πŸš€ NethVoice 1.6.4 Released
We are pleased to announce the release 1.6.4 of NethVoice App, a significant update that introduces improvements to installation, interface, and user experience, along with numerous stability fixes.
Development of features related to Artificial Intelligence and the address book also continues.
:backhand_index_pointing_right: You can follow the development progress in real time via the official NethVoice roadmap.
:pushpin: Roadmap
:sparkles: Main Updates
:globe_with_meridians: New local network management in NethVoice Proxy (on-premises)
Starting from version 1.6.0, NethVoice Proxy automatically uses the IP address of the local network interface to communicate with clients when it differs from the public IP.
This means that devices on the local network are provided with the internal IP for:
  • SIP and SIP TLS signaling
    • 5060/UDP
    • 5061/TCP
  • RTP traffic
    • 10000–20000/UDP
If split DNS is correctly configured (FQDN resolved with local IP on LAN and public IP from external networks), communication remains internal, avoiding the need to configure Hairpin NAT on the firewall.
The different installation scenarios are explained in the manual.
For more details: NethServer/7725
:telephone_receiver: Support for new Gigaset IP models
Support has been added for the following phones:
  • P710 IP PRO
  • P810-P810B IP PRO
  • P820-P825 IP PRO
  • P850W-P855BW IP PRO
For more details: NethServer/7764
:locked_with_key: New authentication extended to the NethVoice App
The new authentication method has also been extended to the NethVoice App, increasing the level of security, including usage via QR Code.
For more details:
:hammer_and_wrench: Other improvements
:package: NethLink 1.4.3
The new version of NethLink introduces:
  • New Command Bar: keyboard shortcuts to access many features (calls, contacts, etc.).
    Documentation available in the manual here
  • :mobile_phone: Updated Phone Island with all the latest improvements
  • :brain: Fixed a memory leak that caused abnormal resource usage
  • :magnifying_glass_tilted_left: Address book search directly from the command bar
:hammer_and_wrench: Other issues resolved
  • NethVoice: Settings page did not update after initial configuration
  • NethVoice: proxy IP not updated after moving the instance within the same cluster
  • NethVoice: application restarted without confirmation
  • NethVoice Report showing no data despite correctly scheduled tasks
  • NethVoice CTI: incorrect use of UniqueID in parameterized URLs (fixed to LinkedID)
  • NethVoice: incomplete Internal users filter with infinite scroll
  • NethVoice CTI: CTI crash during manual click2call with only a physical phone configured
Is this still the case?
Bump.
I am actually wondering what the target market is, for if only resellers can use it usefully without restrictions, what is the purpose to others?
The Community version of NethVoice is mainly meant as a free entry point: for testing, small setups, labs, or getting familiar with the product.
It has limits so it’s designed only for very small environments.
The real target for full business use is the subscription version, which removes those limits and adds support, advanced features, and scalability.
So in short: Community = try & learn / small use cases. Subscription = actual business deployment.
At the moment, there are subs only for resellers.
Maybe it is an idea to create a specific reseller category on these forums? I waisted a lot of time in NethVoice before I asked for whom it was actually intended for. It changed from Wow! to completely useless for me.
What do you mean? NethVoice App is Open Source and you can freely use it, with some limitations. What do you need specifically? Where do you want to activate it? So we can find a way
