Shadowfire
(Jeff Davis)
1
I don’t see a provider that I want to use. Is there a way to add another provider that is not on the provider list?
I don’t see a custom selection under Nethvoice providers. Can I not use any other providers outside the providers list when using Nethvoice?
Thx
SF
mrmarkuz
(Markus Neuberger)
2
I managed to setup a provider by choosing some provider in the list and going to the “advanced admin settings”:
This opens FreePBX where you can setup your provider under “Connectivity/Trunks/<Provider name>/pjsip Settings”:
I think it’s also possible to setup your gateway model there…
Shadowfire
(Jeff Davis)
3
Thanks sir! I will check it out. I appreciate the feedback. I will report back on what I find.
