LayLow
(LayLow)
April 5, 2024, 11:43am
1
I just updated nextcloud to 1.16. available via Software Center. After update I tried to login, but that failes. It seems that the LDAP value under settings is gone:
After manually setting the LDAP server back to the correct instance, I could login again.
Result of update to 1.1.6: Users can no longer login to Nextcloud
HTH
fausp
(fpausp)
April 5, 2024, 7:55pm
2
Got also troubles after Nextcloud update, my domain joined NS8 stays in maintenance mode:
mrmarkuz
(Markus Neuberger)
April 6, 2024, 8:08am
3
Are there errors in the logs?
As explained in the wiki (NS7) , you may need to turn off maintenance mode manually.
In NS8 you can execute occ like that:
runagent -m nextcloud1 occ maintenance:mode --off
LayLow
(LayLow)
April 6, 2024, 6:50pm
4
Just curious, just me, or anybody else have this issue?
Hi @LayLow ,
i have just updated two NS8 machines on two separate networks. So far no problems.
Regards…
Uwe
LayLow
(LayLow)
April 6, 2024, 7:03pm
6
transocean:
So far no problems
Thanks for the feedback.
‘My issue’ is annoying, but solvable. So hopefully it was a 1 time issue. Let’s save this one for the records
We’ll see after the next update at the latest.
