One of our partner has some network copier with scanner function. I replaced their old Ubuntu server with NS, the DC working fine, but the scanners can’t acces the shared scanner folder,I always get password error. With the old ubuntu and the samba the copiers worked fine.
What could be wrong?
Yes, this is a big sucks! You can’t say that the copier wrong or to old when you are the maintainer of the copier too…
There is no prbolem with the share. The samba works wine as DC, and I can access the scan folder with the kyoscan user from PC.
Wrong username or password in the log, when the copiers try to log in.
Yes, I have the old smb.conf, but I left the hdd in the office, so…
Can the scanner handle ftp? If so, I would suggest setting up ftp for the scanner and symlinking or bind mounting the ftp folder somewhere in your samba share.
Yes. I’m working on it… Maybe this is the only solution. The only problem I can’t figure out how working the system user authentication. I always get wrong password erro with Total Commander.
