChoser.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Sharding/ShardChoser: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Sharding/SQLAzure/Schema/MultiTenantVisitor.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Sharding/SQLAzure/Schema: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Sharding/SQLAzure/SQLAzureShardManager.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Sharding/SQLAzure/SQLAzureFederationsSynchronizer.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Sharding/SQLAzure: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Sharding/PoolingShardManager.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Sharding/PoolingShardConnection.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Sharding: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Schema/Visitor/Visitor.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Schema/Visitor/SchemaDiffVisitor.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Schema/Visitor/RemoveNamespacedAssets.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Schema/Visitor/NamespaceVisitor.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Schema/Visitor/Graphviz.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Schema/Visitor/DropSchemaSqlCollector.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Schema/Visitor/CreateSchemaSqlCollector.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Schema/Visitor/AbstractVisitor.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Schema/Visitor: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Schema/View.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Schema/TableDiff.php: remove failed: No such file or directory
warning: file /usr/share/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Schema/Table.php: remove failed: No such file or directory
