I can not install nethserver subscription, because I’m stuck on enterprise branded nethserver. If I try on terminal:
yum install @nethserver-subscription
Group nethserver-subscription does not exist.
Error: Nothing to do
Also software center does not show a module for subscription.
What do I need to do to fall back to a standard nethserver installation for this expired enterprise server?
Thanks
yes I was on Enterprise.
Let the commands run.
Now my branding (Logo) is standard again.
Software center brought up some updates and I installed those.
Problem now: Software center does not show what is installed or could be installed, the list is empty.
How to bring back correct listing so I can choose to install nethserver.subscription?
Please don’t! Unless the db is corrupted don’t execute such command!
@asl you probably have only metadata issues and you need to reconfigure the software center, just execute:
cat <<EOF > /etc/nethserver/pkginfo.conf
# This is the list of YUM repositories that have their groups listed
# on the Software Center UI page, through the pkginfo helper.
# One repository identifier per line
nethserver-updates
nethforge
EOF
yum clean all
Feel free to contact Nethesis support if you still have any problem
@giacomo you solved it. The file /etc/nethserver/pkginfo.conf is differnet on enterprise edition. I changed back to what you posted and what I also could see on my other servers and I’m back to normal again.
so one more subscription is on it’s way now
I’m coming from an enterprise installation and that’s why there is already a token installed it looks like.
I assume that I need a procedure to remove the existing token so I can enter that one I just bought. My Subscription page looks like this:
This will delete the subscription entered and in my case the old parts of the registration from privious enterprise branded installation.
Now I can enter a token.
Thanks to all.
