Nextcloud 18.0.4 is ready to be tested!
I’m asking your support, because as @dnutan already pointed out in the tracker, this release of Nextcloud contains a bug inside the Samba share connection plugin: https://github.com/nextcloud/server/issues/20622
The bug should not affect all installations. Anyone who use the Samba integration would give it a try?
Nextcloud 18.0.4 is available only on NethServer 7.8.2003 (which is read, but just wait for the announcement ;)).
To install it:
yum --enablerepo=nethserver-testing update nethserver-nextcloud
More info at https://github.com/NethServer/dev/issues/6155
