Module: Nextcloud 23.03
I can see the following Errors being Displayed on the Overview Page of Nextcloud
Should these worry me, or they are perfectly fine.
If i should be worried, are they resolved from the Nethserver Side, or NExtcloud Side.
There are some errors regarding your setup.
* Your web server is not yet properly set up to allow file synchronisation, because the WebDAV interface seems to be broken.
* Error occurred whilst checking server setup
* Your web server is not properly set up to resolve "/ocm-provider/". This is most likely related to a web server configuration that was not updated to deliver this folder directly. Please compare your configuration against the shipped rewrite rules in ".htaccess" for Apache or the provided one in the documentation for Nginx at it's [documentation page β](https://docs.nextcloud.com/server/23/go.php?to=admin-nginx). On Nginx those are typically the lines starting with "location ~" that need an update.
* Your web server is not properly set up to resolve "/ocs-provider/". This is most likely related to a web server configuration that was not updated to deliver this folder directly. Please compare your configuration against the shipped rewrite rules in ".htaccess" for Apache or the provided one in the documentation for Nginx at it's [documentation page β](https://docs.nextcloud.com/server/23/go.php?to=admin-nginx). On Nginx those are typically the lines starting with "location ~" that need an update.
* Your web server is not properly set up to deliver .woff2 files. This is typically an issue with the Nginx configuration. For Nextcloud 15 it needs an adjustement to also deliver .woff2 files. Compare your Nginx configuration to the recommended configuration in our [documentation β](https://docs.nextcloud.com/server/23/go.php?to=admin-nginx).
* Your web server is not properly set up to resolve "/.well-known/webfinger". Further information can be found in the [documentation β](https://docs.nextcloud.com/server/23/go.php?to=admin-setup-well-known-URL).
* Your web server is not properly set up to resolve "/.well-known/nodeinfo". Further information can be found in the [documentation β](https://docs.nextcloud.com/server/23/go.php?to=admin-setup-well-known-URL).
* Your web server is not properly set up to resolve "/.well-known/caldav". Further information can be found in the [documentation β](https://docs.nextcloud.com/server/23/go.php?to=admin-setup-well-known-URL).
* Your web server is not properly set up to resolve "/.well-known/carddav". Further information can be found in the [documentation β](https://docs.nextcloud.com/server/23/go.php?to=admin-setup-well-known-URL).
Please double check the [installation guides β](https://docs.nextcloud.com/server/23/go.php?to=admin-install), and check for any errors or warnings in the [log](https://cloud.genius.ke/index.php/settings/admin/logging).
